Question about Vehicle Parts & Accessories
311 cdi air-con wiring fault
New condenser fan not working......no power to fan when air-con is on. any ideas?
  • Vehicle Part... Master
  • 2,122 Answers
Hi Muttley, Check the gas pressure in the system. The there is insufficient gas the AC will not engage, nor will the fan work. Regards John
Posted on Jul 21, 2013
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
A/c clutch will not engage after replacing radiator and fan 4.7 03 durango
was air con working before radiator swap out
is the air con fan plugged in
as above no gas in a/ c system clutch wont work
Oct 26, 2016 | Cars & Trucks
Anybody with EDC light troubleshooting chart for benz sprinter 311 cdi
You need to have it scanned with diagnostic equipment to find cause, repair fault & reset ecu
Nov 29, 2015 | Cars & Trucks
Air-con faulty
sounds like an electrical problem check all fuses and ac clutch relay
Jul 20, 2013 | 2005 Mercedes-Benz Sprinter 311CDI
Need belt Fan diagram for a 2000 model mercedes sprinter van
The serpentine belt routing diagram for a 2000 Mercedes-Benz Sprinter 208 CDI, 2.2 liter, 60 kW (82 BHP) OM 611.987 engine code:
1. Without A/C (Air Conditioning) system:
2. With A/C (Air Conditioning) system:
Please do rate my response. Thanks!
Jan 06, 2011 | Mercedes-Benz Sprinter Cars & Trucks
My dodge sprinter 213 cdi with AIR CON though
Over to right pulley (bottom the a/c) then over rider pully to top left pully to alternator to fan down to drive to tensioner
Feb 27, 2010 | 2002 Dodge Sprinter
Have a mistral air con, outside unit not working
there is no fuse on your condensing unit outside. pull the disconnect to kill the power to the unit and take off the removable panel above the 2 service valves. there will be an oval shaped capacitor that is marked herm and fan. there will be a rupture disc on the top that may have ruptured. also inspect the low voltage wiring(will still be hot unless you turn off the switch at your furnace). this low voltage wire operates a magnetic coil on the bottom of the contactor that closes a high voltage circuit to the fan and compressor.
Dec 14, 2009 | Heating & Cooling
LG 3phase ducted CH02 fault (internal pipe thermistor error)- every day. When it comes up the air con shuts off, and takes a few hours to clear itself. Very annoying. I notice though it comes up less if i...
have u checked your low pressure and high pressure when compressor is on. Remember the compressor has a thermal protection switch if the compressor has too much freon the A.C will work for a while turn off, then turn then off and on. Are the air filters for the evaporator clean, is the blower fan blowing the correct way. How long ago did the evaporator coil got cleaned. With a properly cleaned filter and evaporator coil you can now check for pressures. Use your ammeter and check how much the compressor is pulling and compared it to the name plate. How much tons your A.C. If you give me how much tons and low and high readings I might help you diagnose the problem. Make sure the evaporator is clean blower blowing correct way condenser cleaned and condenser fan rotating the correct way
Jul 24, 2009 | Heating & Cooling
SAAB 9000 1995 ACC Stops Working When Car gets Hot
check the relay maybe faulty and overheating
Jun 12, 2017 | 1995 Saab 9000
Volvo v70 air con fault
This is probably a clutch problem on the compressor, either buy a new clutch or get a second hand compressor and swap the clutch over.
Jun 27, 2008 | 1999 Volvo V70
Mitsubishi wall unit srk50zg condenser src50zg air con not heating new install
Double check your wiring .if the indoor fan is not blowing then you either have an electrical issue OR bad blower motor .
May 24, 2017 | Refrigerators
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
