Sc code 195
Hi i am having problem with my aficio 3245c there appere sc code 195 . i checked out from service manual written there serial num - misfeed . i don.t know how to solve it can help me please.
myob247
  • 1342 Answers
SOURCE: Advent 6415 Combo laptop (aka Gericom N340S8) service manual/specs required
Here's one.
Go all the way to the bottom of the page for the ftp link. They have the service and the user manual. I just downloaded it and it is in English.
Posted on May 02, 2008
  • 52 Answers
SOURCE: serial # recovery
contact the store nd give them the information on the recipt, they should give you either the service tag or the serial #
Posted on May 26, 2008
SOURCE: ricoh aficio 3500
sc441 error means one or more of the developer unit(PCU) isnt rotating. you have to take the PCU out to see which color isnt rotating. there maybe one of the doctor blade is flipped, usually caused by lack of toner in the PCU.
Posted on Jun 05, 2008
  • 19 Answers
SOURCE: i have a ricoh aficio 450 and there is error code sc 350 - 01 apperes , what can i do ?
First of all never touch the optics section of a 450 will give you SC101
I got three solutions for you.
1. Clean the ID sensor.
Take out the Drum Unit, and locate it in the machine its on the top facing the drum.
2. Go to SP Mode. Clear Modes enter 1 0 7 press clear/stop for 4 seconds. enter 1, enter 3001-2 and execute, exit SP Mode.
3. Or Some developer is missing.
Posted on Dec 24, 2008
  • 86 Answers
SOURCE: Gestetner 3218 Aficio 180 Fuctional Problem SC 543
Enter SP mode - Clear button (yellow key), 1 0 7 and hold and press stop button (orange key).
Enter SP5-810 (SC code reset) and select “1”.
Then hold down the “Photo mode” key and the enter key(hash) at the same time for at least 3 seconds (it is not necessary to turn the main switch off andon). If the machine beeps 5 times, the reset was successful. If it only beeps twice, the reset failed, and you need to repair the machine.
Possible causes are the fusing thermistor in the fuser unit, or the power supply unit defective.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
Ghost image ricoh 3245c
No can do, if you are referring Norton Ghost. Ghost it only for OS on computers. Printers have chips with instructions.
Here are the drivers in case you need them.
http://support.ricoh.com/bb/html/dr_ut_e/ra/model/c35_45/c35_45en.htm
Oct 25, 2012 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
Ricoh aficio 3232c SC 571
ricoh aficio 3232c eror code sd 195
Aug 02, 2011 | Ricoh Aficio 2232C Color Copier
Appel service technique Ricoh aficio 1232C super G3. code SC571. j'ai rempli le réservoir de l'huile de vaseline d'après les forums.mais toujours le...
code 571 low oil top up oil located back of copier reset code press yellow key 1 0 7 press red
key keep held for 4 secounds go in copy sp press 5 press lower cursor key untill you reach 5 810
sc reset code then turn copier off/ on
Nov 08, 2010 | Ricoh Aficio 1232C Color Copier
Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Jan 15, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 250, clear misfeeds at w and finisher
Clean the sensors in this parts and try reset the SC codes:Enter in the SP mode press 5-810 (SC code reset)select 1.Then hold down the Photo mode key and the +key at the same time for at least 4 sec.
Sep 23, 2009 | Ricoh Aficio 250 Copier
Sc code 672 with aficio 2090
Direct from the service manual:
• Controller board defective
• Controller board installed incorrectly
• Operation panel harness connection loose or incorrect
May 03, 2009 | Office Equipment & Supplies
Service code SC 548 on a Ricoh Aficio SPC 811dn printer, what is it and how to correct?
I have sc 548 error code also. I was following your instruction, but i couldn't enter to service mode. How do i prepare it? Please write this instruction to me step by step.
Apr 23, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Paper jam/misfeed constantly
creo que el sc 547 es el termostato del fusor de la maquina fijate reiniciandola en el modo "sp"
Jun 14, 2008 | Ricoh Aficio 1085 Laser Printer
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
