Question about LG LP1200DXR Portable Air Conditioner
Won't auto clean - LG LP1200DXR Portable Air Conditioner
While using the auto clean on my oven The glass shattered. Hi had to turn the oven off at the mains to stop the cleaning process. But now the oven won’t unlock. Any advice would be appreciated
Hi
In process of cleaning you can not stop it and to stop it you must do reset what is the model and compeny ?or add a phoro to help you.
Oct 21, 2017 | Ovens
1993 buick park avenue heater won,t work.checked all fuses an relays
i beleive you did more than that.? you,ll probably find all have a common earth , chech and remove it , clean with a wire brush and replace, also chance the fuse you removed and replacer reguardless of it,s appearence , ensure its put back in the correct location,peter.
Sep 03, 2012 | 1993 Buick Park Avenue
Won't auto focus
Make sure the auto-manual focus switch on your camera is set to auto (A) and also make sure the auto manual focus selector on the lens is in auto (A) as well. If your lens contacts are dirty then this will affect the function of the lens as well. Clean those with either a lint free type cloth and alcohol or methylated spirits.
May 26, 2012 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Htc one s won't auto rotate
I have the HTC One S too, and just got my screen rotation problem solved. It wasn't rotating either, even though auto rotation was checked, it was stuck in landscape mode. Then, I uninstalled a few apps that I didnt think were needed anymore, like a game, pixlr express, tango, and a dictionary app.. after that I cleaned the app cache and problem was solved without even restarting. I'm not sure why that worked, but you can try and see it if works for you. I hope it works :)
May 18, 2012 | HTC Cell Phones
Do i need to greas the auto locking hubs on a 1992 ford explorer
YES THEY SHOULD BE CLEANED AND LUBRICATED THE GREASE GETS STIFF AND WON,T LET THINGS MOVE FREELY
Mar 17, 2010 | 1998 Ford Explorer
Motor won,t run on auto
Try blowing some canned air into the feed slot to clean the sensors.
Dec 17, 2009 | Dynex Office Equipment & Supplies
I have a T25 Transporter 1990 ,front wipers won`t
It sounds like the park switch inside the wiper motor has failed or a bad contact. If you can get to the motor, remove the plate/cover and you should see a micro switch, check it for broken wires or clean contacts. If you dont feel comfortable doing this, then take the car to an auto electrician, he should be able to sort it.
Hope this helps
Nov 12, 2009 | 1999 Volkswagen Golf
Automatic won`t change above second gear
sounds like the selector box at fault but change the auto oil and filter with some treatment and this should solve youre problem
Feb 19, 2009 | Nissan Altima Cars & Trucks
LG LP1200DXR Portable Air Conditioner Logo
18 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
