Question about HP LaserJet 1100 Printer
My printer won't print multiple pages
I tried to print a couple of hundred pages of text in a PDF document. After about 25 pages my printer started printing faintly in the middle of the sheet. The last two pages it printed before I cancelled the job have a 3.5 inch strip of very faint (almost missing) text in the middle. I thought it was low on toner but after 5-10 minutes I tried printing a test page and it came out with bo problem. After that I tried to print one of the pages that came out wrong and it printed it perfectly. It is second-hand, so I'm not sure how well kept it has been. Can the problem be something other than low toner?
  • 78 Answers
The Toner is running low. What is happening is you are low on toner in the MIDDLE of the Cartiridge. Take the cartridge out and jently shake it left to right (be careful you dont make a mess) this will distribute the toner evenly. time to buy a spare as this wont last much longer.
Posted on Aug 28, 2007
SOURCE:
How to print 11X17 Booklet on CS Kyocera CS3011ikx
Kyocera printers are well-known for their efficiency to produce brilliant color prints. The printer can deliver high-resolution output with crisp black and white text and graphics. The CS Kyocera CS3011ikx printer can print multiple copies that can be folded into a single booklet. Printing a booklet can minimize cost. Read through the instructions given below to understand how to print a 11X17 booklet on CS Kyocera CS3011ikx printer.
1 Press the Copy menu on the control panel to initiate the process. Select the Layout Edit tab.
2 Click the Booklet option.
3 The printer supports single-sided and double-sided printing. Choose either of them according to the printing requirement.
4 Change Default settings and mention the size of the media.
5 Place the original document or text in the document feeder.
6 Press the Start button.
7 Select the appropriate print size. Modify the size as 11X17 to meet the booklet requirement.
8 Change the page size.
9 Open the PDF document.
10 Select the options File> Print. Choose your printer from the list displayed on the screen.
11 Cut and staple the edges of your booklet. Trim the ends of the pages if it is necessary. Call our Toll-Free 1-866-293-9220
Sep 26, 2018 | Kyocera Office Equipment & Supplies
How can i get my printer adjust to eco mode
Set up your printer to save ink and paper (ECO MODE)
Step 1. To specify print settings in any open application go to File, Print or File, Print Preview, then choose Print Preferences. The options available will vary depending on the printer model you're using, but you'll probably be offered the ability to print in Draft or Economy mode and to a set page range.
Step 2. If you're printing long documents, reduce the page margins to fit more lines on each sheet. Open the program the document was created in and alter the margins in the document settings. Alternatively, you may be able to reduce the margins using the ruler guides. In WordPad, you'll need to look in the Page Setup menu.
Printing Advisor Printer reviews
Step 3. One way to save paper is to print more than one page of your document on each side of paper. Your printer will almost certainly have settings for this, and you may also find them within the software you're using. Be sure to check that the resulting text isn't too small to read, however.
Step 4. Duplex printing is the term used for printing on both sides of a sheet of paper. Not all printers are equipped with this feature, but it's a useful way to conserve paper and produce professional-looking documents. Carefully consider whether you want to flip the page on the long or short edge.
Step 5. Most programs have a print preview feature; use this to see how your document will look on the page before printing it out. You can tweak your page as much as you like, only making a final printout once you're happy with the result. This can save money on paper and ink usage, as well as reducing the wear and tear on your printer.
Step 6. Third-party software can help you reduce the amount of ink you use. InkSaver costs £20 or you can try it free for 15 days. We also like the look of the soon-to-launch Ecofont, which perforates text with holes that are invisible to the ***** eye in order to use less ink.
Print to PDF rather than paper
Step 1. A PDF is an exact electronic version of a document that's viewable on almost any device. A PDF protects the original document from editing by the reader, making the format ideal for marketing materials and digital magazines. Download and install the free version of Nitro PDF Reader.
Step 2. Nitro PDF Reader installs a printer driver that lets you export a document to PDF from any application's Print menu. To create a PDF version of your document, simply choose File, Print and select Nitro PDF Creator (Reader) from the list of available printers. Press Print and enter a name for your PDF.
Step 3. For greater speed and convenience, Nitro PDF Reader offers simplified, one-step conversion. Drag your chosen document from Windows Explorer on to the Nitro PDF Reader desktop icon. The conversion will begin at once, with the resulting PDF saved to your desktop.
Step 4. As well as exporting documents to PDF, the software lets you view them - if you're opening more than one then they'll appear on different tabs. Longer documents can be viewed as multiple pages by selecting the Tasks tab and then choosing between Single, Continuous, Facing and Facing Continuous views.
Jul 22, 2017 | PRINTER Office Equipment & Supplies
WILL ONLY PRINT EVERY ALTERNATE LINE OF TEXT & TEXT BOX BORDERS
Doesn't sound like your printer hardware. Try printing something other than your text document. If the page comes out clean/perfect then it means your printer is having a problem understanding your text document via print program translation. Otherwise try converting your text to pdf and print a sample page, if it works then again problem with software/printer translation.
Nov 24, 2013 | Epson Stylus CX3810 All-In-One InkJet...
I am trying to scan a multiple page document into a single pdf document on my HP C7280 but it scans each page to individual images. Any suggestions?
In Adobe Acrobat:-
From 'File' select 'Create PDF', 'from Scanner'.
Scan the first page and the program will ask of you for 'Next' or 'Done'.
Select 'Next' until you have scanned the last page, then select 'Done'.
You can also make the document searchable by carrying out an OCR on it under 'Documents', 'Recognise text under OCR', 'Start'.
Jul 06, 2011 | HP Photosmart C7280 Laser Printer
HP Deskjet 5150 print is too small
Printers try to fit web pages on a single sheet of paper. If you configure the printer, in the print dialog, not to shrink images and text to fit the paper, it will print on multiple sheets of paper, but the correct size for the images and text.
In a Word document, it depends on what font size you have selected. Most people would rather have the web page print on a single sheet, with smaller images and text than were on the monitor; than tape together multiple sheets for 100% size printout.
Jan 31, 2009 | HP DeskJet 5150 InkJet Printer
Printer only prints one page of multiple page document
i dont know how to conect lexmark printer X4250 to my computer
Dec 25, 2008 | Lexmark X4270 All-In-One InkJet Printer
Printer will only print page 1 of multiple page documents
1. Check that you are using the latest print driver - from kyocera website.
2. If the issue is when you print pdf files then make sure you set the printer in KPDL Auto mode - check the print driver settings about this and the printer menu.
3.You may check if you have the latest firmware installed within the printer - print a service status page (Menu->Others->Service).
Nov 26, 2008 | Kyocera FS-C5030N Led Printer
Printer multiple page document
Try this only for windows user:
To resolve this, do the following :
  1. Windows 2000: Go to Start, Settings, Printers.
    Windows XP: Go to Start, Control Panels, Printers and Faxes.
  2. Right click on the printer icon and select Properties.
  3. Click the Advanced tab.
  4. Click the Print processor tab. The Print Processor screen appears.
  5. Change the Print Processor to Winprint and change the Default data type to RAW .
  6. Click OK in the Print processor screen.
  7. Click Apply, then OK.
Apr 09, 2008 | Lexmark X5470 All-In-One InkJet Printer
HP LaserJet 1100 Printer Logo
189 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
