Question about Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls
Door will not lock to start washing machine - Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls
  • Official Brand Answer
  • 4,342 Answers
Good Morning Michael, I understand that your washer door will not lock and it is inoperable. Let's try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately 2 minutes and turn on the washer. Select a normal cycle and verify if the washer will start. If the appliance will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. I would suggest contacting an experienced service technician to determine the precise cause.
Posted on Jul 22, 2013
My washing machine will not lock to wash i have replaced the locking mechanism assembly and the lock lid light just blinks and click near the computer board what els should i try please jelp
How to fix a washing machine door lock in a Hotpoint ...
? 4:21
https://www.youtube.com/watch?v=p14EEa4AYGM
Jun 4, 2010 - Uploaded by eSpares
For all your washing machine spare parts go to http://bit.ly/1828iPF In this video, ... How to fix a washing machine door lock in a Hotpoint washing machine ... How to open a washing machine door that won't open normally.
Door makes clicking noise and won't lock or start - Kenmore ...
https://www.ifixit.com/.../Door+makes+clicking+noise+and+won't+l...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock the lockand switch assembly might be defective. This is a very ... The Kenmore Elite HE3 is awashing machine by Kenmore. ... Preview my answer. Post my ...
washing machine wont work. the door will not lock to start ...
www.shopyourway.com > Manage My Life > Questions
Manage My Life. washing machine wont work. the door will not lock to start the cycle. all the lights still ... Kenmore HE3T front load washing machine will not start.
How to Fix Washer That Won't Start ' Washing Machine Repair
www.partselect.com/Repair/Washer/Will-Not-Start/
Read on to learn how easy it is to fix the washing machine yourself... ... found on front load washing machine is the door switch and the door lock and strike.
Jan 23, 2016 | Washing Machines
THE DOOR WON'T LOCK THEREFORE THE MACHINE WONT START
Washer Door or Lid Won't Lock - Repair Parts - RepairClinic ...
www.repairclinic.com/...Washing-Machine/...---/Washer-door-or-lid-wo...
Most Frequent Causes for Washer door or lid won't lock. For the most ... Once thewasher door is closed, the washer can begin operating. If the door lock is ...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock thelock and ... The Kenmore Elite HE3 is a washing machine by Kenmore.
Front Load GE washer won't lock / start. ' ShopYourWay
Front Load GE washer won't lock / start. ... Based on your symptom and details it could have a faulty door lock assembly ... GE Washing Machines 3.8 cu. ft.
Washer Won't Spin or Agitate? Washer Door Latch ...
Dec 13, 2015 | Washing Machines
Bosch Maxx6 washing machine. Shut door,rinse button flashing but door not lock so start button will not start circle
look at the place where the lock locked in the door the metal pinns could be broken or covered with erosion or something. De door lock makes no contact with the receptor.
Mar 04, 2015 | Bosch Washing Machines
Washing machine will not start / door will not lock
check first the thing on your door moves ok this the bit that locks in if ok then it may be your door lock
Dec 28, 2013 | Bosch Washing Machines
Error code " du "
DU = Door Unlock code
Washing machine displays error code F/DU after six attempts to unlock.
-Door lock assembly failed.
-Test door lock switch
-Visually inspect wire harness connection on CCU, Door lock assembly, replace door lock assembly.
The door lock assemble on this washing machine can be replaced from either the top of the front. The door boot can be removed or the top of the washer can be removed.
Hope this helps.
Jun 22, 2011 | Washing Machines
GE Washer, Model GBVH5140HWW. Door seal failed and water in washing machine leaked into the base of the washing machine. Removed the front panel, replaced the door seal, dried up the water in the machine...
The seal is likely not installed correctly. What is happening is the latch for the lock is trying to hook and it is being blocked so it doesn't actually lock. After so many tries the machine goes into an abort mode where it washes out all the water and stands by for it to be fixed. If you put some pressure on the door (closing it) while it is trying to lock, it likely will lock and then run. It is basically an adjustment issue. It is also possible that something with the lock mechanism is broken or out of adjustment causing the leaking to begin with and that is actually the area that needs attention rather than replacing the door seal. Door seals rarely fail unless they are physically damaged somehow.
Jun 02, 2011 | GE WSXH208A Front Load Washer
My washing machine wont start. The door lock
You will have to replace the door lock wax motor.
May 21, 2010 | Hotpoint Aquarius WF220 Front Load Washer
My washing machine door doesnt lock properly
its most likely your door lock if it is malfunctioning the washer will not work
Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
I have a bosch washer model wfk2401. i cannot get
door lock mechanism must have jammed in open position. unless the door gets locked, the wash cycle would not start. check the electrical connection in the door lock and physically verify the lock operates when commanded
Mar 19, 2010 | Washing Machines
Door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Feb 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Electrolux EIFLW55HIW Front Load Washer with IQ-Touch Controls Logo
41 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
