Question about Kitchen Appliances - Others
Delta panini press pp 2010 - Kitchen Appliances - Others
Panini scanner gives error but no details about what is wrong
Hello. The thing you should do first is, turn off the computer and the scanner. Now you need to do is to disconnect the Panini scanner from the computer itself. Then turn on the computer and uninstall the Panini program from the computer. When your done doing all that, reinstall the installtion program for the Panini scanner, then reconnect the scanner back onto the computer, then turn on the scanner and give it a testrun and see what happens. Good Luck!
Apr 22, 2014 | Vision Office Equipment & Supplies
BREVILLE PANINI LOCKED AND I CANNOT OPEN IT...HELP
there is a small sliding lock on it I used to have his model, I think its on the side but look closely you should see the clip holding it closed.
Nov 26, 2012 | Breville BGR820XL Stainless Steel Smart...
Can't get my Krups panini maker to start when it's plugged in. It has no on off switch.
I am sorry for my ignorance.
Ihad not relized that paninis were made in coffe machine ((-:
kolbrun
Mar 03, 2012 | Coffee Makers & Espresso Machines
The driver was not installed. You did not accept the certificate required during installation. (DTD8008)
We have got the same issue too when using the desktop deposit function.
The tech support basically did 2 things to resolve the issue:
  • In Internet Explorer
Oct 05, 2010 | Vision Panini My X 60 Check Scanner
In the permanent press cycle only the spin cycle isn't spinning enough. Clothes are extremely wet must run another spin to get out the water.
Thts right....the permanent press cycle my only spin at 600rpm because the clothes would be creased otherwise. Hence the PP cycle.
Some machines lock the PP cycle to low spin RPM. Some allow you to over ride this setting. Check your machine and have a play with the controls. Some PP clothing should even be drip dry to retain the premanent press in the garment. If you want PP then low spin is needed. fast spin will not be a PP cycle...
Aug 07, 2010 | Washing Machines
Have a Breville Ikon Panini Press ... doesn't work
First point of call would be to check the microtemp, which is the small heat regulating fuse inside. If that has blown, you most likely will have no power.
Otherwise call you local Breville Service Centre. If you're in Australia you'll find them at http://www.breville.com.au/care_agentsearch.asp
NOTE: In Australia, this model has a Two year product guarantee. Check your receipt as it may be under warranty!
May 19, 2010 | Breville 800 Class 800GR Indoor Grill
I need the manual for wolfgang pucks panini maker
MY COMPUTER WOULD NOT GET THE WEB PAGE TO PRINT IT, SO FRIEND DID iT FOR ME , AND i NOW HAVE THE INSTUCTIONS. THANK YOU ..
Jun 11, 2009 | Wolfgang Puck Panini Maker
George Foreman White 10060.
Hi lojo166,
As I understand panini's, they are essentially a sandwich grilled on both sides in a press-type of grill - - precisely what this is.
Cooking time will depend on the thickness of the panini.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Sep 21, 2008 | George Foreman GR10AWHT Indoor Grill
Instruction Booklet Breville SG820XL Panini Press
I forgot how to reassemble the panini press coil /heater
Jun 04, 2008 | Breville 800GRXL
Kitchen Appliances - Others Logo
69 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
