Question about 2010 Bentley Continental - Supersports, coupe - Form Fit Car Cover
Bentley continental gt hydraulics
My bentley continental supersports shows a message that "STOP ! Car too-low" What do i do ? It happend when i left my car on high level nd parkd da car fr a few hours and came bak da car was too low from da front and normal from da back :S Pls help !
  • 5,546 Answers
Probably the best thing is to not drive it and have it put on a flatbed tow truck for the Dealer.
Bentley may have a superior Warranty as your car is not 5 years old yet. With the uniqueness of a Bentley you would easily tear up the undercarriage or front body moulding by driving it.
The parts to fix it now will be a lot cheaper than if you damage it by driving. It can be simply a defective Relay. Check the Owners Manual for Relay type and placement if you want to try it yourself.
Posted on Jul 21, 2013
Fuse box diagram for 2008 Bentley Continental GT Speed
Your car should have come with a medium thick book that shows the various fuse boxes and locations/purpose of each fuse.
Jul 26, 2017 | Bentley Cars & Trucks
Where is the AC TEMP sensor located on this car?
Hello Niall MacKay,
Beautiful car!
The picture I found shows a probe (TOP RIGHT) ...
My best guess is that it lives inside an AIR DUCT...
On my cars... I have the FACTORY manuals...
failing that the Bentley Book (un-related) series manuals are pretty helpful. However finding your BOOKS has proven 2 B quite the challenge.
For unknown reasons that MOPAR sensor popped up in my many failed quests (doubtful but perhaps a helpful clue).
Good luck
2005BentleyContinental GT Parts from Buy Auto Parts Bentley Continental Manuals at Books4Cars com
55111178AC Cabin Air Temperature Sensor
Mar 04, 2016 | 2005 Bentley Continental GT
2004 bentley continental gt bonnet releace wont open
You've got a Bentley Continental and you are looking for an answer here? You cheapskate. Call a dealer. My suggestion, is the battery low.
Nov 18, 2014 | 2004 Bentley Continental GT
2012 bentley continental gt
what is question i might be able to but thats very expensive car ill try to help charles
Sep 04, 2014 | 2012 Bentley Continental GT Base Coupe...
Bentley Continental R head Gasket leak
If you can afford a bentley take it to the dealer
Feb 18, 2014 | Gaskets for Bentley Continental...
Bentley continental gt battery does not hold full charge and abs light comes on intermittently?
if the battery is bad, replace it. Low battery voltage can turn the abs light on. Always fix the obvious problem first.
Nov 27, 2010 | 2006 Bentley Continental
2006 bentley continental w/dead battery. How can
Normally if you use the key and turn it to the left and then to the right the car will start on the resident battery and all will be well. Do not use the start button. If all lelse fails then put a battery charger into the two cigar light sockets for 1 hiur at max 10 amp with ignition turned of and with wires trapped in closed door to switch all coutesy lights off and then there will be enough for the trunk lock to energise. If it is later spec there will be a handle in the trunk accessible thru the centre arm rest by an arangutang!""
Jun 02, 2010 | 2003 Bentley Continental GT
Unintended acceleration
You will need to have a test run of the electronic engine controls, if nothing shows test the Throttle Position sensor, closed throttle voltage should be around 1-1.25 volts, while the meter is hooked up and the key on tap on the sensor the volt reading should remain steady, open and close the throttle repeated times, it still should return to 1-1.25 volts closed throttle blade.
Nov 08, 2008 | 2005 Bentley Continental
Problems with the car
if battery is dead then insert key into ignition and turn to the left , this will put it onto auxiliary battery and then you will need to charge main battery ( in rear) when able
May 14, 2008 | 2007 Bentley Continental
2010 Bentley Continental - Supersports, coupe - Form Fit Car Cover Logo
359 people viewed this question
Top Covercraft Vehicle Parts & Accessories Experts
Tenderfoot
Tom
ptpumpman
Are you a Covercraft Vehicle Part and Accessory Expert? Answer questions, earn points and help others
