Question about Koss CDR200 2-Disc CD Recorder
Koss cdr200 dual burner
My player wont record, finalize i a disc, it always says recover cd and half the time it never reads my cd-r music discs, ive cleaned the unit, lenses air dusted, tryed numerouse of diff. cd's?
  • Anonymous Nov 03, 2007
    dont know how to finalize a cd
Use digital/audio cds...this cured my problem..
Posted on Jul 07, 2009
  • 112 Answers
I had an issue similar to this - I found if I didn't try to record from the internal player it worked ok. Does it say 'recover' when you try to record anytime? If you open the unit,you might see some capacitors on the power supply on the left hand side have leakedand the power is cutting in and out. 'Recover' usually comes up when a recording is interupted if you switch the unit off during recording.
Posted on Jan 15, 2008
SOURCE:
I am unable to engage the record button, the display reads "unreadable or unrecordable disc"
There are several types of blank discs (CD-R, CD-RW). This unit only handles the CD-R discs. Unfortunately, this particular unit is even fussy about the CD-R discs it does accept. Even more unfortunately, there is no way to determine which will be accepted and which will not work. At this point, I can only advise you to try CD-R discs from a different manufacturer. Read the first review on amazon.com. Same issue I have had. Sorry and good luck.
Jul 24, 2011 | Koss CDR200 2-Disc CD Recorder
When i put a blank disc in side b it says unreadable
i found the only cd-r that works is 40x which seems hard to find at local stores..there are 16x. 20x, 48x, 52x etc.....
Feb 13, 2011 | Koss CDR200 2-Disc CD Recorder
Can I record from a cassette player to the koss
should be able to go directly from tape out of cass deck to input of your koss, as long it has line level inputs (which it should). from there its play on the tape and record on the cd rcrdr. seems the simplest solution
Jan 30, 2010 | Koss CDR200 2-Disc CD Recorder
KOSS CDR 200 RECORDING
Yes, but you, like I could use an owners manual for this thing, as it isn't as easy to operate as the Philips Audio CD recorders. Owner's manual anyone?
You can just press input select for analog, press record, wait then press 'play' to start recording.
Aug 04, 2009 | Koss CDR200 2-Disc CD Recorder
Recording
Willthe b deck playback a normal cd? Sounds like your record laser is gone. It's a philips laser and they are known for it.
Jan 23, 2008 | Koss CDR200 2-Disc CD Recorder
Cdr200 recording
Your CD recorder has 2 sets of phono (rca) sockets on the back. You probably have the outputs connected to your amplifier & speakers. All you need to do is connect your tape deck (or any source except for a turntable) to the inputs sockets on the back of the CD deck.
You might need to switch to external or analogue recording on the recorder.
If you are going to be doing a lot of this type of recording & want it set up more permanently, it might make sense to reconfigure your hi-fi. Shout if you want help with this!
Jan 09, 2008 | Koss CDR200 2-Disc CD Recorder
KOSS CDR200
can I record from an outside source, like a casset player to cd, on the cdr200, if so, how, thankyou
Nov 25, 2007 | Koss CDR200 2-Disc CD Recorder
Koss CDR200 2-Disc CD Recorder Logo
351 people viewed this question
Top Koss Audio Players & Recorders Experts
Steve Allison
Steve Allison
Steven Wander
Steven Wander
Ekse
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
