Question about Canon PIXMA MP620 All-In-One InkJet Printer
Support code: 6000 - My Printer won't print?
When I got to print something, my computer says that an error has occurred. it comes up with this message: Support code: 6000 A printer error has occurred. Turn the printer off and then on again. If this doesn't clear the error, the printer needs repair. See the user's guide and contact the service center. I've turned the Printer on and off again, and I've turned the computer on and off again but nothing works! Please Help.
SOURCE: My printer will not print Error
im having the same issue
Posted on Oct 31, 2008
  • 1126 Answers
SOURCE: Canon mx330 Error 5100 Error 5100
Cancel printing, turn off the machine. Then clear the jammed paper or protective material that is preventing the FINE cartridge holder from moving, and turn the machine on again. If not remedied, turn off machine, unplug the power cord of the machine from power supply. Plug machine back in and turn power back on. If problem is not resolved, please contact service center. This info is from Advanced Guide Troubleshooting Section under An Error Message is Displayed on the LCD....error code 5100. This is a link to Canon to download Guides.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=18120
Posted on Nov 04, 2009
  • 240 Answers
SOURCE: Printer won't print. Check printer error message
To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
  1. With the printer powered on, press and hold down the <Stop/Reset> button then press the ON/OFF button.
  2. Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.
Posted on Dec 13, 2009
pineworks
  • 4041 Answers
SOURCE: printer malfunction
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
Gunter_N
  • 112 Answers
SOURCE: Laser scanner unit error. Turn off
Hi, Your laser unit is faulty. Its more cost-effective to buy new printer. Having it repaired will cost about same as a new one. If still under warranty then just return and have it replaced.
Regards,
Posted on Jul 29, 2011
My printer canon mx328 error 6000
This information is directly from the Canon website, basically it suggests something is stuck inside. Other articles I found mentioned one person found a paperclip stopping the works.
---- quoting Canon ----
6000/P03 - Orange and green light blinking 3 times Description:
A service error has occurred.
Resolution:
  1. Turn off the printer.
  2. Disconnect the power cable.
  3. Open the printer cover.
  4. Check for any orange protective tape or white polystyrene and remove if necessary.
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
  6. Close the cover.
  7. Reconnect and turn on.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
----- end quote ---
Best wishes -
http://www.canon.co.uk/support/consumer_products/product_ranges/printers/maxify/error_codes/#6000
PIXMA Printer Error Codes and Error Messages
Jul 05, 2015 | Canon Office Equipment & Supplies
This error 6000 always show when i want to print out
It can be many causes..
Something may block the paper feed tray from opening.
When you copy large documents
If you command printing when the tray is covered, the 6000 error occurs.
**If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 14, 2013 | Office Equipment & Supplies
Ink cartridges won't move to the left, error code 6000
You will need a new carrage motor for this, better off with a we printer.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jan 09, 2012 | Canon Pixma iP2600 Photo InkJet Printer
Printer error has occurred 6000
Error 6000 gets displayed when there is a paper jam or other general malfunction. When the message "6000 Printer error has occurred. Turn off the printer then back on again. If the problem persists, see the manual." Is displayed, something may block the paper feed tray from opening.
If the printer is surrounded with documents or when you copy large documents such as books, make sure that you secure the clear space in front of the tray before printing / copying. When the error message above is displayed and if you find something is in front of the tray, remove it. Then, turn OFF the printer and back ON again and the printer will be ready for printing.
If you still have the trouble, contact the repair service.
Check the printer for any paper jam or try to reset the printer to release memory code errors.
1. Press and hold the Resume button for 1 - 2 minutes.
2. Open the cover.
3. Remove the cartridge and then reinstall it.
4. Close the cover.
5. Turn Off the printer.
6. Turn On the printer.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 14, 2011 | Computers & Internet
Printer Error message : Printer Error has occurred. 6000
2. Open the cover.
4. Close the cover.
Dec 21, 2010 | Canon Office Equipment & Supplies
My Canon MP980 is showing Printer Error code 6000. Have turn off machine and turned on again - no change - still showing.
error [6000] or light blinking 3 times is mean there is an error occurred in the LF encoder signal.
May 20, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Instead of printing, the printer ejects empty paper and shows Error code 6000. Restarting the printer as recommended in the manual doesn't help
This Error (error 6000) occurred while attempting to print something. Follow this instruction to clear it.
1) Reset your device:-
  • On the operator panel, press and hold the ON/OFF button for one second. (The display will go blank.) If pressing ON/OFF button does not shutoff the device then unplug the power cord.
  • Wait Approx. 10 Sec then press power button ON/OFF button again.
  • Wait until the device has completed its cycling process before submitting another job request.
or
2) Remove Paper Jam if any
Else your device need service (repair)
Good luck...don't forget to rate the solution
Feb 23, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Error code 6000
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Apr 27, 2009 | Office Equipment & Supplies
Error code 6000 on canon pixma mp210 stops me from printing
Error 6000 means - The specified file could not be encrypted.
Solution: reinstall the printer driver.... it's better to install a upgraded version of driver...
Good Luck!!!
Mar 19, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon PIXMA MP620 All-In-One InkJet Printer Logo
217 people viewed this question
old marine
old marine
