Protect push power/ sony- MHC RV6
Sir, i got the message in my sony hifi sytstem and it display the protect push power button and already the technician has changed the optical laser and a card which is rite behind the tray, i think it was the video card he changed and presently its in a working condition, but i want to know whether the technician has done rite job or he has cheated.
    New Friend:
You must deals sonyMhc Rv6 power amplifier card
Posted on Sep 06, 2015
    Genius:
  • Audio Player... Master
  • 1,054 Answers
A protect message on a sony usually means there is an amplifier problem.
Posted on Jul 19, 2013
SOURCE: Sony MHC-57AV - System shuts down "Push power protect button"
this problem is audeio out put is sort .pls ching out put STK .Any Q - My ID uttamkholiya@yahoo.com
any sony music system problem
Posted on Nov 07, 2009
SOURCE: sony mhc-7av push power protect
Maybe the audio amplifier IC damaged and need to be replaced good luck
Posted on Feb 11, 2009
nuwan chinth
  • 111 Answers
SOURCE: pushed power protect
speaker protection turned on.it can be happend because of bad power amlifire section.can you remoove the powe ramp board with large heatsink.its very easy to repair.and i can help.
nuwan
Posted on Jan 12, 2009
SOURCE: Sony MHC-2800 setting the clock
Hi, it's simple. First press "Timer1" and Timer2" buttons together, clock on display will start blinking, by cursors "Up/Down" you can change the value of hours and minutes (switching between hours/minutes by "Left/Right" cursor). To save set time press "Memory". Enjoy your set clock :)
Posted on Jan 30, 2008
Luis2584
  • 7 Answers
SOURCE: protect push power
you have wires touching. did you drop anything in your radio? water, medal's?? etc..
Posted on Dec 19, 2008
Can we connect mobile to sony MHC-RV6
If the old version of Sony MHC-RV6 then no, if the new 2015 than Yes, it has bluetooth capability.
Feb 20, 2016 | Sony Audio Players & Recorders
Tip
My sony 3 disc ex-change/mini hifi component system mhc-rg66 it keeps flashing...
First things first. The unit doesn't switch on.
- Is it plugged in?
- Is the fuse blown?
- Does it look like it's suffered damage?
It switches on, but won't play anything / the lights come on, but no sound.
- We'll start at connections. Is your MP3 player/ iPod/ CD player/ record deck plugged in correctly?
- Are the speakers plugged in correctly/ at all?
- Is it in protection mode - this is a pretty standard thing now, where the amplifier tries to deliver more than it's rated current (ie, into a short circuit), and it cuts out. The only way to fix this is to take it to a local hifi shop, who will reset it (there's usually a small fee involved). The unit will be fine after that.
------- There is no bass. ----------
A few causes for this, so there's a few solutions.
- The speakers are out of phase. This is where one speaker is wired normally, one is wired in reverse. The bass from each speaker is "opposite" and would cancel out. To solve this, Make sure the + on the speaker is connected to the + on the amplifier. There's usually a stripe on the cable to help you determine this.
Cause # 2
The eq settings on your ipod/ unit have been messed with.
Set all the equiliser settings to flat, then readjust them to taste.
Cause # 3 (nasty one)
You've blown a woofer. The explanation is this - the speakers have taken in too much power, the bass unit has got too hot and the glue holding the coil in place has melted. Usually, the woofer can't be physically pushed when this happens. To solve this, it's new speaker time. An alternative is to see if you can get a recone kit for said speaker, and try to fix the voicecoil yourself. This isn't recommended to those who are new to the idea.
I hope this helps the reader.
Chris
on Sep 27, 2010 | Sony LBT-ZX6 Shelf System
Sony vcd component.mhc-rv6 error protect
That's either a wiring short, or a blown speaker, or the unit's output transistors are fried.
These are all physical defects. There's no button to press that will fix this.
Sep 03, 2014 | Audio Players & Recorders
Protect push power sony/mhc Rv6
you will find nearly all electronics are made in china so that isn't unusual. all I can suggest is to use a search engine like google or yahoo with the model number of your system with the name of the component part that was replaced. that will give you an idea of whether you were charged correctly. doing this, you WILL find lots of people selling these parts a lot cheaper than sony do - because they're not sony parts. they're copies or equivalents.
Jul 19, 2013 | Audio Players & Recorders
Sir my MHC-RV900D is disply shows push power protection again and again.plz solve my problem. thank u
There is most likely a short in the amplifier that will need to be repaired before the unit will power on normally.
Mar 12, 2013 | Sony MHC-GX40 CD Shelf System
Whenever i turn on my sony MHC-VX333 mini hi fi it flashes the message "push power protect"
when it display push power,this indicate an instruction to push the power button. please do so
May 17, 2010 | Electronics - Others
I've sony mini hifi MHC-GZR88D. flicker
cold reset your hi fi system, by powering on your system then while holding stop button press disc 3 and power at the same time.
Feb 10, 2010 | Sony Electronics - Others
Protect- push power
After installing the cd display shows the Push Power in the model of MHC-RV5
Jul 07, 2009 | Sony DVP-S330 DVD Player
457 people viewed this question
 Grubhead
Grubhead
