Question about Canon ImageRunner 5075 Copier : IR 5075
My canon ir 5075 show a jam94
When i copie from dadf show jam 94
solofixya
  • 34 Answers
SOURCE: Canon IR-C3200 When trying to copy from platen
HIT THE RESET BUTTON TWICE AND THEN TRY AGAIN.
Posted on May 08, 2009
  • 199 Answers
SOURCE: which one is better to buy IR 5075 or IR 5065
The all above models are same with minor change for speed
You need model as your daily output requirement
All models are heavy duty.
you can select any one for upto 10,000 print or copy per day or for 20,000 & up print/copy select ir 5075
Posted on Jun 15, 2009
SOURCE: regards DADF size setting in ir4570
register your adf
Posted on Jun 21, 2010
  • 62 Answers
SOURCE: My Canon 5075 will only copy out of the legal
What do the two letter trays in the display screen say.
Posted on Jul 09, 2010
edy_bubat
  • 259 Answers
SOURCE: e000808 in canon ir 5075
something wrong in power supply or fixing drive.
the power can not hitting well.
solution is checking both or call technician because they hard enough.
Posted on May 24, 2011
E000004-0010 error on my canon ir 5075
That means induction heater is faulty (insufficient current) and needs to be replaced.
Dont forget to clear error log after the replacement.
(copier>fnction>err>clear)
Nov 03, 2015 | Canon ImageRunner 5075 Copier : IR 5075
No text only blank page on canon ir 5075
Laser shutter stuck, it covers the line of sight from the laser unit to the drum unit when drum is taken out. sometimes things get out or place and it does not open you can see it with the drum cartridge out and move it but if the lever is not broken which it usually is not but only slid off the side of the actuator that pushes it back overcoming spring tension or gravity. Let me know, I didn't look up the model but know that the ir6030 s and other models did this a lot
Jul 24, 2015 | Canon ImageRunner 5075 Copier : IR 5075
MY CANON 5075 TONNER SUPPLY MOTOR PROBLEM REGURALY I HAVE CHANGED MOTOR MANY TIMES BUT STILL IT GETTING PROBLEM WHAT IS THE PROBLEM
try to find the right toner for 5075 and replace it< if the problem still alive,so it's about your toner sensor
Oct 28, 2014 | Canon ImageRunner 5075 Copier : IR 5075
Error 100-001 mesin ir 5075
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured or click start type in event viewer press ENTER you might be able work your way through the problem
Hope it helps.
Dec 18, 2012 | Canon ImageRunner 5075 Copier : IR 5075
E000808 in canon ir 5075
May 24, 2011 | Canon iR 5075 AllInOne Printer
After restarting the machine shows the ready to copy massage it later bring a red indicator without any massage on the screen but the lower massages remain such as copy ratio, density among others what...
did you check jam indicator that glows red left from LCD panel?
Try to reopen the paper drawer and put it back strongly.
If you have dadf it can show jam if its lift up all the way.
On leftsideway, beneath the left door is paper pick up door reopen them and close more strongly.Also check the sensor flapper in the middle, wich is seen when paper pass door are opened.
For service manual you can contact me on emma.servis@gmail.com
Hope that helps!
Sep 04, 2010 | Canon iR 2016i Black and White Copier
When making two sided copy, a messae is given like "Remove doc. on glass"
please be specific, did you put original in dadf ( auto feeder ) or on copy glass?
Aug 06, 2010 | Canon iR 2020i Laser Printer
Which one is better to buy IR 5075 or IR 5065
Jun 15, 2009 | Canon imageRUNNER 5000 Copier
Canon ImageRunner 5075 Copier : IR 5075 Logo
22 people viewed this question
old marine
old marine
