Question about Boating
Gme gx300 transmitting problem
The unit on my boat occasionally transmits a buuuuup and other times not. I have tried changing the mike, worked for a bit then did the same. Seems to be worse if I speak straight into the mike but not always. Regards, Tim
    Champion:
    New Friend:
  • 227 Answers
Do you have a mike filter on your system
Posted on Dec 19, 2013
4 Suggested Answers
SOURCE: Freq change GME GX300 from 27Mhz to 29Mhz
Hold down the 88/pri and the DW buttons while switching on the radio into programming mode. You'll then need the programming soft and hardware to read the radio., add the 27mhz channels and write it back to the radio. The GX300 can only store additional freq. in the p1-p0 modes
Posted on May 05, 2010
aloha27
  • 696 Answers
SOURCE: With engine running on boat, radio transmitts with
This is almost always caused by a poor ground. I would suggest you run your ground wire (larger the better) back right to the negative terminal of the battery.
Hope this is helpful.
Posted on Sep 09, 2010
SOURCE: I have Icom2200h vhf radio in my truck i have to
hi,where is the button to change the light from amber to green 2100H
Posted on Feb 07, 2012
Gme tx3420 no transmitting
most likely an old battery replace your battery and you will be able transmit.
Mar 31, 2014 | Radio Communications
GME TX3340 not transmitting
You may have a bad microphone, not uncommon problem.
Apr 18, 2012 | Computers & Internet
My galaxy 959 sqeals and does not receive or
mike has wiring problems. Check for breaks in cord and where the plug goes into the unit. If not original mike then has incorrect wiring for the radio and will need to be changed for config
May 01, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
Radio will "receive" but not "transmit". Radio, antennas, and wiring are all less than two years old. Should I try a new mike?
Firts you have to check for carrier.For this you need an swr meter.2) Check continuity between the pl259 tip and antenna.3) Check for modulation (voice) if all of the above are OK. 4) Check if your display changes to transmit when you press the mike. IF all fails,then try another mike.
Jan 27, 2010 | Cobra 29 LTD CB Radio
Cannot communicate on radio
You almost certainly have a bad antenna connection. Try re-soldering the PL259 connector. Do not transmit until you have at least got weather reception.
Jan 13, 2010 | Boating
When i click the mic i get no transmit
If the receive works ok,sounds like a mic
problem,try another mic if you can find a
buddy who has a Cobra that may let you
try it most all Cobra mic will work but not all.
Good Luck
Sep 08, 2009 | Cobra 29 LTD CB Radio
Sep 05, 2009 | Boating
SSB radio
If you are using the radio on a boat, then no, the grounding does not matter that much. However, an SSB transceiver would be hassle to install on a boat because of the amount of power they use to transmit. If the transmission is bad, try using the radio's internal tuner instead of the separate tuner. This may help improve the quality of transmit, however, some radios have a tough time clarifying incoming and outgoing signals and create a garbled sound when it receives a signal or when it transmits. If that doesn't work, then you can try grounding. But if you want a radio that doesn't require all this nonsense tning, you might want to think about investing in a Yaesu. They are pricey, but are one of the best HAM radios.
Sep 04, 2008 | Ranger TR-696F SSB CB Radio
Motorola Talkabout T6500 will not transmit.
Are you sure the batteries are ok?, try to change the batery, check the radio battery contacts, verify if when you press the ptt, appear an icon on the display that correspond to TX function. Try to use an audio accesory to TX, if all this fail, you should replace it. Good luck
Jan 20, 2007 | Motorola Talkabout T6500 (7 Channels)...
Boating Logo
144 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
