Question about Frigidaire Refrigerators
Door ajar warning light/interior light won't come on
Our interior light went out a couple weeks ago. Replaced the bulb but still won't work. Today the door ajar warning started beeping although the door is sealed tightly. It beeps about every 2 minutes or so. The fridge is maintaining it's temp so we know the door isn't actually ajar. Not sure what to do?
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon bibliophilel, based on the symptoms you are describing, may I suggest resetting the refrigerator. This can be done by either unplugging it or flipping the household circuit breaker off. Wait roughly ten minutes and then turn the unit back on. If the issue persists, then more than likely the light socket and/or the door switch that triggers the bulb and alarm are faulty. In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the exact diagnosis of the appliance and repair.
Posted on Jul 23, 2013
  • 1462 Answers
SOURCE: FFA60 Hotpoint fridge/freezer Red warning light
if i read the english right, the compressor runs but the freezer fan only runs for a short time. no fan then no cooling. there is a fan stat so that the fan only runs when the evap is down to temp. this may be faulty. also on some hotpoint, the fan switches off when door opened. check door switch operating ok. this may also explain problem with fridge lamp
Posted on Mar 31, 2007
  • 1314 Answers
SOURCE: Kitchenaid KSCS25INSS
im not sure about the alarm but im going to assume its a door ajar alarm tilt the fridge back using the adjusters on the front wheels till you can open the doors about 1/4 let them go and it will close its self fridges are air tight and some times when you shut one door the air it pushes will slightly open the other the installation inst say level the unit but its better to have them leaned back the lights probably turn of auto if a door is ajar give that a try and let me know please
Posted on Feb 13, 2008
SOURCE: 3 beeps
We had the same problem. Our fridge was beeping and the lights would not come on. To stop the beeping and turn the lights back on we had to press the OVER TEMPERATURE RESET button. As soon as we did this, the lights came back on and beeping stopped. Hope this helps.
Posted on Feb 05, 2009
  • 400 Answers
SOURCE: Fridge/freezer beeping
There is a lever switch usually above the door (when door is in open position) on the fridge cabinet. Not on the actual door. The beeping should stop if this lever is pressed. If the door is positioned correctly it would depress this lever when closed. It may be that the door adjustment is slightly out. If the beeping does not stop when depressed, then your printed circuit board (located usually above the door) is faulty and needs to be replaced.
Posted on Mar 04, 2009
SOURCE: Samsung RB1855SW won't stop beeping and fridge malfunctioning
Thanks so much for the advice. I just gently pried the door sensor switch on my Samsung RB1855SL out with a butter knife and then pulled out the electrical connection and it fired up right away. It looks like some orange juice seeped in and corroded it. What a relief to have the fridge working again, not to mention to not have to listen to the beeping.
Posted on Feb 12, 2010
My 2004 Pontiac grand am se1 acts like door is open and interior light stays on also does t lock on its own when in gear and lights don't blink and horn not honk when locking with key bob
Door ajar switch problem more then likely or wiring issue . The BCM - body control module won't turn off interior light , let door lock because it think's the door is open . The door ajar switch is a input to the BCM .
The first thing would be to have it checked for DTC'S - diagnostic trouble codes . Also check with an enhanced scan tool to see if the BCM shows ajar switch data (open or closed ? Do you know about body electronics ?
Body Control Module
The various BCM input and output circuits are described in the corresponding functional areas indicated on the BCM electrical schematics. The Body Control Module functions include the following:
A/C compressor request. Refer to Air Temperature Description and Operation
Remote Function Control. Refer to Keyless Entry System Description and Operation
A/C cooling Fan. Refer to Air Delivery Description and Operation
Audio Delay Power. Refer to Radio/Audio System Description and Operation
Exterior and interior lighting control. Refer to Exterior Lighting Systems Description and Operation
Daytime running lights (DRL)
Automatic lighting control
Fog lamps
Interior lighting. Refer to Interior Lighting Systems Description and Operation
Battery rundown protection (Inadvertent Power). Refer to Interior Lighting Systems Description and Operation
Chimes. Refer to Audible Warnings Description and Operation
Key-In-Ignition
Head Lamps On
Seat Belt Not Fastened
Turn Signal On
Park Brake Warning
Door Ajar Warning
Check gages
Gage control. Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
Instrument cluster indicator control. Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
Theft deterrent. Refer to Theft Systems Description and Operation .
Engine coolant level sensing. Refer to Cooling System Description and Operation .
Washer solvent level sensing. Refer to Wiper/Washer System Description and Operation in Wipers/Washer Systems.
Key-in-ignition sensing. Refer to Audible Warnings Description and Operation in Instrument Panel, Gages, and Console.
Seat belt use sensing. Refer to Seat Belt System Description and Operation .
Brake fluid level sensing.
Parking brake state sensing.
Rear compartment interface. Refer to Power Door Locks Description and Operation
Horn interface.
Door lock interface. Refer to Power Door Locks Description and Operation
Bulb Check. Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
Oct 24, 2016 | 2004 Pontiac Grand Am
2005 X-Trail interior lighting diagram
If you open other doors besides the driver door do the lights work? If so the door ajar switch is defective in the driver door. Also can you turn on the interior lights from the headlight switch control?
Jul 09, 2016 | 2005 Nissan X-Trail 2.0
While driving door ajar chime goes off, clicking sound form behin
this problem is caused by a tiny micro switch that is attached to the door latch inside the doors, the stick and give this false warning, have replaced dozens of them, it is called the "door ajar" switch oddly enough :)
Jun 06, 2010 | 2002 Ford F250 Super Duty SuperCab
Lites interior dont go off
you have to take out the door ajar switch its in the door it works your interior lights and door ajar switch which is in the door and is hitched to the door latch
Feb 01, 2010 | 1999 Lincoln Town Car
Flashing Dome light constantly when ignition on
check all fuses one might have blown and this could be a warning sign in the old days if you blew out the tail lights the interior light would come on and the signal indicator for which bulbs but also buy the electrical manual available from ford and search out the wiring there could be a jumped circuit
Nov 20, 2009 | 2008 Ford F-350
1999 Taurus - now windows won't open!!
You have probably blown a fuse. The interior light switch is probably faulty causing the light to stay on and the warning to come up.
Make friends with a good Mechanic
Oct 06, 2009 | 1999 Ford Taurus
Door ajar light and interior lights
There is a push button switch in the door frame possibly covered with a rubber boot you may have bent the push pin and it is shorted to the frame, Remove the switch and ensure the wire is still attached to the switch and not loose inside the frame
Mar 11, 2009 | 1997 Lincoln Town Car
While driving, the interior lights and locks went off and on
Check Body Control Module OF Vehicle. This Module Acts As A Switchboard commanding on or off of what ever function inside of vehicle you turn on, wipers, blinkes interior lights etc, possible ground wire to or from control module or possibly bad module!
Jan 31, 2009 | 1997 Plymouth Grand Voyager
Refrigerators Logo
285 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
