Question about Toshiba Satellite Computers & Internet
Toshiba equium p200 laptop my screen is very erratic.. do i need new screen,or ribbon please ?
  • 60 Answers
SOURCE: Master Reset
Are you just looking to completely erase your hard drive (delete all files from your computer)? If so, try Active@ Kill Disk - it's free. Use directions for Booting from a Floppy Disk if your computer has a Floppy drive or Booting from a CD if you'd rather use a CD.
http://www.killdisk.com/downloadfree.htm
Hope this helps! : )
Posted on May 28, 2008
  • 29 Answers
SOURCE: Toshiba Equium L20 Laptop crashed
Hi Hneybee, i've looked every where and found nothing of a free recovery disc for your machine, seems every one wants something for really nothing. All i can recomend is get in touch with toshiba in your country and see if they will supply you with one (even if you have to pay for it).
But keep in mind there might be a bigger problem with your laptop as for it to crash like that. I should be able to help you but first you'll have to get a cd to boot up. When you do give me a email and i'll help ya out. Good luck JLS jeff-smart@hotmail.co.uk
Posted on Oct 21, 2008
  • 256 Answers
SOURCE: i need to reboot my toshiba equium l10-300 laptop with no cd
Try starting in safe mode. Hold down oth the control and F8 kays and press power. Do not release Contro & F8 until it starts to beep. Then it shoud start in safe mode. If the computer will not start in safe mode you have a hardware problem. If it starts in safe mode, you have a Windows problem that re-installing Windows will solve that (to a point). Without the Original CD and install code, you have two options. Buy a new OS or.......pirate it. I do not recommend the last.
Posted on May 28, 2009
  • 7 Answers
SOURCE: Replacing screen on my toshiba equium a100 306
this is not the same model but i think you will get the idea.
http://www.fonerbooks.com/laptop_5.htm
Posted on Jun 17, 2009
  • 232 Answers
SOURCE: touchpad on toshiba equium A200-1VO laptop not working
you have lost your driver for the cursor .
go to :
  • www.toshiba.com/taecdpd/support/drivers.shtml
  • this should have all the drivers required for your PC .
    give it a try and let me know how you go
    Posted on Sep 30, 2009
    I have a Toshiba Satellite Pavilion P200 laptop. I recently purchased a replacement battery however the replacement will only charge to 99%. Any suggestions please?
    New recharageable batteries need to be charged overnight and fully discharged several times before they reach their full charge capacity.
    Mar 14, 2012 | Toshiba Satellite P200-0TD00Y Notebook
    Equium 100 PC Desktop: my sscreen has rotated on my Toshiba EQUIUM A100-0...
    hold ctrl+alt and press the up or down key to change the screen to its original position
    May 05, 2010 | Toshiba Equium 100 PC Desktop
    Toshiba Equium A100-02k laptop black screen
    sounds like it could be the monitor itself
    Apr 02, 2010 | Toshiba Equium 100 PC Desktop
    I need to completly rset my toshiba equium p200 i have no disc
    If you want to restore back then you should have a recovery partition to check it press F10 when you turn on the system. If you have the recovery partition it will take you in and from there you can select any recovery option. (destructive or non destructive)
    If there is no recovery partition on the system then you need a disc which you can easily get by calling toshiba it will cost u around $12.
    Mar 21, 2010 | Computers & Internet
    How easy is it to replace a keyboard on a toshiba EQUIUM P200 1IR laptop?
    Most laptop keyboards are 'snap in'. At one edge, normally the closest to the space bar, there will be two or so tabs that fit into notches in the bezel surrounding the keyboard. You have to pry the tabs from under the notches towards the display, and then carefully lift the keyboard up at the close edge. You will then find a ribbon cable [flat, likely clear flexible plastic with copper colored traces 'painted' on] that connects the keyboard to the mother board. Generally they have either a push on connector that you have to release to take the tension off the connections, or a simple press-in connector. The first type has a squarish piece that you can slide away from the body of the connector to release the pressure. It will move about 1/16 of an inch, and stop. It should stay on the motherboard connector. If you release it, the ribbon should pull out easily.
    Replace by re-connecting the ribbon cable, placing the rear of the keyboard into its slot, and snapping the keyboard under the front edge.
    I take ZERO responsibility for any damage you cause by following these instructions as they are 'generic', not specific to your computer.
    tom
    Dec 20, 2009 | Computers & Internet
    Laptop camera doesnt work
    Please make sure that you have installed proper driver software for your camera. Please goto this link to download the drivers to your computer and when the download is complete please open the downloaded file and follow the on screen instructions to proceed with the installation.
    for Windows Xp, http://support1.toshiba-tro.de/tedd-files2/0/webcam-20070809133519.zip
    For Windows Vista, http://support1.toshiba-tro.de/tedd-files2/0/webcam-20071108170647.zip
    I hope this will resolve your problem, Please do rate my solution.
    Regards, Rashid.
    Oct 28, 2009 | Toshiba Satellite P200-0TD00Y Notebook
    I have a toshiba laptop equium L40wont turn on
    i suspect 2 causes of it 1.broken AC 2. OR damaged motherboard
    Oct 07, 2009 | Computers & Internet
    Laptop equium l10
    Hi, My Name is Henry. I am one of the technicians here.
    You need to upgrade your bios. Go to the http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
    click download and follow the instructions.
    NOTE THAT YOU HAVE TO BE VERY CAREFUL WHEN UPDATING THE BIOS BECAUSE YOU COMPUTER MAY DEVELOP MORE PROBLEMS IF YOU DO IT WRONGLY.
    Please do not forget to rate my solutions to you.
    Regards
    Henry
    http://www.clickpcrepair.com
    Mar 17, 2009 | Toshiba Equium 7100S PC Desktop
    @ KEY NOT WORKING
    if one key on the keyboard no longer functions, try an external keyboard. It the external keyboard works normally, replace the built in one
    Jan 18, 2009 | Toshiba Satellite A100-S8111TD Notebook
    Computers & Internet Logo
    24 people viewed this question
    Top Toshiba Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
