Asus rock G31M motherboard
No video output after build, all components working ok. Installed a new graphics card incase board integrated one was faulty. Can anyone help?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
Are there any beeps from the motherboard. can you be a explain your problem more elaborately. if there are any beeps try to clean up your ram and try again
Posted on Jul 21, 2013
Hello everyone. Just wondering do I need an optical drive for my brand new pic I just built? And I just installed my motherboard and the graphics card together but nothing is working on the screen.
use the cd that came with the mother board as it has all the drivers to make the mother board work and to line up the graphic card
if the was a cd for the card run that as well
other than that talk to a IT geek shop and get ideas
Sep 14, 2015 | ASUS Computers & Internet
What is visual graphic acdactor ,and the freze
A video card (also called a video adapter, display card, graphics card, graphics board, display adapter or graphics adapter) is an expansion card which generates a feed of output images to a display. Most video cards offer various functions such as accelerated rendering of 3D scenes and 2D graphics, MPEG-2/MPEG-4 decoding, TV output, or the ability to connect multiple monitors (multi-monitor).
Video hardware can be integrated into the motherboard or (as with more recent designs) the CPU, but all modern motherboards (and some from the 1990s) provide expansion ports to which a video card can be attached. In this configuration it is sometimes referred to as a video controller or graphics controller. Modern low-end to mid-range motherboards often include a graphics chipset manufactured by the developer of the northbridge (e.g. an AMD chipset with Radeon graphics or an Intel chipset with Intel graphics) on the motherboard. This graphics chip usually has a small quantity of embedded memory and takes some of the system's main RAM, reducing the total RAM available. This is usually called integrated graphics or on-board graphics, and is usually low in performance and undesirable for those wishing to run 3D applications. A dedicated graphics card on the other hand has its own Random Access Memory or RAM and Processor specifically for processing video images, and thus offloads this work from the CPU and system RAM. Almost all of these motherboards allow the disabling of the integrated graphics chip in BIOS, and have an AGP, PCI, or PCI Express slot for adding a higher-performance graphics card in place of the integrated graphics.
Aug 31, 2012 | Computers & Internet
Hi, I need standard spec info of VGA built on Asus P5GC-MX 1333 whether 64 Mb or 128 Mb. Many thanks & regards, Richard
you can use up to a maximum of 224 mb of your computer's RAM for the onboard video chip to use. You can install a video card with any amount of memory (which would give you a lot better video performance).
Jun 18, 2011 | ASUS P5GC-MX 1333 BULK C2D LGA775 945GC...
Want to know that "ASRock G31M-S" is compatable with Nvidia 9500
Your new card maybe faulty or you might need a larger Power Supply Unit (PSU),, if its just started to happen...
Jul 30, 2010 | Asrock G31M-S Motherboard
My intel d848pmb motherbord in not giving display how to solve it reply me on my id Atiq_killer@yahoo.com plz i m wating for ur good ans
You have an integrated video card on this motherboard? AND u are not getting output to your Monitor? If so, install another video card to see if u will get output to the monitor. If u do, your video output problem is solved. If the integrated video card is the only thing not working on the board, then u can continue using the same board as usual. Be sure to remember to plug ur monitor into ur new graphics card.
Mar 15, 2010 | Intel D848PMB Motherboard
I can't install a GeForce 6200 graphics card
Also, if that card has dual outputs, such as 2 DVI connectors, try connecting your monitor to the other one.
Jul 19, 2009 | ASUS GeForce 6200 TC, TD64 Video Card
Cannot get a g force 5500 to work in a new hp a6700y its plugged in but will not work it has a integrated gforce 6150 in board but will not recognize the new card
Hi..
Make sure that your motherboard can support your new installed video card. Check also that it is plug correctly, try to remove it first and reinsert it again. Remember that the video card are not working properly if your video card driver is not installed.
You need to installed the video card driver.
ICmanServer
Jul 03, 2009 | Nvidia GeForce FX 5500 Video Card Graphic...
Motherboard installation
Hello mecompe,
If you installed an AGP graphics card before your fist boot of the system, you will not receive display. By default the onboard graphics is set to boot display. (If this is the case, remove the AGP graphics card & boot the system). The Asus P4SGX-MX can only use a 4x AGP 1.5volt (only) card.
There is an order of sequences to perform before installing/ adding an AGP graphics card on to the board when the board also uses an integrated graphics card.
First, shut down the system & unplug the power supply from the PC. Connect your monitor to the VGA port at the rear of the board. Remove the AGP card. Re-connect the power supply & boot the system. You should have display? Re-boot the system. As the system starts up press the delete key on the keyboard every 2 seconds. The bios main menu will load. (Open your manual). Go to
section 2.4.3, page 2-20 under Advanced, PCI configuration. Set Primary VGA bios to
[AGP VGA Card]. Save the bios & exit. The system will auto restart. Press & hold the power on/ off button on the PC case until the system shuts off. Unplug the power cord from the PC. Insert the AGP card into the AGP slot. Connect your monitor to the AGP card.
Check all internal data & power cables, (Incase something came loose). Re-connect the power cord & boot the system. You should have display! Install your video software.
If your using the integrated VGA PCI graphics card, go over the bios settings page 2-18 & 2-20.
Need the Asus manual? Click this link;
http://support.asus.com/download/download.aspx?modelname=P4SGX-MX&SLanguage=en-us
To view the manual you'll also need Adobe PDF reader, click this next link for Adobe.
http://www.adobe.com/products/reader/
(The green led (light), means standby. The board is receiving 5volts DC.
If you still do not have display just let me know.
Good luck mecompe!
Mike
Oct 28, 2008 | ASUS P4SGX-MX Motherboard
Graphics card problem
Hi rovin,
So you bought an XFX GeForce 256MB video card. You're board has 1 free AGP 8x video slot & 3 PCI (White opened slots).
You mention there is not slot for the new card. (What type of video card did you buy)? PCI-E, AGP or PCI?
The only slot you're board does not have is a PCI-Express.
Look in you're manual on page 1-7 for the location of the AGP video card slot.
94565e6.jpg If you bought the wrong card, exchange it for an AGP 8x or PCI.
The ASUS P5PE-VM uses a integrated Intel® 865G chipset with integrated Intel® Extreme Graphics 2 Technology, which uses you're system memory to function.
If you need a manual you can download it from Asus. Click on the link to open to the P5PE-VM download site.
http://support.asus.com/download/download.aspx?modelname=P5PE-VM&SLanguage=en-us
I hope you find this helpful.
Mike
May 11, 2008 | ASUS P5PE-VM Motherboard
Installed first start up no video output on pny 8500gt's
Try unplugging all other devices like HD's, CD's, DVD's etc.. and see if you get video. If not, then it could be a cpu problem, memory problem, or even a bad mother bd. Also, if there are jumpers on the board, make certain they are correct.
Geno
Mar 05, 2008 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Computers & Internet Logo
David Payne
David Payne
