Protect push power sony/mhc Rv6
Sir, i have already changed the parts, as the technician of sony service centre insisted to change the optical laser, as the gear was broken, which was mounted on motor, so he changed the total unit and optical laser too, beside that he changed a card, which was attached rite behind the disc tray, which i think, it is video card. Now my hi fi sytem is working but, i want to knoe whether the technician has done rite thing to my system, and may i knoe what is the actual price of optical laser unit and video card, how to knoe it is originally belongs to sony? because, i found, on the motor as MADE IN CHINA.
    Genius:
  • 1,479 Answers
You will find nearly all electronics are made in china so that isn't unusual. all I can suggest is to use a search engine like google or yahoo with the model number of your system with the name of the component part that was replaced. that will give you an idea of whether you were charged correctly. doing this, you WILL find lots of people selling these parts a lot cheaper than sony do - because they're not sony parts. they're copies or equivalents.
Posted on Jul 19, 2013
SOURCE: Sony MHC GNZ8D Region unlock
Need to unlock the MHC-GNZ8D. Please help.-
Posted on Jul 18, 2010
  • 375 Answers
SOURCE: I have not been using
it could be that your lens has lost its ability to read dvd discs but retains the abaility to read the audio cd you used. If this is the case (and a cleaning disc doesn't help) then I am afraid that the service centre was correct in its assumption.
Hope this helps.
Posted on May 08, 2011
SOURCE: Does anyone have a manual for the sony mhc 65300av
I want to o order
Posted on May 10, 2011
dunnbiker
  • 8546 Answers
SOURCE: my sony mhc-s9d goes to 'push system protect;
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on May 18, 2011
  • 1054 Answers
SOURCE: How To Remove Push Power Protect To My Sony mhc-dp1000d?
You can't. There is a short in the amp that needs to be repaired before the unit will power on normally.
Posted on Mar 08, 2013
Can we connect mobile to sony MHC-RV6
If the old version of Sony MHC-RV6 then no, if the new 2015 than Yes, it has bluetooth capability.
Feb 20, 2016 | Sony Audio Players & Recorders
Sony vcd component.mhc-rv6 error protect
That's either a wiring short, or a blown speaker, or the unit's output transistors are fried.
These are all physical defects. There's no button to press that will fix this.
Sep 03, 2014 | Audio Players & Recorders
Protect push power/ sony- MHC RV6
A protect message on a sony usually means there is an amplifier problem.
Jul 19, 2013 | Audio Players & Recorders
Sir my MHC-RV900D is disply shows push power protection again and again.plz solve my problem. thank u
There is most likely a short in the amplifier that will need to be repaired before the unit will power on normally.
Mar 12, 2013 | Sony MHC-GX40 CD Shelf System
Sir my sony stereo system showing "protect push power" how i troubleshoot the problem please replay fast
Protect Push Power on a Sony is telling you that you have an output short circuit and to turn off the player to prevent further damage.
Check the speaker cables for connection fault. If all is OK it means you have a blown STK Amplifier Chip. Will cost you about 20$ plus labor.
Apr 30, 2011 | Sony MHC-NX3AV Shelf System
Protect push power
audio amplifier IC fried need to be replaced
Jun 01, 2010 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Protect push power
you have wires touching. did you drop anything in your radio? water, medal's?? etc..
Dec 19, 2008 | Sony MHC-RG30T Shelf System
Push protect problem/ sony MHC-VX33
push power protect is error signal shows problem in power amplifier board, mostly power amp out
IC STK402-100S found deceptive.
contact nearest Sony service center for proper repair.
Sep 29, 2008 | Sony MDS-JB940 Mini Disc Player
64 people viewed this question
 Grubhead
Grubhead
