Question about Refrigerators
I have a samsung rs261mdwp refrigerator side by side refrigeraor. The freeer and refrigerator section are both warm. The feezer section not cold enough to make ice. Repair person indicated needed a fan motor but did not check fan motor only checked circuit board by looking at it. What could be causing the problem. At one time the refrigerator would stop cooling and then start cooling 3 or 4 days later.
HVACRH20
  • 237 Answers
SOURCE: Problem with fresh food side of my refrigerator freezer
The bulbs dim glow is a worry, sounds like not enough voltage is getting there. If you are comfortable with a multimeter, check what the voltage is at the bulb socket. If you have a low voltage issue due to say the transformer not working properly then the fan will also have low voltage (or no voltage). No power, no fan, no cooling. I'd suspect there are voltage issues with that transformer, especially since it's a 240 VAC model. A transformer typically steps down the 240 volts to 120 volts for light bulbs and maybe even the fans (or the whole refer). The repair man may be correct in that the transformer is built in to a circuit board but it COULD be a stand alone transformer.
Posted on Nov 10, 2006
  • 1314 Answers
SOURCE: GE side by side refrigerator gss22jfmcww not cooling
they are talking about the motherboard at the back of the unit and are prob right parts people see the promb a lot and was just trying to save you some cash good parts store pull the fridge out you will see a panel at the back on the freezer side pull the cover and inspect and you will see a board look for a burned resistor ge has corrected the problem and the new board cures the problem just follow the inst instructions
Posted on Jan 01, 2008
SOURCE: MZD 2766GE refrigerator: freezer side is cold but refrigerator side gradually warms after a week and then freezer side warms.
fan won't start by itself.
Posted on Aug 10, 2008
  • 2920 Answers
SOURCE: Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Posted on Aug 27, 2008
jumptrout51
  • 3361 Answers
SOURCE: the refrigerator section is not cold
Replace the freezer fan motor.
Posted on Feb 21, 2009
The light on the freezer side keeps blinking but refrigerator side not working flashing
possible the freezer needs a recharge of freon . only a repairman can assist with that .
Sep 06, 2015 | Samsung RS261MDWP Side By Side...
Ice maker set up
it takes a couple hours for ice and not as long for water to chill .
Feb 09, 2015 | Samsung 26 cu. ft. Side by Side...
How do I adjust the temperature to make the refrigerator cold
usually there is a control knob inside the fridge just turn it to colder and see what happens
Feb 03, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
Fan malfunction in the freezer samsung rs261mdwp
If your questioning is how to replace it its no easy task. It involves removing everything from the freezer and all the shelving. The back inner panel of the freezer compartment and then removing and replacing the fan. Followed by reassembling everything.
Jul 25, 2014 | Samsung 26 cu. ft. Side by Side...
Samsung refrigerators
if the filter is dirty enough to where it stops the flow of water then yes.a replacement of the filter should fix the problem for you
Aug 19, 2012 | Samsung RS261MDWP - 26 cu. ft. Side by...
Neither refrigerator or freeer is very cold despite moving controls to coldest setting. Notice some frosting on inside of freeer on back part way down.
The defrost system has failed. Most likely a bad heater and thermostat behind the freezer wall panel.
Both controls should be set to the mid-range.
If the heater and thermostat are good then the main control board is bad.
Jul 25, 2011 | Hotpoint HSS25GFP Side by Side...
Feezer cold frig.warm
sounds like your freezer is not defrosting, causing lack of air flow to fresh food side
May 09, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Refrigerators Logo
70 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
