Question about Amcor ALTL-12000E Portable Air Conditioner
Where is the condensation pan on the amcor alp 12000E?
5 Suggested Answers
carlsbiz
  • 1124 Answers
SOURCE: WE HAVE AN AMCOR ALD 12000E AND THE CONDENSATION
That can be quite normal.. Depending on how much humidity there is in the air..
Posted on Jul 22, 2009
  • 36 Answers
SOURCE: my vent is too short
Try to extend the pipe using a pvc pipe or, some sort of pipe.use alluminum tape that you can get at your local hardwhare store to seal the crack in the pipe that you use to extend..
Posted on May 27, 2010
hammondskeit
  • 46 Answers
SOURCE: Amcor PCMB-12000E Portable Air Conditioner
you can get a part from any suppies store that sells a/c equipment ... some requier epa license .. but something like a fan u can buy that without a license ..
Posted on Jun 28, 2010
  • 3074 Answers
SOURCE: dont know how to empty portable ac amcor AF 12000E
sound like the drain plug needs to be removed
Posted on Jul 22, 2010
Override temperture setting on Amcor Amc-12000e portable Air Conditioner
Actually there is no way to do what you want because the unit is designed to operate when the inside temperature allows the heat exchanger to function so that it will condense the liquid refrigerant into a gas.
As far as using it in the winter to dehumidify this same applies. If it is to cold then the gas won't be able to condense back into a liquid. If I were you I would buy a portable dehumidifier but remember that if the temperature is to low it won't work.
Good luck
Marty
Mar 01, 2014 | Amcor PCMB-12000E Portable Air Conditioner
I have an AMCOR ALTL1200E, fan works, cold air comes out when the compressor turns on BUT after 5 minutes compresor turns OFF, then after 5 minutes again it turns on, what is wrong, thanks
Sounds like the unit is cycling off on a high head pressure (condenser coil too hot). When the condenser cools, the automatic switch resets. The unit cuts off again when the condenser heats up again. Clean the condenser coil, and clear out any debris (bird's nest, lint etc.)
Aug 30, 2013 | Amcor ALTL-12000E Portable Air Conditioner
When i turn it on it shuts off and the power button flashes red
Sounds like the condensation pan is full and the float switch is shutting the unit down. I just encountered this issue, there is a small pump that usually prevents the pan from filling up by pumping the condensate over the condensor and evaporating it, either the pump has failed or the humidity is too high and it can't keep up.
May 24, 2012 | Amcor ALTL-12000E Portable Air Conditioner
I have a AMCOR CPLMB 12000e A/C that runs but doesn't cool. Where can I get it fixed?
KD Grayson Heating & Air Conditioning
916-640-6693
Always a flat rate for a diagnostic $29 Anytime Any day! 9e28e716-b18a-414a-86c2-4e8057e9d403.png
Aug 30, 2010 | Amcor Heating & Cooling
Amcor PCMB-12000E Portable Air Conditioner I need to replace the motor on the lower fan for my air conditioner, can anyone tell me where I can get a new one?
Jun 28, 2010 | Amcor PCMB-12000E Portable Air Conditioner
My vent is too short on my amcor model ALTL 12000E portable ac
May 27, 2010 | Amcor ALTL-12000E Portable Air Conditioner
Unit not cooling
  • i think you should have someone with a/c refrigerant come out , it doesn't sound like it's the board because if it was the board it wouldn't do anything . if it isn't cooling then it is a refrigerant problem or a compressor .. if it's a refrigerant problem it's a e-z fix but if it's the compressor, then it may need to be replaced . and sometimes replacing a compressor with the labor and the money for a compressor it might be best to buy a new unit . i see u said u cant afford to buy one .. but if i was u - i would atleast get a second opinion .... i would help u but i live in maryland ...
May 22, 2010 | Amcor ALP 12000EH Air Conditioner
Amcor ALTL-12000E Portable Air Conditioner Logo
23 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Bill Long
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
