Question about Samsung Televison & Video
Samsung remote control AA59-00484A
Want to open remote for tv to clean out dust without damaging it I have removed the screw but can't get it open help please
SOURCE: virgin media tv remote control
what you have to do is ring virgin and ask then to send the code.
this code is done stight to your set top box
Posted on Feb 08, 2008
  • 298 Answers
SOURCE: SAMSUNG TV
The LCD Screen can only be replaced. The link for this item is listed below.
Samsung LN-T3253H LCD Screen Replacement
Posted on Apr 16, 2008
SOURCE: REmote Control
Most of the problems is the connections of the cables around the screen some are small electrical high voltage short need to be check, with no lights to see the short.
Posted on May 18, 2008
dnewcombe1
  • 1564 Answers
SOURCE: remote control not working on brand new series 4 42 inch samsung
Make sure the remote is set to operate your tv and not a cable box or accesory. It's in the menu
Posted on Jul 24, 2009
  • 40 Answers
SOURCE: I can't find my Samsung 32" TV manual and I
Not sure how to do the channel scan , but i did find the manual with will include how this is done...http://www.generalmanual.com/Televisions/Samsung-LN32A330-LCD-TV.htm
Posted on Jul 03, 2011
Samsung tv model code LS19CFEK/EN
reset the code and clean the contacts battery very well. Open the remote and clean the keypads for dust, and corrosion. and try again.
God bless you
May 27, 2013 | Televison & Video
Samsung LE32C450E1W TV remote control stopped working, changed batteries no luck, turned off at power source for 30 min which fixed prob temp but has happened again and now turn off doesn't help....
Check the remote control for its infrared emission. Check it with fresh batteries. Clean the battery contacts inside its battery compartment. If these do not help you, you remote control need cleaning. If you wish to know more about how to clean and repair a remote control check this site. Pull up older posts. One among it has details.
Mar 24, 2013 | Samsung TV Remote Control
Samsung txd1372 remote commands doubled or tripled
Murphy's law says that the tv only does what it is told. No flashes on it's own? Check the remote battery's first easiest.
Then open the remote to see if these is dirt or dust in the keypad.
If some liquid got in there clean with solvent on a rag. Don't put the solvent on anything else.
Wipe off the sending unit on the front of the remote with damp rag.
If this does nothing then blame the tv or get another remote to try out.
Mar 03, 2013 | Samsung TXD1372 13" TV
Samsung BN59-00603A remote - flashing VCR button
1) clean the contacts batteries very well with contact cleaners
2) retight the spring contacts batteries with pliers for better contacts.
3) open the remote and clean the KEYpad with c.cleaner from oxide, corrosion, dirty, dust, and proof. The syscom must emit I.R very clean for work.
4) if after you did the before mentioned step, go to the repair shop TV for fix it.
God bless you
Sep 16, 2012 | Televison & Video
I have Roshan tv,my remote is not working,fell,n,damage.model Hh 21scp
1) change the battery with the same type, and full charged
2) clean contacts battery with contacts cleaner
3) resolder the wires connector battery
4) retigh the springs contacts battery with pliers for GOOD contact
5) open the r. control, and clean the keypads switch, for dirty, dust, bad contacts or open contacts test with VOM.Rmember they send clean infrared beam from Syscon Micro trans to the receiver
6) Otherwise you must go to the repair shop TV for fix it
God bless you
Aug 02, 2012 | One For All URC-3021 Remote Control
I have an LSSQ40207 remote and can't seem to get the close caption off the screen.
Hello
It must be due to the function fault with the "CC" button on your remote control. To confirm it, just get into its "Menu" suf through and come to the "close capation" function, select it and try to disappear it by pressing the [Vol or Ch] button on your TVs panel control. If you can do this way, and can't do it with remote button, be sure that, that button on your remote control is not working. Infrared signal rays are emitting each time we press each button on the remote, and frequency of each function for this rays will be different to each other. These rays are recived at the TVs infrared sensor fitted inside and changes the fucnctions as we desire. If any defect in contact of the remote buttons to its internal circuit board, will cause a no-signal condition when we push that button. In most cases, cleaning the remote's inside board will resolve this problem. To clean it, you have to open your remote control. It can be opened by slide up its side groove with some sharp tool, like a knife, without breaking its cabin. Be very carefull not to hurt by yoursef while open it. Inside it you can see a circuit board with a few components. Clean the contact face of the circuit board with a soft cloath dipped in rectified spirit or medical quality turpentine. Allow some time to dry out. Clean the remote button's internal touch pads also. Dirt and dust are the main reason for the contact trouble. If it was due to this dirt and dust, you will get it right this way. Still you finds the fault is there, there is no other way than replace the remote control hadset with same type and nummber.
If you want anymore assistance from me, feel free to get me by FixYa. OK.
Aug 05, 2011 | Panasonic Televison & Video
Proscan tv turns off with remote when pushing the volume or mute button
Hello
There are some push buttons on your remote control handset is internally shorting with each other. The only way to retify it is either by cleaning the internal parts of your present remote control or buying a new one.
To clean the remote control, you have to open it. Most of the remote controls are slip lock type fittings, and can be opened with the help of a small knife, inserting between the slits of upper and lower cabin pieces. Put the knife at the side slits, and gently lift without breaking its cabin of locks. Some models will have one or tw screws, additional to these lock fits. Remove batterise before opening it, and check if there is any screw in the battery compartment.
On opening, you can see a printed circuit board, with 4 or 5 components. Clean the surface of that board [tuching face of kepad], with a smooth cotton cloath piece, dipped in pure alcohol or medecial quality turpentine. Never use any strong solvents like thinner or petrol, as they will damage the plastic and rubber parts. Clean the carbon rubber pads of the touch pad also. Dry it well before reassambling.
After these, your remote should work fine. If not, you have to buy an other, and your remote is irreparable. OK.
Apr 05, 2011 | RCA Televison & Video
(I) spilled milk in my Denon RC-802 audio/video remote control. How do I get it open to clean it without damaging it?
You can find replacement remotes at places like this:
Replacement Remotes
As for cleaning it, most remote controls have TWO different ways of fastening the two halves together. The first is screws. Open the batter compartment and remove the batteries. You may find one or more screws there. Remove the screws and set them aside in a safe place. Sometimes the screws are under labels on the back (the screws are almost always on the back side of the remote). Unfortunately, after you remove the screws, the remote may not open. This is because it is usually also held together by plastic snap tabs. Each remote is different, but the method used is always the same: you take a very thin metal blade, like the edge of a putty knife, and move it along the groove separating the front and back halves of the remote until you feel a "bump" of some sort. Press in firmly on this bump while at the same time torquing the blade to separate the two halves. You will have to do this for each latch, making sure the previous latch you undid doesn't click back in place. You will probably end up marring the edge of the remote a little bit while you do this, but that is unavoidable.
Jan 25, 2011 | Audio Players & Recorders
Samsung TV remote. I noticed today my TV remote wasn't working. I changed the batteries and noticed there had been some leakage from the AAA batteries. Since changing the batteries the 8 buttons on the top...
Giving you some hints. Battery leakage is one enemy of tv control and other remote control. They can corrode your battery spring contact, give contact bridges with neighboring tracks that can cause erratic behavior of your remote.
Some repairs can be done but doesn't guarantee success. First is try to clean the corrosion on battery contact = no power usually. Erratic behavior cause by contact bridging = battery leak residues.
Opening a remote control. Some have screws on its small foot. Covered by a rubber or sticker. Some are notch clip in strategic location you have to fry that one by one, opening first on its weakest side. In some don't want to be open.
Cleaning the board by a soft eraser is one way. After you open the remote. Commonly the button area where contact takes place.
If the first procedure and cleaning doesn't work. Buy new remote or use universal remote controller.
Aug 23, 2009 | Samsung TV Remote Control
SAMSUNG TV REMOTE
You better open your remote and clean circuit board inside.Dirt and dust can caused to malfunction of almost all button.When open already brush it with toothbrush with alcohol and dry it with the use of a hair dryer.
Hope thi may help;
DON'T FOGET TO RATE:
Aug 21, 2008 | Samsung TV Remote Control
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
