Question about XR-SR MULTI-FUNCTION SPEEDOMETER
Have a 94 grand marquis gs the dash lights quit working pulled cluster partially out now speedometer quit working... and just recently the windshield wipers quit working unless you flip the bright lights on ...help
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 88 Answers
Hi, if you move the cluster may you move the switch from your steering wheel check you steering switch is on the right fitting.
Posted on Jul 19, 2013
2003 grand marquis turn on the wipers and the instrument lights go out.
Could be a grounding issue , instrument cluster and the windshield wiper motor an switch share ground 201 . lose connection possibly . Pull the driver side left kick panel and look for wires screwed or bolted fast to the car body
Dec 12, 2016 | 2003 Mercury Grand Marquis
My 1994 grand marquis dash lights and tail lights went out is it the light switch
what causes tail light, park light and dash not to work o n a 94 grand marquis
Apr 25, 2012 | 1994 Mercury Grand Marquis
Took apart the dash in a jeep grand cherokee 94 put it back together and now the speedometer wont work but everything else is fine
remove again the dash. in the position of the speedometer, you can see a cable that is quite thick, as thick as a normal coaxial cable that can be seen behind your TV. attach this first at the back of the speedometer before reinstalling the dash.
Aug 07, 2011 | 1994 Jeep Grand Cherokee
Good engine swap for a 94 grand grand marquis
Another 4.6 out of a '94 Grand Marquis. If you can. That way all the sensors will be correct and the wiring harness will plug-and-play. You can install almost any 4.6 but, depending on the year, there's going to be a lot of issues making them work with the electronics in your '94 Marquis.
Nov 08, 2009 | 1994 Mercury Grand Marquis
99 Grand Marquis, Alternator Light
Some people have the dexterity to manipulate their arm and fingers to get behind the dash. I have done this with the digital speedometers when they went dim or out altogether.
Pulling the cluster out really is not that difficult if you are mechanically savvy.
Oct 28, 2008 | 1999 Ford Crown Victoria
How do you remove the dash board on a grand marquis 1996
It is best to remove the front seat then remove the outer trim work on the dash which are fastened with clips. Then remove the screws which hold the heater/AC controls and also the dash panel such as speedometer etc. Remove the lower plastic shield from around the steering column and disconnect the transmission gear position indicator cable. Remove the plastic covering between the steering column and the drivers knees. Their are mounting bolts in the dash and under neath as well and also barbed fasteners. Remove the steering wheel column mounting bolts and it's support brackets. Lower the steering column to the floor. Remove the front door coverings located near the door hinges. Be carefull not to break the fasteners. They pry out of the door weather stripping and then you lift up on them. This will give you access to the lower dash mounting brackets.
With the steering column lowered remove the plastic trim under the windshield. It pops out and givces you access to the front dash mounting screws. disconnest the headlight photo cell control, disconnect the clock, radio and all other pigtail connections that would otherwise interfear with removing the dash. I remove the speedometer electronic cluster as well. Disconnect the AC/heater upper and lower duct work. They are generally fastened with screws and and you have to look for them.
The dash is fastened by the previously mentiond screws located below the windshield and by bolts located near the door which can be seen when the trim is removed also by lower bracket that are braced and is easily identified. These bolts heads are # 10 metric. I have probably forgotten a couple of items but this should get you through the worse of it.
The Mercury Grand Marquis and the Crown Victoria both tend to have blend door problems for the climate control and the dash has to come out to access the blend door control.
Aug 02, 2008 | 1993 Mercury Grand Marquis
XR-SR MULTI-FUNCTION SPEEDOMETER Logo
70 people viewed this question
Top Koso Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Koso Vehicle Part and Accessory Expert? Answer questions, earn points and help others
