Question about Vehicle Parts & Accessories
Ford e350 diesel
I am leaking coolant.. i have located the issue. from the coolant jug i followed the large feed hose which ran into a "T" joint. this "T" joint has cracked and i am leaking from there.. what is the part number
    Top Expert:
  • Vehicle Part... Master
  • 12,223 Answers
Go to www.advanceautoparts.com and get it
God bless you
Posted on Jul 19, 2013
How do I fix a coolant leak
Find leak soon, low coolant will kill a diesel. Keep coolant level correct. Inspect very carefully with a bright flashlight. I like the new Led lights. Look for wet areas radiator hoses, heater hoses water (coolant) pump and Heater coil inside. Do you have any bubbling in the coolant fill tank when engine is running? If so you probably have a Head Gasket failure.
Mar 12, 2015 | 2005 Ford Fusion
I have a 2002 Ford Econline E350 that the front air comes out only out of the windshield area, no air out of face/feet area. Already replaced the Blending Door Actuator, please help! :)
Go directly towards a vacuum leak . The vacuum reservoir is notorious for going bad in the these vans , unfortunately you have to pull the heater box to repair it which takes numerous hours. Hopefully it is just a vacuum leak that's accessible. If its a diesel I would first check the vacuum pump , if its gas then start by checking the small vacuum line under the hood along the cowl on the right rear of the engine compartment. Pull apart one of the tee fittings and check for vacuum with the engine running . Then check inside the truck pass side under dash for a bunch of vacuum hoses . Got vacuum?
Mar 31, 2014 | Ford Cars & Trucks
I replaced my radiator on my 2004 with a 2.2 and it seems like the thermostat is not opening. It can not get the air out. It seem to just to over heat and push the coolant out. Randy
REPLACE THERMOSTAT IF TOP COOLANT COOLANT HOSE GOING TO RADIATOR IS HOT TO TOUCH THERMOSTAT OPEN. TO BLEED COOLANT SYSTEM FIRST YOU NEED TO ADD COOLANT TO THE COOLANT OVER FLOW JUG UNTIL COOLANT LEVEL STOP DROPPING AND STAY AT FULL COLD MARK.WAIT 3 MINUTES IF COOLANT DROPS ADD MORE COOLANT UNTIL COOLANT STAY AT FULL COLD MARK.WITH RADIATOR OVER CAP OFF CRANK ENGINE FOR MINUTE WATCH COOLANT LEVEL AT OVERFLOW JUG.IF COOLANT DROPS ADD MORE COOLANT IN THE OVERFLOW JUG.WHEN COOLANT LEVEL STOP DROPPING IN OVERFLOW JUG.SCREW BACK ON THE RADIATOR CAP TO OVERFLOW JUG.WHILE ENGINE IDLING WATCH TEMPERATURE GAUGE WHEN TEMPERATURE START CLIMBING TURN OFF ENGINE WAIT A WHILE KEEP FROM GETTING SCALDED.WHEN COOLANT COOL DOWN SOME. PLACE A LARGE RAG OVER THE COOLANT OVERFLOW JUG OPEN CAP LITTLE AT A TIME UNTIL PRESSURE RELEASED, THEN REMOVE CAP ADD MORE COOLANT IN THE OVERFLOW JUG TO THE FULL COLD MARK.THEN REPEAT THE PROCESS SCREW BACK ON THE COOLANT OVERFLOW RADIATOR PRESSURE CAP.THEN START ENGINE WATCH TEMPERATURE GAUGE WATCH COOLANT TEMPERATURE GAUGE WHEN COOLANT TEMPERATURE START RISING TURN OFF ENGINE AGAIN WAIT UNTIL ENGINE COOL DOWN ENOUGH TO KEEP FROM GETTING SCALDED TAKE PLACE LARGE RAG OVER RADIATOR CAP WHICH IS THE COOLANT OVERFLOW JUG CAP OPEN CAP LITTLE AT A TIME UNTIL PRESSURE RELEASED ADD COOLANT UNTIL AT FULL COLD MARK. WHEN YOUR COOLANT LEVEL STOP DROPPING.AND TOP RADIATOR HOSE VERY HOT THERMOSTAT OPEN AND AIR IS OUT THE COOLANT SYSTEM. MAKE SURE YOUR COOLANT OVERFLOW JUG HAS COOLANT IN IT,WHEN ENGINE COOL DOWN CHECK COOLANT OVERFLOW JUG KEEP COOLANT LEVEL AT FULL COLD MARK.BECAUSE IF OVERFLOW JUG IS EMPTY THATS A SIGN RADIATOR COOLANT LEVEL LOW.WHEN OVERFLOW JUG EMPTY IT WILL ALLOW AIR GET IN THE COOLANT SYSTEM AND CAUSE CAR TO OVERHEAT.WHEN REPLACING THERMOSTAT ALSO REPLACE THE RADIATOR CAP ON THE COOLANT OVERFLOW JUG.
Aug 09, 2011 | 2004 Oldsmobile Alero
Overheating
CAR OVERHEATING FIRST CHECK FOR LOW COOLANT IN THE RADIATOR COOLANT OVERFLOW JUG.IF COOLANT LEVEL IN OVERFLOW JUG LOW REFILL ADD COOLANT BACK TO THE FULL COLD MARK.PUT RADAITOR CAP ON COOLANT OVERFLOW JUG START ENGINE LET IT IDLE UNTIL IT OPERATING TEMPERATURE.MAKE SURE TOP RADIATOR HOSE GETTING HOT WHILE ENGINE WARM UP.IF TOP RADIATOR HOSE DONT GET HOT WHILE ENGINE IDLING YOUR THERMOSTAT COULD BE STUCK CLOSE CAUSING CAR TO OVERHEAT.IF TOP HOSE IS GETTING HOT.CHECK FOR COOLANT LEAKS CHECK TOP RADIATOR HOSE AND BOTTOM RADIATOR HOSE FOR LEAKS.CHECK FOR LEAKS AT THE RADIATOR CORES AND PLASTIC SIDE CONTAINERS.IF ALL IS GOOD ENGINE OVERHEATING WHILE IN A LONG TRAFFIC LINE, COOLANT FANS NOT COMING ON.COULD HAVE FAULTY ENGINE COOLANT TEMPERATURE SENSOR OR BLOWN COOLING FAN FUSE OR RELAY.COULD HAVE PCM FAULT.MAKE COOLING FAN ELECTRICAL CONNECTORS AND WIRING NOT DAMAGE OR BROKEN.
Jul 17, 2011 | 1999 Oldsmobile Alero
How do i replace the water thmostat 99 6 cylider
WELL YOU NEED TO DRAIN COOLANT LEVEL BELOW THERMOSTAT LEVEL.YOU HAVE TO DISCONNECT MAF SENSOR LOOSEN AIRDUCT 2 LARGE CLAMPS LOOSEN REMOVE 4 SCREWS TO AIR FILTER COVER LIFT UP REMOVE COVER. THEN REMOVE AIR FILTER AND HOUSING, FIRST DISCONNECT MAF SENSOR.YOU HAVE TO DISCONNECT THROTTLE CABLE AND SHIFT CABLE.YOU HAVE TO DISCONNECT REMOVE THROTTLE BODY COOLANT HOSES DISCONNECT IDLE SPEED CONTROL VALVE CONNECTOR AND DISCONNECT TPS SENSOR CONNECTOR. THEN REMOVE THROTTLE BODY ASSEMBLY. YOU NEED TO BUY NEW THROTTLE BODY COOLANT HOSES AND NEW THROTTLE BODY GASKET FOLLOW TOP COOLANT HOSE TO ENGINE BLOCK.NOW YOU SEE CAN AND REMOVE THE THERMOSTAT HOUSING REPLACE THE THERMOSTAT.BESURE TO HAVE EXTRA COOLANT ON HAND.BLEED COOLANT SYSTEM WHEN DONE.TO BLEED COOLANT SYSTEM REMOVE RADIATOR CAP ON OVERFLOW JUG.THEN OPEN BLEED SCREW ON THE WATER PUMP BYPASS HOSE PIPE JUST A LITTLE.POUR COOLANT IN THE OVERFLOW JUG UNTIL LEVEL STOP DROPPING.STOP AT COLD MARK ON JUG.CLOSE BLEEDER SCREW ON WATER PUMP BYPASS HOSE PIPE.CRANK VECHICLE CHECK FOR LEAKS. START UP ENGINE LET IDLE FEW MINUTES THEN CHECK COOLANT LEVEL ADD MORE UNTIL UNTIL LEVEL STOP DROPPING.PUT RADIATOR CAP BACK ON OVERFLOW RESERVOIR. LET ENGINE IDLE WATCH COOLANT TEMPERATURE GAUGE.WHEN GAUGE START CLIMBING. TURN OFF ENGINE WAIT FEW MINUTES TAKE A LARGE RAG OPEN RADIATOR JUST A LITTLE YOU HEAR HISS NOISE.WHEN PRESSURE STABILIZE DONT GET SCALDED BECAREFUL.OPEN CAP LITTLE MORE.IF COOLANT PRESSURE STILL BOILS OUT WAIT 20 MINUTES ADD MORE COOLANT TO RADIATOR OVER FLOW WHEN COOLANT LEVEL STOP DROPPING.PUT RADIATOR CAP BACK ON START VECHICLE UP LET IDLE UNTIL THERMOSTAT OPEN. THEN FEEL TOP RADIATOR HOSE FEELS HOT THERMOSTAT OPEN WATCH TEMPERATURE GAUGE.IF GAUGE TEMP START CLIMBING TURN OFF ENGINE WAIT A WHILE.CHECK AND ADD MORE COOLANT.WHEN THE ENGINE CAN IDLE TEMP GAUGE STOP CLIMBING YOU HAVE BLEED COOLANT SYSTEM.KEEP CHECK ON COOLANT LEVEL.
Dec 29, 2010 | 1999 Oldsmobile Alero
I have a 2003 Ford F350 7.3 diesel engine,Engine run fine,but only the problem diesel mix with coolant,what could be the problem.
you may have two hoses that hooked into your radiator that help cool you oil. If the radiator breaks down inside than you need to replace the radiator. The radiator probably has four tubes or hoses bolted to the tanks. Two four transmission two for cooling oil. If so you need to replace the radiator and flush out the cooling system and clean out the water jug. Do not wait long cause you could clogg your heater core with oil. and also cause the vehicle to over heat and that is not good for diesels.leave comment
Jun 30, 2010 | 2003 Ford F350 Super Duty DRW SuperCab
I have a leak in the large diameter line leading to my rear a/c on a 2002 e350 7.3l van, behind the left rear wheel. What part do I need to replace?
if the leak is in the hose itself just replace the hose or if it is at the joint then replace the O-ring at the fittings
Jan 02, 2010 | 2002 Ford E350
E350 6.9 diesel rear head gasket is leaking coolant..any magic sealant?
I have used a sealer at NAPA auto parts that works...it cost about $15+, not cheap....I have done headgaskets on that engine...alot of work....but caution.. if coolant leaks into the combustion chamber you can "HYDRO-LOCK" the motor and REALLY have problems, if it doesn't throw the lower end out.....hope this helps ...GL
Jul 06, 2009 | 1984 Ford F 350
Replace thermostat on Ford e350 diesel 1990
follow top hose from radiator to engine, it connects to steel tube with a plat and 2-3 boltshold plate down. sypgon radiator down into clean bucket, remove bolts, take out thermostat, clean both mounting surfaces very clean until only metal showing put in new thermo put gasket on tighten bolts and add antifreeze
Jul 06, 2009 | Ford E-350 Cars & Trucks
Vehicle Parts & Accessories Logo
37 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
