Question about Panasonic SC-PM17 CD Shelf System
Cd tray won't open, and cd's won't play
May somebody please help me. My Panasonic SC-PM17 was working fine, till today, when i tried to play a cd, it won't play it at all, so i tried with each of them, but it doesn't play. i checked if the cd tray was jammed but it didn't appear to. I tried to change the cd, but each time, the system would not take any commands. I tried everything that was on the manual, but without luck, all i can get too is "CD change", but i can't select the track from any cd to play. If somebody will be so kind to help me, i'll appreciate it very much.
4 Suggested Answers
SOURCE:
  • 130 Answers
SOURCE: CD player
All this cd systems have the same problem. If you're using burned cd's sometimes they don't work so you need to close the session after burning in your burning program. If you're using original cd's it means that the device needs to be cleaned up (especially the lens) because the structure of a 5 cd combo device gets very dusty after a while. Also from my experience after cleaning it put a cd in each deck (even if it's off) so they could prevent it getting dustier again. Hope it helps, good luck!!
Posted on Feb 12, 2006
  • 4 Answers
SOURCE: I have a Panasonic sc-pm16 and the cd trays are
The cd changer is of a bad design ! The limit switches from the trays and the gear wheels (plastic material) are **** ! It's a mechanical Problem. You have to disassembly the completely cd changer !
Posted on Aug 12, 2010
  • 75 Answers
SOURCE: Panasonic SC-AK600 CD player says "no disc" when
Your cd laser lens has got weak.get it replaced.
you can replace only the lens or the whole laser pickup.
Posted on Jan 31, 2011
CD function not working on Panasonic SA-HE70 receiver
when you say its not working what do you mean by that?
its got no power.
the tray wont open.
tray trying to open but wont.
or just wont play cd.
if none of the above could you please give me more info please.
Nov 08, 2016 | Panasonic SA-HE70 Receiver
Why won't the CD drawer and Cassette door open on my Panasonic SA-PM17 CD Stereo System?
This does happen with CD trays, it's quite common. I can't remember the exact mot common cause, but it's some worn out part, such as a small (plastic) cog wheel. Search on "cd tray won't open" on the internet to find a multitude of reasons, most to do with computer CD trays, but I guess the mechanism is essentially the same. These may also describe ways round the problem.
Some CD players have a small hole on the front near the tray into which poking a straightened out paperclip should enable you to open the tray by a few mm, enough to be able to pull it open in an emergency - but it's awkward to do on a frequent basis.
5.May.2014
May 05, 2014 | JVC XL-F254BK 5-Disc CD Changer
The tray on DVD won't open when pressing OPEN button DVD/CD is inside
Often the tray is powered by a rubber belt. If the latter breaks or slips the try will not open/close. The motor will work and tell the electronics that all is well because it has done its job but it really hasn't since the tray is inert!
Sep 10, 2017 | RCA DRC247N DVD Player
No disc
nicely done! congradulations
Mar 18, 2012 | Panasonic SC-AK630 CD Shelf System
Cd changer loading problem (panasonic sa-pm53)
Have a Panasonic SA-PM53 pulled a CD trays out to get stuck CDs out. So how do I get the 5 CD trays back into the carriage and in sync?
May 24, 2009 | Panasonic SC-AK78 CD Shelf System
Disc tray won't open
try turning the dvd off if this dosn't work than try rotating the tray , there maybe a cd jammed in the unit . If this is the case you will have to remove the cover and manually remove the cd.
Jan 31, 2009 | Panasonic SC-HT730 System
Cd jam in panasonic sa-pm17
Hi. Got the very same problem. At christmas I had loaded two cd's in one of the racks. I used needlenose pliers as well and pulled each of the 5 trays out (well past their runners). Tried to dismantle the unit with the 3 screws on each side, but gave up. When I turn the power off and on and do a cd check the "hello" flashes then nothing, tried cd/change power button and basically everything else. All I can say is go easy on the unit as I was to forceful an now think i've ruined it. I'm gutted as this was a great mini hi-fi and has served me well. Best of luck with ur Panasonic, cheers.
Jan 04, 2009 | Audio Players & Recorders
When we try to play a disc frpanasonic sa-ak28
CD lens may be defective or just need cleaning.
Dec 10, 2007 | Panasonic SC-AK33 CD Shelf System
CD Malfunction
HIwaog, two things can be causing your problem, one is your lens may be defective,or two your sp motor maybe defective, try changing them.
Aug 24, 2007 | Panasonic SC-AK33 CD Shelf System
Cd tray jammed
If you turn it off at the mains, wait a few seconds then turn it back on. As soon as you turn the power on, try and press the button for the tray to open. If this dont work, you will have to open up your system and remove this disc yourself. Good luck.
Sep 21, 2006 | Panasonic SC-PM313 Shelf System
Panasonic SC-PM17 CD Shelf System Logo
89 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
