Question about City Bus Simulator 2010 York - Windows
C4 engine 32 bit color
Error: 47520003 what can i do
With new Windows 10, I'm getting error msgs when I scan docs, what can I do other than turn the Lexmark OFF and then ON, to get it to communicate without error messages ?
did you update the driver for the printer
see http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_UK&productCode=LEXMARK_PRO4000#2
Which o/s as not mentioned by you if 32 bit or 64 bit version guessing 64 bit version on link above as there was a windows 10 32 bit version available also
Oct 12, 2015 | Lexmark OfficeEdge Pro4000 Inkjet...
Error code c4-10
This code does not exist. C4-00 means your Primary Transfer Corona stick is bad and needs to be replaced.
Nov 20, 2013 | Sharp MX-3610N Color Photocopy, Print &...
At 1440x1200 resolution the monitor (719Sw) visualizes fine, but a window appears saying "input not supported". Does my cpu not support this monitor. Its a P4, 32.99 ghz 504 mb ram machine
Restart the computer
2 While the computer is loading, press "F8" key on the keyboard right before the
computer reads the hard drive or press the "F8" key multiple times in 1 second
interval until the "Windows Advanced Options Menu" appears on the screen
3 Under "Windows Advanced Options Menu", using the arrow key on the
keyboard, select "Enable VGA Mode" then press Enter. Select "Windows 2000
or Windows XP" for your operating system.
4 Wait while the computer is loading and once the computer finishes loading,
5 Right Click anywhere on the blank area on the desktop then click "Properties"
6 Click on "Settings"
7 Click on "Advanced"
8 Click on "Adapter"
9 Click on "List All Modes..."
10 We recommend that for 15" LCD's select 1024x768, True Color (32 Bit) 60
Hz or 1024x768, High Color (16 Bit), 60 Hertz; For 17" & 18" LCD's select
1280x1024, True Color (32 Bit), 60 hertz, or 1280x1024, High Color (16 Bit)
60 Hertz, or
640x480, 256 colors, 60Hertz or 75Hertz
640x480, High Color (16 bit), 60Hertz or 75Hertz
640x480, True Color (32 bit), 60Hertz or 75Hertz
800x600, 256 Colors, 60Hertz or 75Hertz
800x600, High Color (16 bit), 60Hertz or 75Hertz
800x600, True Color (32 bit), 60Hertz or 75Hertz
1024x768, 256 colors, 60Hertz
1024x768, High Color (16 bit), 60Hertz
1024x768, True Color (32 bit), 60Hertz
11 Additional Valid Modes for use only with 17" & 18" LCD Monitor
1280x1024, 256 colors, 60Hertz
1280x1024, High Color (16 bit), 60Hertz
1280x1024, True Color (32 bit), 60Hertz
May 17, 2011 | AOC 917Sw 19" LCD Monitor
It says c4 engine and then it says something about 32 bit color . my comp is set to 32 bit color and i have the latest directx so what could be the problem also i have a dual core prosseser and the lastest...
Gentlemen,
I purchased City Bus Simulator 2010 from Fspitot shop under order Number 316737 for $54.50 Canadian and cannot get it to work. I cannot load any passangers and cannot see any yellow bus stops.
I am running Windows Vista on a 64 Bit Computer.
Can you tell me how to solve the problem or direct me to someone who can help. It is a TML product. on a disk. I have been trying to get it to work for 2 weeks now with no success.
Thank you,
Lawrence Hibbard
4602 B-47 Street,
Red Deer, Alberta,
Canada, T4N 1R1
lhibbard@telus.net
403-314-1181
Mar 30, 2011 | City Bus Simulator 2010 York - Windows
My computer screen has error message Frequency out of range. This happened when running Google Earth, it changed the color quality from 32 bit to 8 bit. When I tried to change the bit back I get this error...
Right click on the free space in the desktop and select properties. Then go to display properties and change settings to 32 Bit and Change the screen resolution to 1024 by 768 Pixels.
Apr 05, 2010 | Gateway GT5220 PC Desktop
Driver on original CD is 32-bit Intel compatible platforms only, and I use Windows XP 64-bit
goto > http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=17105
Enter the Operating system.
Download the new driver
Apr 24, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Lost my 32-bit color resolution
if its a stock system with out upgrades can go to
HP select your OS then select graphics
Apr 10, 2009 | HP Compaq Presario SR2011WM PC Desktop
VX-3000 & Windows XP Professional SP3
i am trayng to install my microsoft lifecam vx-3000 from your web side bat on my mesanger is not workin so i deliti and ned help to install windows xp
Dec 25, 2008 | Microsoft LifeCam VX-3000 Web Camera
I have a 9320 One Touch Scanner and can not find the drivers for Vista. This is creating much frustration as I had purchased the scanner new and can not use it. If possible please point me on where to...
System Requirements PC Microsoft Windows 98 SE, 2000 Professional, ME, XP:
Pentium Equivalent Processor or Higher
64MB of RAM (128 MB Recommended for Windows XP)
200 MB of Available Hard Disk Space
CD-ROM Drive
USB Port
Color Monitor
I do believe the scanner does not support windows vista as of yet.
Printer / Scanner
HP Deskjet 6940 (via Network, auto driver) (32-bit)
HP Laserjet 5L (32bit)
hp color LaserJet 2550L (32-bit)
HP Officejet 4200 (32-bit)
HP PSC 1401 All-In-One Printer (32-bit)
Lexmark 240N (Native Driver x64).
Microtek Scanmaker 3600 (32-bit)
Samsung ML-2010 monochrome laser printer (32-bit)
Epson R220 (32 bit)
Brother HL 1030 works after adding a printer manualy and installing as a brother 1430 (32bit)
Dell Photo AIO Printer 964 (32-bit)
HP Laserjet 4plus (32bit)(64bit) with HP Jet Direct as LPR on Standard TCPIP Port
HP DeskJet 845c (32 bit)
(supported printers/scanners)
Apr 20, 2008 | Office Equipment & Supplies
City Bus Simulator 2010 York - Windows Logo
96 people viewed this question
Top City Video Game Consoles & Games Experts
EnergeeUK
Level 1 Expert
richie46
Mister Danger
Are you a City Video Game Console and Game Expert? Answer questions, earn points and help others
