Question about Canon Office Equipment & Supplies
Canon sensys mf8000c laser
We have a Canon MF8000C. I was just trying to load some paper on the tray but now I have a problem putting back the tray. It won't go in all the way. Seems stacked. I don't want to push hard as I might break it. What is wrong?"
SOURCE: Printer won't pull paper into printer
Check the "Feed Switch" button on the control panel (below the ON/OFF button) to be sure the green light at the back of the picture is lit. If not, try pushing the button and then printing again. It worked for me and it was so simple!
Posted on Sep 07, 2008
SOURCE: Canon MF4150 Duplex Printing Paper Jams
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine: Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine) Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part). Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards.  Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
Posted on Sep 09, 2008
SOURCE: Canon MF3240 printer error message.........
I think I solved my printer problem: Chang the paper size to LTR in the printer panel. then go to compter printer setup and choose printing preferences and choose page setup and chang the paper size to Letter (LTR) also. hope this is helpful.
Posted on Feb 28, 2009
SOURCE: Can't print business cards. Won't feed from rear tray.
I just spend over an hour on the phone with Canon for the same problem... the resolution is simple. From the Control Panel, select Printers & Faxes. Right-click the mp620 printer, and select Properties. Select Printing Preferences from the bottom of the General tab, then click the Page Setup tab. Choose Print Options at the bottom. Place a check mark in the box next to "Disable the paper source setting of the application software." Click OK 3 times and the problem should be solved.
Posted on Nov 27, 2009
pineworks
  • 4041 Answers
SOURCE: canon pixma ip1980 service error 6000
Hi there
You can try this may help you.
These are the steps:
1. Turn On iP1980
2. Push and Hold Resume button about 2 minutes
3. Release Resume button
4. Printer back to normal again
To get Permanent , follow the steps here :
Manual Resetter canon Pixma iP1980/1900 Download
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 07, 2010
E 198
This looks like a pretty common error code for different Canon printers. I found some support articles for different Canon printers that suggested you should update your drivers because it was a software bug.
Maybe that's the case for you, and maybe it isn't, but it's a good place to start. The CD that came with your printer was out of date long before you opened the box, so you should download new drivers and install them.
This Canon site has drivers for different versions of Windows: http://www.canon-europe.com/Support/Consumer_Products/products/Fax__Multifunctionals/Laser/LaserBase_MF_series/i-SENSYS_MF4010.aspx
Download and install the version that matches your Windows and see if that helps.
It's also possible that your red light is caused by a paper jam and the printer isn't reporting it correctly. If the driver update doesn't fix it, try opening the paper tray and whatever access panels are there and see if you can spot a piece of paper or debris jamming it up.
If all that fails, I suggest calling Canon's toll free support number. Their technical people on the phone are actually *very* good compared to other companies.
Dec 06, 2013 | Canon I-sensys MF4010 All-In-One Laser...
I own a Canon Image Class MF 4550 d. This morning
Try turning the printer off and back on. If this does not work, try rebooting your computer. Another choice is to go to the Control Panel > Programs > Unistall a Program and delete the printer's software, reboot your computer and re-install the printer's softwre.
If this does not work, you can always return your printer for a full refund or ask them to exchange it for a new one.
Sep 07, 2013 | Canon I-Sensys Mf4550d All-In-One Laser...
Canon printer lbp 3310 paper sensor error flashing red when full of paper
my canon LBP printer 3310 the error is alarm light on what the problem
Apr 03, 2013 | Canon i-SENSYS LBP-3310 Laser Printer -...
I have lost instruction manual. How do I 'copy' on a canon FAX-L120
1-Load the document face up in the ADF/Tray
2-Enter the copy mode by pressing Copy Button
3-Enter Quality
4-Press Start
For any further information/ clarification please refer to Chapter 6, Page 80 & 81 for the Canon i-SENSYS FAX-L120 Manual.
Save the Manual for Future reference
Hope it helps! Good Luck!
CreativeTECH
Mar 11, 2011 | Canon i-SENSYS FAX-L120 Plain Paper Laser...
Load cassette LTR only prints first page
Turn off the machine, under printer driver properties on PC set the custom paper size on A4 or paper tha you use.
Turn on, and try to print.
Jun 28, 2010 | Canon i-SENSYS MF4140 All-In-One Laser...
Memory Full Canon i-sensys Fax L120
try this
press "menu" and then "#" button, go to service mode. Select the "clear data function". and select "memory clear"
Sep 03, 2009 | Canon i-SENSYS FAX-L120 Plain Paper Laser...
Supply rec paper tray - what does this mean when the tray is loaded?
OK, I was having a similar problem: Tray full of paper and tray adjusted properly.
Whatever I tried, the printer kept saying load paper.
I went to print menu>properties button (windows XP this is next to the printer name)>paper source tab.
It tuned out that the paper source had been changed from cassette to multi-purpose tray.
Change it back to cassette and you should be golden.
Jun 03, 2009 | Canon MF8180C Color Laser MFC Printer
We have a canon i-sensys L 100 fax machine and it keeps coming up with the error Check scan Platform and we are unable to send faxes. How do we solve the problem.
Ok,Remove the papercover tray, if you look just above the paper tray you will see the scanner,close the scanner by pushing it upwards,and then your problem will be solved.
Mar 18, 2009 | Office Equipment & Supplies
Fax does not know paper is loaded. says load paper
When you load your paper, you must press the Stop/Reset button for it to reconize you have loaded paper.
Nov 17, 2007 | Canon FAXPHONE L80 Laser
75 people viewed this question
old marine
old marine
