Question about Dishwashers
Dishwasher haier dw12-tfe3 error Code 4
Does Not Pump up the water
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: water leaking from bottom of
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occurs. Removing and Cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there is gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Posted on May 28, 2011
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
Our 3 week old Haier DW12-TFE2 Series Dishwasher has stopped working, the water remains inside from the prievious wash. We have found that by emptying the water manually that it will run a was cycle, but...
Kink in the line or possible obstruction in the discharge, very bad to leave stagment water in your dishwasher you can get contaminents that way, I suggest from experience and to be safe to use extra hot water and bleach a tablespoon or so, and flush thru there, also check the hoses make sure they are not blocked and thewre is an air gap, and the height of the discharge is proper. After flushing get a box of baking soda, and some distilled vinegar and under neath your sink you will see the discharge or p trap, either place that in there thru the sink drain or put in the dishwasher with no dishes of course and allow the vinegar and baking soda enough to just reach the drain turn off unit and let the vinegar bomb do its thing, this also works for your laundry drain too, always good to flush them every now and again, if you start getting water backing up in your tub, you need a pump of your septic tank, or a thaw, or if on city water and sewer, you have blockage, hope this helps, good luck
Nov 05, 2013 | Haier Dishwashers
Water leaking from bottom of dishwasher and error code e6 bush DW12-TFE3 dishwasher
May 28, 2011 | Dishwashers
Where do i get a drain hose for haier dw12-pfe2me-u dishwasher
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend
http://ping.fm/zJDAM
heatman101
Apr 18, 2011 | Dishwashers
Hi threr I have the following problem with my Haier DW12-EFM dishwasher: The dishwasher seems to operate properly for the first several minutes untill program selector knob stops betwin position 2...
This is either a fault with the temperature sensors or the timer it's self, Not a simple one to diagnose without some general knowledge of how these circuits operate
May 14, 2017 | Haier 24 in. ESD100 Built-in Dishwasher
DIshwasher drain clogged Haier dishwasher model DW12-PFE2-E
Remove the drain hose from the sink drain assembly and force air into the hose--The clog should spit out into the washer cabinet. Make sure the drain hose doesn't have any kinks or sharp bends. Hope this helps.
Nov 21, 2009 | Dishwashers
Haier dishwasher
I useto have same problem. For some reason there was water under machine, then i tilted machine, clean water and problem solved. This is built-in dishwasher that is why water acumulates under machine and "leak cut off switch" turn off machine. You can't reset machine while you have water under, machine telling you there is a problem, but Haier wan't put solution on their site - Haier suport is very bad. Sorry for English and hope this help.
Aug 08, 2008 | Haier ESD200 Built-in Dishwasher
Dishwashers Logo
27 people viewed this question
Top Dishwashers Experts
