Question about Dryers
My plugs in my bedroom only work when the light switch is turned on. How do I fix it?
    Genius:
  • 1,617 Answers
Call an electrician!
Posted on Jul 19, 2013
Why Ceiling Fan Fixture does not work
You get what you pay for! Shouldn't buy a store brand.
Jul 14, 2014 | Hunter 52" Ceiling Fan With Light And...
Why my Hunter Ceiling Fan does not work?
Its unlikely that the fan is on a separate feed from the breaker box than the rest of the outlets in your room but you never know. It would not hurt to check all of your breakers. If the fan and its light are controlled by the same wall switch then the wall switch may have went bad. Within the fan there are separate wires for the fan and the light so both of them would not go out at the same time. It makes more sense that the problem is at your wall switch.
Jul 14, 2014 | Hunter 25872 Sojourn II Brushed Chrome...
I have no up stair lights after going to turn on bedroom light nothing I noticed that the other bedroom lihgt had gone out so I changed the bulbs and the fuse in the fuse box made no difference Ithen...
hi if the rose has caused the problem then the mains wire may be damaged, it can also damage the fuse RCB0 B6 fuse, this will not let power though until the fault is fixed. it would be best to get an electrician to fix this problem as its dangerous to open the fuse box to fix the problem.
Jul 15, 2017 | Office Equipment & Supplies
Toshiba hooked to dish struck by lighting, will not turn on, solution?
Ensure the power outlet has power. Try TV on a different power outlet. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Aug 01, 2012 | Televison & Video
I have a circuit breaker that controls a light switch and all the outlets in one bedroom and controls half the outlets and a light switch in another bedroom. None of which work now. I have replaced the...
One single cable runs from the circuit breaker to a junction box in that area of the house.
The cable has a black Hot wire, white Neutral wire, and bare ground wire.
Once the cable arrives at junction box, it can split up 2 or 3 directions.
Each successive box receives a cable that feeds back to the first junction box.
Chances are the junction box is on the ceiling. And it will be the ceiling box that is closest to main breaker box.
Junction box can also be a switch box. In that case it will be switch box closest to main box.
Find the junction box, as point of organization.
Open junction box and separate all black and white wires.
Turn power on and see if breaker sets.
That will tell you if problem is between main box and junction box.
Junction box wires are separated.
Tape tester leads to wood sticks to keep hands away from power.
Turn power ON and test each wire in junction box to bare ground wire.
Tester will light up on Hot wire.
Test Hot to each other wire in box, except bare ground, and tester lights up on Neutral
This identifies the cable that comes from breaker box.
Now, reconnect cable from breaker box to one of the other sets of black and white wires located in junction box.
Check if breaker resets.
If breaker resets, see what circuits are working, and you can eliminate them as suspect.
Remember each successive box in a circuit has 1 cable that connects back to main breaker box
Going 1 box at a time, and disconnecting black and white wires, will eventually lead to the suspect.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 05, 2011 | Electrical Supplies
Lustro Maestro MA-LFQHW-WH Fan/Light Dimmer
something is messed up for sure... two solutions.... disconnect outlet and cap wires.. or open up both boxes and see where / how they they wired the outlet into the fan/ light control and disconnect it there and then pick up power for the outlet from the black /white wires BEFORE the dimmer control
Aug 19, 2009 | Maestro Fan/light Dimmer Ma-lfqhw-wh...
We have 2 Hunter ceiling fans with remotes. We can get the one in the bedroom to work great but the one in the living room now will not turn on the fan or light. Also when we are trying to get the living...
The remote might have wrong orders. Get the battery out and insert it back and see if the problem solved.
Do you set the dip switchs correctly on the fan and on the remote? Numbers set must be matched. Otherwise, the fan won't work either.
Aug 11, 2009 | Hunter 52" Ceiling Fan With Light And...
Central Vac will not turn on.
These problems are nearly exclusively caused by a bad circut board and replacing it is the fix. Bad boards can cause many different effects so its nearly impossible to be sure. The 9v signal wire is not enough to short out an entire unit so it is unlikely the hose. If it is a direct connect system and you are pulling power from the 110 somehow that would cause main unit problems but that is unlikely at best. Sounds like a failed board to me.
Best of Luck
Jun 04, 2009 | Easy Flo EF1400 Central System Vacuum
Motor Hum
check your grounds and all other connections. remote wiring has to be precise. somes times not for the do it your selfer. all the labor youve encountered somes the cheap can turn out to be very expensive.
Apr 26, 2009 | Hunter 52" Ceiling Fan With Light And...
Dryers Logo
15 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
