How do I open a Digidoor II when there is a power outage?
  • Hennie Broodryk Sep 08, 2013
    Yes very easy to fix that problem. Just get a cheap Computer UPS and put it inline of your pwer supply. Problem solved. Theres enought power in the UPS to open & close ypur garage door about 5 times. Till the outage ahs restored.
  • Paul Rose
    Paul Rose Dec 12, 2013
    I have new UPS supply but it only last 7 -10 mins even without use before it is has run down and has no power left?
    Genius:
  • 1,479 Answers
Not sure how us computer geeks can help you with your garage door.
Posted on Jul 19, 2013
Can i fit 12v battery backup for digidoor 11 to open when there is loadshedding. My digidoor2 had the extra consoke for remote receiver
Nope, Digidoor II has no battery backup. You need to invest in a UPS or replace the motor.
Digidoor one, Digidoor III and the Digidoor IQ all have build in battery backup.
__________________
Reference:
http://www.4x4community.co.za/forum/showthread.php?t=142874
Jun 13, 2015 | Computers & Internet
How do I get a free service manual for digidoor 24 garage door opener
Your first problem is you bought a digidoor garage door opener. But check their website, or call the manufacture. You will either be able to download the manual or have to buy a one directly.
Mar 28, 2015 | Building Materials
I bought a receiver to pair a Centurion D5 motor with thE Digidoor motor.How do i install the Receiver on a Digidoor motor?
Hi there Vusi.
You should have a manual open and close switch on the wall for your Digidoor. You need to find the two wires which control the open and close functions on the Digidoor Trace these back to the Digidoor motor connect these to the Comm and NO terminals. You also need to supply 12V power to the receiver This needs to be connected to the Possitive and Negative terminals on the receiver. These connections originate in the Digidoor motor housing and can be connected right there. Some Digidoor motors have connection terminals for additional remote receivers in the housing. Remember that the minimum connections needed are Positive, Common(Sometimes the common is also the negative supply so you can bridge the common and negative terminals on the receiver) and NO. Then pair the remote with the receiver as per the instructions in the receiver box. If you still cannot come right post pics of the PC boards of your receiver and Digidoor motor and I will identify the connections for you
Jan 05, 2015 | Televison & Video
How do I program a Digidoor 3 garage motor.
Limits must be programed. Power down and remove battery power ,press & hold button on motor pc board then apply power still holding button. The door should start running open and close. When it starts you can release button
Oct 31, 2014 | Building Materials
Why does myd digidoor ii opens fully but does not close ...just moves front then back again
The child safety interlock is not set right. The transmitter and receiver are placed at the bottom of each side of the door. If the transmitter/receiver are not aligned correctly, the door will not close.
Line up the transmitter till the light on the receiver lights up.
Aug 22, 2014 | Building Materials
Digidoor ii wall console will not open or close the garage door
First thing to check is the power. If this is on, then the only answer is that your green wire linking console button to the motor has a break in it. I found my break at the motor connection - after time this had been bent and weakened and had snapped. I snipped end of green wire (motor side), cut away plastic and reconnected to motor connection with two arrows up and down, and wa la! Try it.
Mar 11, 2014 | Transcend T-Sonic 850 Digital Media...
How do i programme a digi key remote to my digidoor II garage motor, my original fell and no i bought new digi key remote. plz help
How to program a digi-key remote control :
- on the wall console press the light toggle button to switch the light off.
- press and hold the light toggle button, the light will come on and after 5 seconds go off.
- release the button and the light will go on again.
- within 30 seconds press the required key on the digi-e key transmitter (your remote control). The light on the digidoor ac/dc will go off.
- to confirm press again the same button the transmitter (remote), the light on the digidoor ac/dc will flash foor times. Done
Apr 22, 2011 | Audio Players & Recorders
Hi, My Digidoor II opener only moves the door 20mm at a time and stops. The same happens using the remote or the wall mounted pushbutton. How do I fix this?
I had the same problem easy to fix!
It's the rocker rail (small plastic thing that ajusts the power and direction) that is damaged. Buy the part for R36-00 from any Digidoor agent 011 3978448.
Remove the motor from the installation rail and open the blue motor cover. You will see the rocker rail is attached to the blue cover, one of them will be broken. Replace both of them (up and down)!
Jan 06, 2011 | Computers & Internet
I bought a second hand Digidoor 1 with garage door. The door opens and closes perfectly when the digidoor is off. When I power up the digidoor the motor will not open the garage door when the door is...
You are receiving interference from the digi door. You will have to return this unit and go with a different one on a different frequency. Chamberlain makes a clicker that would work well with that unit. Thanks BB
Sep 21, 2010 | liftmaster Chamberlain Garage Door Opener...
Computers & Internet Logo
501 people viewed this question
David Payne
David Payne
