Question about Frigidaire ATF6000ES Front Load Washer
Ftf530fs1 my washing stop turning, its a front load washer, do you know why
SOURCE: washerFrigidaire Front Load Washer
"dr" is a door problem. Most likely not closed properly or a problem with the latch mechanism.
Posted on Aug 03, 2008
rylee_smith
  • 8619 Answers
SOURCE: washer wont spin
Hi!
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
If you find this solution helpful then do rate this solution.
Thanks
Rylee
Posted on Feb 05, 2009
SOURCE: washer is just over 1st year warranty and is
Sounds like unit has bad struts.
Posted on Jun 19, 2009
  • 10 Answers
SOURCE: My GLTF1040AS0 front load washer has stopped
Does the unit stop and display any error code(s)? Is it noisy in Spin? If yes to either your pump drain screen is likely cloged/restricted and the pump itself could be damaged.
AND/OR
Drain hose is pushed to far down into drain stack. This can cause a syphon effect were water drains while the unit is filling.
Posted on Jul 18, 2009
BIKER T
  • 909 Answers
SOURCE: Front load washer FTF530FS1 stop mid cycle,
Seems you have possibly 2 problems. One, check to see if the element is not faulty. If no heat during heating cycle, the washer wont proceed for a long time.. Two, if noisy, especially on spin cycle, the bearings (2 of them) and the seal are faulty. Replace them as soon as possible.
Posted on May 27, 2010
Ftf530fs1 not filliing not spinning
Hello rickclancyar - Is the washer make a humming noise? If so either the drainage hose or pump is clogged and needs to be clean. If not, then the unit could possibly be experiencing an issue with the control board, wiring failure, faulty pump, timer, or door lock assembly. Consult a professional for an accurate diagnosis and to assist with the repairs.
Feb 11, 2013 | Frigidaire FTF530FS Front Load Washer
Strong Odor, almost organic smelling, coming from my Fridgidaire Energy Star stacked Front Load Washing Machine, 5 cycle, Heavy Duty Model# FTF530FS1, Serial # XC90201067. It is in the townhouse that we...
This smell usually comes from items caught in the hose. If you can remove the bottom front panel, (usually 2 screws holding this down) then you will see a rubber acordian piece attached to the water pump. If you remove and clean this the smell should not remian. I just removed mine and found many coins and a huge ball of stinky lint, hence the smell. Good Luck!
Jul 21, 2011 | Frigidaire FTF530FS Front Load Washer
I need to remove the front panel of my Frigidaire front load washer in order to replace the door switch, model #FTF530FS1
all youhave to do is remove part of the boot and unscrew the door switch it will come out far enough to take the wires off and replace the switch.
Jan 22, 2011 | Washing Machines
Front load washer FTF530FS1 stop mid cycle, sometimes for more then an hour, then starts up again, entire cycle can take more then 3 hours? Also during cycle is very loud.
May 27, 2010 | Frigidaire FTF530FS Front Load Washer
Cylce stops after 1st drain before spin out
I have kenmore washer front load H2 after 1st circle of wash it stop and start beeping with code F11. My email address is anarfi1212@ live.com
Jan 21, 2010 | Kenmore HE2 Plus Front Load Washer
Timer goes thru all cycles to final rinse - to fast
HI. This is a defective timer motor. I would replace this defective timer module asap. Once replaced, this issue will be solved.
Oct 13, 2009 | Frigidaire FTF530FS Front Load Washer
When washing stops and flashes f20
That code means "No water or Insufficient water supply" Check the water supply valve, the fill hose screen for debris... Good luck let me know if that solved it..
May 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Front Load Intellisense 6.5kg
washer may not be detecting water temp but water flow ..if you never use hot water may try hooking cold water to a Y-connector and then hooking to both hot and cold inlet valves ..however it is also possible washer is detecting inlet temps in which case you're out of luck ..i suspect the latter
Sep 01, 2008 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
