Question about Saeco Syntia Espresso Machine & Coffee Maker
Saeco Syntia slow brewing
Very slow brewing
EsWorld
  • 1618 Answers
SOURCE: Saeco Odea Go - slow to brew coffee, comes out of steam valve
The steam valve needs to be replaced, because the pins have been damaged from high pressure buildup, could have been caused from a very fine grind. You can also check the screen in the brew unit that might be blocked and causing the high pressure backup.
Posted on Nov 15, 2009
  • 18 Answers
SOURCE: cannot release the brew group for, saeco
Group is stuck in mid cycle due to some obstruction. You will need to have it serviced. Though it's possible to jiggle and pull it out. The machine will not likely reset itself, preventing you from re-inserting the group. Still requires a service to manually remove obstruction and reset it.
Posted on Feb 10, 2010
SOURCE: saeco syntia - error message 'problems with the
I read your post. Could you explain me this problem?
Me too have a syntia, but I never saw this error message.
What kind of symbol do you see?
bye
F
Posted on Jul 12, 2010
SOURCE: water tank parts for saeco syntia
Don't know where you are but www.dutchwest.co.uk in the UK supply the parts.
Posted on Mar 17, 2011
multilinkent
  • 739 Answers
SOURCE: Saeco Syntia - how do I replace the right side
Hi
if you do not mind, could you explain in more detail the problem, so I can try to solve your problem as far as affordable.
regards
Posted on Mar 19, 2011
Why after descaling my new Seaco Syntia coffee machine, it stops while brewing and it requires being primed over and over.
Syntia and Brera machines are made by Saeco. Brera is marketed under the brand name Gaggia (owned by Saeco).
The causes for this malfunction can be due to following in order as stated:
1- The machine was not descaled or it was descaled using products. that are labeled as descaler but they are not. After extended period of not descaling, one may have to use more than one cycle of descaling to remove accumulated depsits of Calcium in the water system.
2- The grind setting of coffee is too fine. Make it coarser by one notch toward coarser setting at a time.
3- The pump is losing its pumping pressure and not pudhing water through the coffee. Replace ULKA pump with an Invensys pump model CP3.
All fully automatic machines are convenient and make classic shots of espresso from bean to the cup at the push of a button. With this simplicity, owners forget its maintenance until machine stops working. Please pay attention to descaling every three months. No excuse is good enough.
Services Unlimited Inc Parts Guru
Oct 18, 2014 | Coffee Makers & Espresso Machines
Syntia out of service code?
If it is under warranty ,call the manufacturer .There are many causes to the service code , coffee beans ground too fine ,setting for 3 beans may be too much if the beans are small, try setting with one bean...
Valve, round cover , spring loaded , on top of brew group dirty, metal valve pin may be covered with deposits from coffee oils . check manual or call a service center , screen of bottom piston plugged with coffee oils , to silver screen plugged with coffee oils .
none of the super-automatics like oily , shiny or over roasted beans .
Dec 19, 2013 | Saeco Syntia Espresso Machine & Coffee...
Saeco syntia leaking out the bottom
Over pressure valve is broken, near the water pump , stop using it and get it fixed , or you may damage your Computer board
Nov 08, 2013 | Saeco Syntia Espresso Machine & Coffee...
Saeco syntia ground coffee chute not working well
The grind on the coffee might be too coarse and instead of making espresso its coming out like drip coffee because the water is running through it too fast.
May 25, 2012 | Saeco Syntia SS Automatic Espresso Machine
My Syntia is about 1 yr old and the display shows a red wrench with the #4 in the lower right corner. What does this mean and where is the nearest service center? I live in Oklahoma.
This is a brew unit blocked error. Try turning the machine off for a few seconds and then powering back on. If this does not correct the problem, then the machine needs to go to a service center unless you are very handy. We are located in Houston, and probably your closest service center. Some of the service centers, such as ourselves, do provide free tech support over the phone and may be able to talk you through it.
Dec 27, 2011 | Saeco Syntia Espresso Machine & Coffee...
Water tank parts for saeco syntia
Mar 02, 2011 | Saeco Syntia Espresso Machine & Coffee...
Saeco syntia - error message 'problems with the water circuit'
bye
F
Jul 11, 2010 | Saeco Coffee Makers & Espresso Machines
Nov 14, 2009 | Saeco Odea Go
Saeco Syntia Espresso Machine & Coffee Maker Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
