Question about Electrolux Vacuums
Electrolux Ultraactive vacuum Error code
What does the E6 Error code on an Electrolux UltraActive vacuum mean?
2 Suggested Answers
rubin_chad
  • 894 Answers
SOURCE: Electrolux Ultraactive losing suction and turbo
Hi, it's Jeremy from Crucial Vacuum.
There are a few potential solutions you should try to fix the suction of your Electrolux vacuum. The first thing you should check is the height of your brush-roll. Your height setting may be too high for the type of floor you are vacuuming. Raise or lower your brush-roll depending on if you are vacuuming on carpet, tile, or wood surfaces.The second thing you should check is the vacuum bag. If it is full your vacuum can lose suction. This is simply remedied by replacing it with a new and clean bag. The third reason for a loss of suction is your hose is clogged. Check the hose for debris or foreign objects that may be obstructing the flow of air in the vacuum. The last potential reason for your vacuum losing suction could be the brush-roll itself. If it is clogged with dirt and hair it may not be spinning and not picking anything up. Check to see the condition of your brush-roll. If it is clogged remove the debris.
You can purchase direct your Electrolux replacement vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/electrolux.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Posted on Aug 05, 2014
Electrolux Ultraactive losing suction and turbo head brush won't spin. Canister is empty, no blockage in hose or nozzle of turbo head, filters cleaned, but Hepa not replaced recently. Could that cause it...
Jeremy Lerner
Aug 05, 2014 | Vacuums
I have a new Electrolux 4300A (Ultraactive Deep Clean Canister) and the powerhead brushruoll has stopped working. Where is the reset button?
I have repaired many of these and to be honest your best course to to call Electrolux Home Care and find your nearest warranty station. The reason for this is it should cost you nothing and without the on ohm meter and a prior knowledge of how these are put together, you would not be in for a fun afternoon. Call them and explain the problem, most likely you have a broken or pinched wire in the neck assembly and will need a replacement. The wires to the neck attach directly to the main circuit board near the height adjustment, but to retain your warranty call Electrolux now... put down your mouse and call them so you can go back to enjoying your recent purchase with confidence.
(800) 896-9756 Monday-Friday, 9AM-8:30PM (EST)
Saturday-Sunday, 11AM-7:30PM (EST)
Nov 13, 2013 | Electrolux 75922-4 Beam 045056 Power Head
Heppa filter pops off when I turn the vacuum on
Did you replace the exhaust air diffuser? That's the plastic type vent housing the hepa filter was under.
Oct 12, 2013 | Electrolux UltraActive Turbo Bagless...
Remote control Electrolux flashes 3
Can you give more information...what model and what is happen.
Aug 23, 2013 | Electrolux UltraActive EL4300A Bagless...
Ultraactive vaccum filter keeps popping off
There are two possible causes for this issue. The most likely is that your exhaust filter is blocked and so the air literally cant get out. You need to replace the exhaust Hepa Filter every six months anyway so get a new one and see if that fixes the problem. If it still is popping off after this it means the tiny lugs on the filter cover are damaged so you will need to get a new one of those.
Jul 11, 2013 | Electrolux UltraActive Turbo Bagless...
Electrolux ultraactive vacuum won't start
Hi There, The E2 error is caused by the terminal block pins where the hose plugs into the vacuum become bent out of shape. This is the receiving pins at the front of the vacuum on the inside. If what I am saying is confusing then it probably needs to go to a technician, it is a 10 minute job to fix if you have done it before. There is also a slim possibility that you may need a new hose for it too. If you are in Melbourne I can fix it I run the VacuumSpot business.
Jul 06, 2013 | Electrolux Vacuums
How to clean a washable electrolux filter
Hi There,
Ok so i am going to assume you are talking about an Electrolux filter that is basically a rectangle shape with a hard plastic outer and folded corrugated filter material in the middle. The link I put to Electrolux filter would be a good example. Basically I would caution you against washing it. I know the packaging says that it is washable but what I have found is that the pores of the filter material are too fine for water to pass through. What will happen is that the vacuums suction will wedge tiny bits of dirt and dust in the pores and water will not necessarily flush it out. What is far more likely to happen is that it will wash out a fair amount but leave a portion in the filter to set and therefore continue to block suction.
You are better to use an air compressor or simply tap the filter out on a piece of newspaper and change it every year or so.
Of course if your filter is more like a Electrolux UltraActive filter which is basically foam then you simply rinse it out like a kitchen sponge and make sure it is bone dry before putting back in the machine.
Jun 26, 2012 | Electrolux Ultrasilencer Green Canister...
Hi there my electrolux ultra active is flashing 3 E on the remote screen. What is wrong with it?
my electrolux ultraactive vacuum won't start & is flashing between 2/3 on the remote. I've empty the canister & checked filters etc. It's band new I've only used it three times.
Dec 07, 2010 | Electrolux Vacuums
Vacuums Logo
60 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
