Question about Acer Veriton Computers & Internet
Replace ethernet card - Veriton Acer Computers & Internet
    Genius:
  • Acer Master
  • 1,479 Answers
If you pick up a network card from your local pc store, you can either remove and replace your existing one (if it is removable) or just insert it into one of the spare slots on your motherboard after removing the blanking plate.
Posted on Jul 19, 2013
Ethernet port not functioning after lifghtening strike
Ethernet port not working after a lightning strike? Then I suggest obtaining an inexpensive Ethernet adapter card, and installing it.
One example of an Ethernet adapter card, (Ethernet Card, Networking Card - Same/same),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1275962&CatId=200
The above Ethernet adapter card is a PCI style of adapter card. It plugs into any available PCI expansion slot on the Pavilion a620n's motherboard.
This is an illustration and photo of the Pavilion a620n motherboard from HP Support,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00069442&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&site=null&lang=en&key=null&product=424215
Scrolling to the middle of the page shows first the illustration, then the photo.
In the motherboard photo the three white long expansion slots on the bottom of the motherboard, are the PCI slots.
On this page is information on how to open the computer case, and replace, or install an Ethernet Card,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=424215&
Click on ~ HP Pavilion PCs - Upgrading and Servicing Guide
This is a PDF file. You may have to allow up to 30 seconds to see the first page, and additional time for the file to fully download.
[Removing and Installing an Add-In Card is information on how to remove, and install an Ethernet Card. An Ethernet adapter card is an Add-In Card]
For additional questions, and/or clarification on what has been stated please post in a Comment.
Regards,
joecoolvette
Apr 30, 2011 | HP Pavilion a620n (PC028A) PC Desktop
The pci ethernet card tp-link is crashing the startup process with windows 2000 and damages the boot files
Try and replace the ethernet card or try and start it up without the ethernet card present. If it works you know its sucessful then the Card is faulty
Jun 08, 2010 | A-Trend ATC 6220 Motherboard
Lightning struck and took out my dell ethernet card adapter? Is there anywhere I can buy one to replace it?
Yes you can buy a replacement Ethernet card from any electronic or computer store near you and they are pretty cheap now...
Dec 16, 2009 | Dell Ethernet Card Network Adapter
Replacing ethernet PCI card 10/100 by gibabit 1000
When you replace and install LAN card you need to install also the driver. Be sure that your onboard ethernet PCI card are disabled in BIOS. So that the new install LAN card are working.
Regards
PCmania
Sep 26, 2009 | Dell Ethernet Card Network Adapter
How to replace ethernet card on hp pavilion a706n, it looks like it is built in to the motherboard, can I just buy a replacement and put in one of the empty slots??
It is buillt in however if you have a spare PCI slot on the motherboard you could fit another ethernet card which would override the built in one.
Sep 14, 2009 | HP Pavilion a706n PC Desktop
Will not come on and the network light is allways on
hi,
u can try unplug your network card and re-plug it back.
hope this will help.
Sep 11, 2009 | Acer Aspire L100 PC Desktop
My Ethernet card doesn't work on my n845wn Intel
It's possible the drivers are not installed.. To check if drivers are properly installed for the Ethernet card, if you have win XP
* go to Start>Control Panel>System> click on Hardware tab, then Device Manager
- once you're on Device Manager, look for network adapter, you should see something like "Via Rhine II Fast Ethernet Adapter", this is just an example, you may have a different brand of Ethernet adapter
- if you can see the Ethernet Adapter and it has a green icon beside it, it should be working fine, you can also double click on it, to view the Status
- if you don't see the Ethernet Adapter on the list, look under the section "Other Devices", if you see an "Ethernet Controller" on the list with a yellow exclamation point, it means the drivers for the Ethernet Adapter were not installed, which means the drivers has to be re-installed
- you need the manufacturer cd for the drivers
*Now if there's no "Ethernet Controller" on Other Devices section, it's possible the Ethernet card is not being detected by the computer
- you may have to unplug the Ethernet card physically from the computer (computer must be completely turned off) then try to insert the Ethernet card again and boot up the computer, if the computer detects the Ethernet card, you need to install the drivers
- If the computer doesn't detect the Ethernet card, most probably it's busted. You may have to replace it.. You can also try to install the Ethernet card on a different computer just to check if it's really the Ethernet card or the motherboard that's the problem..
May 10, 2009 | Intel Desktop Board D845WN Motherboard
Questions about replacing ethernet card on my Dell desktop
Any ethernet card will work fine. Just be sure it's the fit's the correct slot. You probably have a "white" slot which is a pci slot. If it's a longer "black" slot then it's isa. More than likely it came from a pci slot. Before you buy one, confirm the type of slot. In additon, before installing it go to control panel and system settings, hardware, device manager and remove the old one by right clicking it and select delete or remove. Shut down the computer follow instructions for new card.
Probably will have to install the drivers first then shut down and install the new card. Good Luck.
Apr 17, 2009 | Dell Ethernet Card Network Adapter
Replacing an ethernet port on my hp pavillion
Your ethernet port is probably integrated into the motherboard of your computer. Have you tried reinstalling the driver for the ethernet?
If the port is truly bad, my suggestion would be to purchase an ethernet card or NIC (Network Interface Card) and have it installed. You can get them for $15 to $25 at any big box computer store.
Nov 04, 2008 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
