Question about IBM Netfinity 3500 M20 8657 Server
Video controller disabling
How do i disable the video ? for a pci video card? wich jumper? thanx
  • frankie3500 Sep 08, 2007
    this is very ok..
    thanx!
    Problem Solver:
  • 19 Answers
That model server comes with onboard video. If you wish to use a PCI video card then all you have to do is place it in the server and the BIOS will automatically disable the onboard. If it currently has a PCI video card in it, just remove the PCI card and you should get the onboard video again. Hope this helps.
Posted on Aug 29, 2007
Respected Sir, I installed an nvidia 8400gs graphic card a year ago..........it works fine ....then two weeks ago i dusted up my cpu...........i inserted the graphic card then the computer...
It is best to disable the onboard video electrically via a jumper or dip switch on your computers motherboard or in its system BIOS. Please refer to your computers user guide or contact your computer manufacturer for instruction on this process.
In the event that your system does not support the above, you may be able to disable the onboard video card in the operating system using the instructions below.
Make sure that the new PCI video card is not installed in your computer.
Windows XP/2000
1. Right-click My Computer and select Properties.
2. Click the Hardware tab, and then click the Device Manager button.
3. Click View, and then Show Hidden Devices.
4. Click the Plus (+) sign next to the Display Adapters category to expand it.
5. Select the onboard graphics controller under Display Adapters and click Disable. Click OK to confirm.
6. Do not restart the computer until the controller is disabled.
7. Turn the computer off.
8. Install your PCI GeForce card and follow the included instructions from the card manufacturer.
May 14, 2011 | HP Computers & Internet
Respected Sir, I installed an nvidia 8400gs graphic card a year ago..........it works fine ....then two weeks ago i dusted up my cpu...........i inserted the graphic card then the...
Windows XP/2000
May 14, 2011 | Dell Inspiron 6000 Notebook
Everex GA3400 no video, no BIOS splash, nothing. Install PCI card
First look for a CMOS battery on the motherboard. If found, disconnect the battery and also disconnect the power cables from the system.
Wait for about 10 minutes and then reconnect battery.
Turn it on. If it remains same, try to re-seat memory modules and let me know if you get any beep sound when you turn on the system
Feb 18, 2010 | Everex GA3400 PC Desktop
How to turn off the builtin video on QDI Winnex 1E motherboard?
Check your BIOS - there should be a setting in there to disable the onboard video. You shouldn't need to use a jumper to disable this.
Dec 18, 2009 | QDI Group QDI WinneX 1E Motherboard
I tried to install my video card on the Iwill Xp4evo and it doesnt work. Its a BFG Asylum Fx5200 256MB PCI card. Everytime i try to install it, it doesnt work. I dont think its the card because I sent...
make sure to check your bios is up to date check bios to see if all the pci slots are enabled and check
*********** board for a jumper if the system has onboard video sometimes you have to disable the on board video by setting the jumper to disable also sometimes in the bios there is a setting to set default video card to pci just dig around and se what you can find... if all that dosn't work these little form factor systems usualy have very limited amount of power it may be that your power supply may just not be pushing enough to run the card
Nov 03, 2009 | Iwill XP4evo Barebone
I need to disable the onboard video by finding the jumpers on the motherboard (MSI 7191 Version 1.1). When I installed a new PCI card (because the onboard video is broken) the computer freezes up and...
Go to the device manage and instead of disabling it, uninstall it. Then power down, move the cable to the pci port. reboot, when windows brings up the new hardware found, hit cancel until it disappears. Go back to device manager and if it has re-appeared uninstall it again and go about your business.
Sep 06, 2009 | MSI PM8M-V Motherboard
I have an emachines etower 433i with onboard video. I've installed a separate pci video card, but I don't know how to change the jumper settings on the motherboard to disable the video chip. On the...
Go into >my computer>properties>device manager>graphics.You should be able to disable your on-board graphics there. Be sure your computer boots from the new card before you do this.
Dec 17, 2008 | Computers & Internet
Were are the jumpers to disable the on board videofor aopen mx3w pro-E
Why do you need to disable the onboard video??
If you have added a new graphics card it should automatically select this new card.
If it doesnt, you can go in to the bios and disable the onboard graphics card from there.
For example, Onboard graphics can usually be refered to in the bios as PCI, so if you've added an AGP card or PCI-E card then you would just need to select either one of these from the bios menu.
Not sure what bios your using but it may even have ann option to disable onboard graphics.
Oct 23, 2008 | AOpen MX3W Pro-E (91.88210.241)...
HOW TO DISABLE MY ONBOARD GRAPHIC CARD??
For user BIOS21 & julio1963,
How to enable you're (Add-in AGP video card) & disable the onboard, integrated S3 graphics UniChrome 2D/3D PCI graphics card.
Enter you're bios. Open you're user manual to page 3-13. Integrated Peripherals. Go to, Init display first. Set to AGP.
(Not to PCI). That is all you need to change. The MSI bios will than see you're add in AGP card & automatically disable the PCI S3 graphics, (Onboard) card.
Enjoy!
If I can help you further, feel free to post here.
Please, each user's vote this issue as a fix, if this helped you to get you're bios to see you're new AGP graphics cards.
Mike
May 31, 2008 | MSI KM4M-L Motherboard
Motherboard bad video
You don't need to disable the on board video chip to use the PCI video card. However, if you do have a problem that relates to disabling the on board video chip, you can edit those settings in the BIOS.
Feb 25, 2008 | Texas Instruments (97988030001)...
IBM Netfinity 3500 M20 8657 Server Logo
322 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
