Thermastat I have dial type thermastat that sticks out from the wall 1-2 inches. It is located smack dab in the middle of a main wall in my living room, it is an eye sore. Is it alright to cover it with something as long as there is room behind what I cover it with? Or will this cause problems. Right now we are not using heat or air, and what I have hanging there is a metal art piece. Or what other options do I have? Thanks Dana
    Problem Solver:
  • 15 Answers
Hello Dana. Will covering a thermostat affect its performance? Yes, almost certainly - it needs a clear flow of air to it so that it can constantly monitor the room temp. It really depends on how much it's covered by whatever you plan to place in front of it. I guess your options are: (1) move the thermostat (obvious, I know!). Cost will depend on how easy it is to re-route the cable. (2) fit a flush-fitting and more attractive unit - check out the 'Heatmiser' for an example (3) cover it and see what happens! It won't actually harm the unit (well, it shouldn't...), but will probably make the temp swings more obvious before the thermostat 'clicks in'.
Posted on Aug 28, 2007
    Problem Solver:
  • 16 Answers
Unless you damage the thermostat in someway, covering it is a non issue. Because it is an electrical device you will still want to have easy access to it, so don't do anything too permanent! OPTIONAL: I recommend that you disconnect this device at the power source (usually its own breaker/fuse) just to be safe.
SOURCE:
When turning on my bravia 32 is all black and then lines in color appear and then black again
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 22, 2014 | Sony Bravia KDL-46HX729 LED Internet TV...
Need to see a giagram of the hood lock. my cable broke & I need under the hood. I have to break-in.
need to reach way up behind the grille assembly and trip the mechanism by hand..may need to remove any plastic air dam thats below the bumper to do this..sometimes you can use a long blade screwdriver at least 8 inches long to reach back that far and trip the mec hanisms' trigger release..the mechanism is smack dab in the middle of the grille area but the release is to the right of it some(normally)
Feb 12, 2013 | 1998 Chevrolet K1500
How to decoration Living room will look good?
The importance of the living room in a house is self-evident, the basic style of a living room is the keynote of the whole family, and also the best place to entertain friends and family . Different living room suitable for different groups of people, young people like active and stylish. Middle-aged keen of dignify and deep. Elderly suitable for classical and nostalgic. In short, there is always a right for you.
Living room with a colorful and old-fashioned fireplace or retrofit TV cabinet. In addition, the carpet of colorful rectangle filling compared to the living room adds a lot of modern feeling. Tobacco basket, licorice fork, folding beds decorated on the wall, gave the entire living room into a rural sense. Built-in bookcases used for storage, sofa platform for display decorations, and leather sofas will make the living room look full business sense.
Dec 21, 2012 | Dryers
How do I gain access to the fan which is located on the inside of the unit of a split aircon, the unit which resides inside the house. Need to pull this part out off the unit to clean it. Thanks
is this a split system on your wall or a cassette(a square unit in the middle of the room) like in the picture? units on the wall are very annoying to get out and if you do you will probably brake it. best to just turn of the unit and whip and spin whip and spin with a long brush or stick with a cloth on it.cassette units you unclip middle filter plastic panel then theres a fan use a shifter to undo ?
Oct 29, 2010 | Cfm Daikin R410a Split System Air...
My car dosent like to start. It fires up and then dies
Sounds like you have heat soak. Is it not wanting to turn over when it is warmed up? If so then it is your starter.
The fuel filter is smack dab in the middle underneath the car. Mine was under a heat shield for the exaust. The fuel pump is in the tank and is only accessible by dropping the tank.
Mar 15, 2009 | 1991 Pontiac Grand Prix
I am living in a home with a carrier furnace. The furnace is in the back part of the house in a store room. It has two- 2 1/2 inch plastic pipes. One that suppplies air to the furnace and the other is...
As long as the fresh air intake pipe to the furnace is not plugged up the second vent is not needed some homes when they are new are air tight and need a fresh air circulation system
Oct 30, 2008 | Carrier Heating & Cooling
Mitsubishi VS-60603 60 inch Projection TV
You would have to completely take the Mirror out or Mylar backing and being careful not to damage anything, trying to move and reassemble when you get at the new location.
Dec 05, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
