Question about Frigidaire Dishwashers
Frigidaire PLD4555RDC2 Runs when not started after power outage
Yesterday we lost power. When it came back on, the Low light was on, which I wasn't concerned about because I assumed it would go off after a few cycles (we don't use a rinse agent). However, ever since then, if we close our dishwasher all the way, it starts running. We don't have any cycle selected and haven't pressed start. It just starts as soon as it clicks shut. Can you help?
  • Official Brand Answer
  • 4,342 Answers
Hi Emily, I am happy to assist you. First, I suggest reprogramming the dishwasher. This can be done by either flipping the household circuit breaker off or unplugging it. Sometimes, resetting power to the unit for about ten minutes does the trick. If not, you may want to connect with a local servicer who will be best equipped to pinpoint the problem since the unit could possibly be experiencing a communication issue with the control board and door lock assembly, a potential wiring failure or a faulty door latch. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
Posted on Jul 22, 2013
  • 44 Answers
SOURCE: my dishwasher shuts itself off
The lights will typically blink when the door comes open. It may be that when the washer warms up, parts of it expands and allows the door to open slightly. It may also be that the trigger that registers the door being shut is not being tripped.
Posted on Sep 14, 2007
SOURCE: Dishwasher only runs in rinse only mode!
my dishwasher just keeps bleaking clear AND NO WATER IS GOING INTO THE MACHINE IT JUSTS KEEPS RUNNING BUT THEIR IS NO WATER COMING IN.
THANKS
Posted on Nov 18, 2008
RepairClinic
  • 32 Answers
SOURCE: Frigidaire PLD4460REC Dishwasher will not start
This is very likely due to a bad main electronic control board but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Posted on Feb 03, 2009
  • 3 Answers
SOURCE: dishwasher, flashing lights, frigidaire
The steam has gotten into the keypad display and fried it. Call Fridgidaire and let them know you've seen numerous people on the internet with the same problem and that you need part# 154554401 It worked for me.
Posted on Apr 01, 2009
  • 4 Answers
SOURCE: Frigidaire Dishwasher FDB956RBC0
I successfully replaced the broken handle for my ELECTROLUX 24" Built-In DISHWASHER Model FDB956RB.
Try to check to make sure you reassembled all the parts and wire connectors properly.
Other than the broken handle, did you have other problems prior to replacing the handle/latch?
Posted on Nov 28, 2009
Hotpoint refrigerator won't stop running
The temperature sensor could be at fault
Mar 26, 2013 | Refrigerators
Frigidaire ffu1767fwo (power spike) does not turn on can it be fixed
Hello tom97420 - Was the freezer unplugged during the power outage? It is best to be unplug unit and wait for the power to come back on, turn control to off, plug the unit in and reset control to factory suggested setting. Do not open freezer door unnecessarily if freezer is off for several hours. Make sure the freezer plug is tightly pushed into electrical outlet and not plugged into a GFI. Is the temperature control in the OFF position? Set temperature controls to proper setting suggested by owners guide or set to the halfway point and adjust it up or down as needed. If any suggestions are ineffective, contact a professional to move forward accurately. From what you have described the power loss could have possibly caused a communication problem with the control board, temperature control or wiring harness.
Oct 24, 2012 | Frigidaire 16.7 cu. ft. / 473 liter...
Yesterday we had a power outage. When the power came back on, my TV would not work. The green light on the front just keeps flashing quickly. I tried unplugging it, and I unhooked all devices from it as...
Thats caused by weak capacitors on the DM board. They drain when the power is lost then they cant recharge after power is restired. You can get the dm repair kit for your model at www.tvrepairworld.com it contains the repair instructions and the upgraded caps plus other service info on the cd
Jun 07, 2011 | Mitsubishi Televison & Video
Stopped working after power outage
If you cannot fix - too expensive or whatever - consider a replacement with a five year 100% parts and labor warranty and in-home service. Imperial (made in USA) is the only range hood manufacturer that offers this. More information here: www.vent4less.com
Regards,
Donald
Jul 12, 2010 | Frigidaire (PL36WC40EC) Stainless Steel...
Printer won't turn on. had power outage yesterday. now printer won't turn back on. have power to receptacle.
Sounds like a bad low voltage power supply.
You can google a business called The Parts Drop and contact them.
Dec 08, 2009 | Xerox WorkCentre M15i Laser Printer
Power won't stay on although there is electricity. If i reset, the power light comes on, but only for 2 seconds- the fridge is now 60 degrees. We lost power yesterday afternoon- could this have fried it?
After a power outage and possible power surge it is very probable serious damage was done. Worst case senario being a grounded compressor. I know of nothing you can do yourself. Time for a service call.
Oct 10, 2009 | Electrolux Refrigerators
Frigidaire side-by-side stopped working
I would chech the components on the compressor. Take the cover off the compressor power terminals and inspect the relay for damage.The power outage is not a concern but the power surge could definately be the cause. hope this helps.
Jul 28, 2009 | Samsung RS2578BB Side by Side Refrigerator
Power outage
I would say that is not a feature, it's a problem. Sounds like the control board has no battery backup of any kind to retain settings in case such an outage occurs. If still under warranty, have it fixed. A refrigerator should be trusted to be left unattended, if this has been this way from new, you should have complained the first time it happened. If they say that it's in the design and all of these do this, perhaps there's a class action waiting to happen.
Please leave comments and check back in, e-mails may not be working after this reply.
Jul 27, 2009 | Frigidaire Freezer FFU1764
After a power outage yesterday, my 24" Pure Flat Tube Stereo TV (TTM-2420) is not receiving power. (the glowing light on front of TV is not on and the TV cannot be turned on) I don't know how long power...
Surge protectors are meant to trip whenever an outage occurs to prevent component damage. If possible remove back panel and check if any fuses were burned. If all looks normal then your component is most likely fried.
Jul 05, 2009 | Televison & Video
Won't charge after the battery runs low.
that means your battery is flat so first boost the battery using universal charger or in other way charge you battery directly
Apr 08, 2017 | Sony Ericsson XPERIA X1 Smartphone
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
