Newair af-351 won't blow air - Heating & Cooling
2 Suggested Answers
  • 736 Answers
SOURCE: NewAir AF-350 is blowing water
water normally condenses in the evaporator .. this runs down to a pan that drains to the outside section of the air conditioner .. there it it used to help cool the condenser and overflow runs out a drain in the back ... your unit is not draining the water properly to the back section .. that is usually caused by the air conditioner being being mounted with its top tilted toward the inside ... it should be level or slightly tilted toward outside for proper drainage ... its also possible that paper or other debree has clogged the drains inside the unit from the front section going to the back section ..
Posted on Jul 25, 2010
Which side of the honeycomb filter faces incoming air?
facing incoming air as I suspect it is a charcoal filter used to remove odours from the room air before it goes through the unit
Mar 07, 2016 | NewAir AF-1000W Portable Evaporative...
How do i get my newair af 1200e portable air conditioner to stop blowing cold and warm air.
that is normal operation when thermostat setting is reached it will cycle off compressor.
Sep 09, 2015 | NewAir Heating & Cooling
We have the AF-351 plugged and ready to turn on but it doesn't turn on how do we turn it on.
http://cache.air-n-water.com/manuals/newair-af-351-manual2.pdf read this manul might be of use
Jul 13, 2013 | Heating & Cooling
I have a NewAir AF-350 purchased on 5-21-10. After storage for the "winter" I set it up and the pump isn't pumping water to the pad. I have noticed that the water is going "up and...
Sounds like you may have an air bubble in the drain system. Try adding a little tap water to the pump system to help force the air bubble out. Sort of like priming the pump.
Also, you wouldn't send it back to anyone here on Fixya for Warranty repair. You'd have to send it back to the manufacturer. But, before you do, try talking with someone in the manufacturer's Technical Service Dept. They can probably help you over the phone. Thus, saving time and money.
Hope this helps you solve the problem.
Apr 13, 2011 | NewAir Heating & Cooling
We just purchased this product, it was blowing warm and and now wont blow warm air
Check your thermostat setting at +29 and also mode in "Heat ". If still problem continues, check RV
Dec 09, 2010 | NewAir AC14000H Air Conditioner
The air conditioner is blowing hot air, there is no water to drain
if it is also blowing cold air out of the other vents you need to vent the hot air its blowing outside
Sep 30, 2010 | NewAir ACP-1000E Portable Air Conditioner
NewAir AF-350 is blowing water out the front louvers. Unit is 2 days old.
Jul 25, 2010 | Heating & Cooling
Not blowing cool air
Likely needs freon has leak needs repair local hvac contractor can help. T
Jun 16, 2009 | NewAir ACP-1600H Portable Air Conditioner
Shouldn't it be cooler?
Just found at least one problem with mine. I pulled off the back screen and then pulled off the back cover by undoing the two screws at the top. There is a pad in there that rotates through the water reservoir. If this pad doesn't get wet, you won't get any cooling. My pad was bone dry. Turns out the wire for the motor that rotates the pad was disconnected from the front control panel. I reconnected the wire and now the pad rotates through the water reservoir. We'll see how this works.
May 21, 2008 | NewAir AF-330 Air Cooler Fan
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
