Ncr atm error codes
*5255*2*E(1*300001400,M-14,R-10010
    New Friend:
  • 5 Answers
If this error is on dispenser,means shutter jammed closed.Is necesary to check the shutter and reductor gear to the shutter and change if is brocken.
Posted on Jan 28, 2015
P77 ncr atm found automeatic diespensar ran
Posted on Oct 10, 2013
    Sergeant:
  • 396 Answers
Contact NCR Support. They should have the answer to this problem. That is a proprietary piece of equipment.
Posted on Jul 21, 2013
What is meaning of this ATM error
*7810*2*E*300050900,M-13,R-10110
what is meaning of this error codes and whats happening for atm machines
Jul 19, 2013 | Summit Appliances Division Youniverse...
Ncr cash register model 2114 3Err code
error 3 code on model NCR 2114 is a printer error meaning the printer cannot complete a print cycle caused by various issues concerning the condition of the printer
Nov 16, 2011 | Computers & Internet
I have a problem in my ATM machine.. it shows the error on screen ( communication down) i check my telefone lines its ok ..... and there is no problem in brain net connection ..... plz some one help me...
Different ATM Machines have different error codes. If your ATM machine is experiencing a communication failure it could be a bad modem board, or just a simple phone line problem.
I suggest starting with replacing the phone line. First, plug a regular phone into the wall phone jack, make sure you have dial tone. If you do, get a brand new phone cord and run that into the top of your ATM. Disconnect your ATM phone line inside the head of the ATM and plug that new cord in there. Try and clear the communicaiton error. If that works, try a transaction. If that works, replace old line with this new one.
If that doesn\'t work, make sure you didn\'t lose master keys, and that your ATM is actually online with your processor.
If you are not getting good service, and your ATM has been down for days, you should look into changing your ATM processing.
Google ATM Processing or call 888-501-5246
Dec 05, 2010 | Computers & Internet
I have a 7870--2000 NCR scaner and it keeps freezing with the cash rigester?
First determine if the problem is the scanner or the register. Switch scanners with another one, does the problem follow the scanner?
Could be the cable, interface card on teh scanner.
If the problem stays at the register and you tried a new cable, the register is the problem.
Apr 10, 2010 | NCR 7872
Capital Computer Group, LLC
651-405-8293
www.capcom-ncr.com
We specialize in the NCR arena, also have many other point of sale needs.
Free bench testing equipment failure on any p.o.s hardware item.
Nov 05, 2009 | NCR 7875
7875 scanner/scale error code 4.
Problem is with the scale part of theunit, it needs calibrating, you can do this but you do need a set of weights, and it also depends on what country you are in reference the legality after you have done this. But chack fist the top plate is OK not damaged and sits OK, press scale zero. If that does not work there is a cover at the front of the unit sometimes with a seal over it or through the part that stops the cover being shown. Press the button under thisand follow the audio instructions, you will need 2.5kg, 5kg & 10kg or 5lb, 15lb & 30lb depending on ncountry you may need Weights & Measures in to verify afterwords depending on legalities
Mar 26, 2009 | NCR 7875
I have been getting error code and now error code , which I assume are related, Where can I get a replacement ink absorber?
2425 Enterprise Dr.
#200
Mendota Heights MN, 55120
Wethernb@capcom-ncr.com
651-405-8293
We Buy, Sell, Repair, and Refurbish both new and used POS Systems, NCR, IBM... We also offer structured cabling as well as Video Surveillance Equipment.
Give us a call and we can trouble shoot it with you!
Jan 14, 2009 | Office Equipment & Supplies
Error 230 en Escaner NCR 7875
You need disable the scale scannig the bar codes for programing
Program mode
304
save and reset
301lbs to kg
302kg to lbs
303enable scale
304disable scale
305 Protocol comunication
306 Protocol comunication
307 Protocol comunication
Oct 08, 2008 | NCR 7875
Computers & Internet Logo
270 people viewed this question
David Payne
David Payne
