My aqualtis AQXXF 149 PI, blows the plug fuse at the start of any wash cycle i put it on?
2 Suggested Answers
MsMithra
  • 79 Answers
SOURCE: Hotpoint Aqualtis AQGF 149 Error F-05 what does this mean?
F-05 means service switch jammed.
Hope this helps. =)
Posted on Oct 10, 2009
How to change noisy bearing on Ariston AQXXF 129
inner and outer drum has to b removed replace the bearing kit 2 bearings one oil seal as kit
Aug 25, 2014 | Ariston Technologies Washing Machines
Door wont unlock
Some of these machines have a door lock that dose not unlock for a min. or two after wash is done. If so try the door now & it should open.
Jul 15, 2014 | Washing Machines
WHAT IS F12 IN A WASHING MASHINE ARISTON AQUALTIS AQXXF 129 H?HOW CAN I FIX IT?
F12 SPECIFIC FOR LVB2000 INDESIT EVOLUTION / DIALOGIC.
F12: Lack of Display card-Main Card Communication
1. Check the effectiveness of contacts on CNC Connector Card
2. Overhaul 8-way connector on Display card
3. Check continuity of CNC-CN 8 way connector
4. Replace Main Card
5. Replace Display Card
Dado
Apr 24, 2014 | Ariston Technologies AWD 129 NA Washer/...
Error code 07 on my Aqualtis AQXXF
Might be a bit complex but this is your problem and solution
REMEMBER TURN THE POWER OFF
F07: Heater relay stuck or element open circuit
This fault is only signalled when pressure switch is in empty position.
Check the efficiency of edge connector J3 on module.
Check wiring to heater and continuity of element (25 ohms approximately).
Check the efficiency of pressure switch connections and correct operation of pressure switch,
and the pressure chamber is not blocked with sludge.
Remove edge connector J3 and check wiring and contacts at positions 2, 3 and 4 on J3.
If all above OK replace pressure switch, module or eeprom as required.
Jun 10, 2009 | Washing Machines
Brand new Hotpoint AQXXL 149 PI died a death after 10 mins!
This is joyce
Please do not try to work on anything that is new it will void your warranty, call your technician call where ever you bought it from and tell them you dont want this item its not working for you. usually they will replace or get you help quickly
thanks
joyce
Feb 07, 2009 | Washing Machines
Faulty washing machine
if its no heat there only 2 items it can be heater element or the thermostats u could test the element by replacing the plugged in wires with wires that hasve a plug on place the wires into right places turn the plug on and if the element works it will start to glow turn it off as soon as u see it glowing from the inside of the washer also u can check the thermostats by dropping them into hot water and u should hear them pop
Nov 18, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
