Ir 2270 e 732- 0010
Whan 2-2 side copy one side scan but 2nd scan not moov and one side copy after scan machin hang and after some time err 732-0010
4 Suggested Answers
sagarjd
  • 95 Answers
SOURCE: scanning/copy - black bar
Please perform the steps provided in the following weblink:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00704831&dlc=en
Regards,
Sagarjd
Posted on Nov 21, 2008
rhoncruz
  • 134 Answers
SOURCE: lexmark x2500 err msg: UNABLE TO CONNECT
What you will see
When trying to print, you get a communication error; the device is correctly detected in the Device Manager, the firewall is not blocking any files and you can scan using the All-In-One Printer.
Explanation
Any PC using the AMD USB architecture is preventing the printer from printing when connecting via USB.
What to do
Follow the specific steps for the PC manufaturer below:
Dell Studio 1536:
IMPORTANT: Do not replace any hardware, before performing the following steps:
Step Action 1 Go to Control Panel 2 Go to Programs and Features 3 Uninstall AMD USB Audio Driver Filter
Note: Uninstalling this USB audio driver doesn't cause any impact for systems with Vista Service Pack 1 installed
Acer Aspire 5530, Extensa 4130, Extensa 4430, and TravelMate 4530:
There are files available to address printing problems when connected to a USB printer or multi-function printer, for Windows Vista and Windows XP.
  • Printer did not print, print jobs will be listed with the status "error" in the task list
  • No error message appears, printer simply does not print
  • Problem only manifests when the printer is connected via USB
Please go to the Drivers and Downloads area to get the file appropriate for your operating system and unit.
US Customers:
http://www.acerpanam.com/synapse/data/7117/documents/USBFilter107_Vista_Setup.msi
http://www.acerpanam.com/synapse/data/7117/documents/USBFilter107_XP_Setup.exe
EMEA Customers:
ftp://ftp.work.acer-euro.com/notebook/aspire_5530/vista/Drivers/USBFilter107_Vista.zip
IMPORTANT: The third-party products discussed in this article are manufactured by companies that are independent of Lexmark. Lexmark makes no warranty, implied or otherwise, regarding the performance or reliability of these products.
Still need help?
If you need additional assistance, please contact Lexmark Technical Support. NOTE: When calling for support, you will need your printer model/machine type and serial number.
Please call from near the printer and computer in case the technician on the phone asks you to perform a task involving these devices.
I hope it helps!!!
Posted on Dec 02, 2008
  • 990 Answers
SOURCE: Steps to make an automatic double sided copy
Hello sir; That is depend on your machine have duplex unit or not if doesn't come with duplex unit you can not do it.
Posted on May 30, 2009
How do i get the factory default setting for canon ir 6800?
Go to service and and clear the error
Asterisk * press
then press 2 & 8(Two buttons single time)
Again press Asterisk *
COPIER>FUNCTION>CLEAR>ERR
Then press ok an off the machine wait 1 minute and on the machine..
Jun 23, 2016 | Canon Office Equipment & Supplies
E000003-0000
good morning sir, my ir machine is 3300 the problem is showing to my machine is E000003-0000 please suggest me answer
Thanks
Apr 21, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
IR 2270/2870g photo copy machine ,paper jam at the time of double side copy
Clean the vertical path rollers .they are located in the right door. check for obstructions. inspect your right door for broken parts and missing pressure springs that keep pressure on those vertical rollers. Make sure the right door is shut firmly.
Apr 11, 2014 | Canon Ink Cartridge GPR15 for iR 2270, iR...
I have a cannon ir 3300 machiene and occured a problem with a error code e000000-0000 please help me out to remove this problem my technician has asked me to change the filament which is worth 12000.w
First clear that error from service mode. Press additional function
press 2 and 8 together
press additional function agian
service mode should appear in screen
select copier
select function
select "clear"
select "err"
select ok.
unplug power cord for a few seconds and restart the machine
try to make some copies if problem persist replace the fixing heater assembly
Feb 17, 2014 | Cannon Office Equipment & Supplies
Hello , i have cannon IR 2270/2870g photo copy machine ,paper jam at the time of double side copy
There might be an issue with the feed clutch or fuser. It depends on where it jams in the machine.
Sep 27, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Open your developer unit and check sensor , refix it an close unit see........your problm solved
Apr 22, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
How to clear RAM using factory settings in CANON IR330 machine?
ir 330 and ir 400,gp 405 r same machine,turn on the copier when its ready to copy press the additional function then press (2 and 8 both r same time) again additional function when this process is completed copier on the screen select that in the screen find the 'function' select then select on clear in clear menu select one by one err and other all function like dc-con and press ok after se;ect one by one..
Sep 02, 2011 | Canon ImageRUNNER 330s Copier
Canon IR 400
i have canon ir405 cpier it dispays error code E243 please help me sir
Jun 01, 2009 | Office Equipment & Supplies
Problem in Leica Microtome Model 2145.(Semi Automatic)
It sounds like there is a problem on the main board or the motor controll unit ,, you should replace those
Nov 10, 2007 | Computers & Internet
jasbo
jasbo
