Question about Brother MFC 7420 All-In-One Laser Printer
Reset 7470d cartridges
I refilling toner cartridge how to reset ?
Not sure about your model, but it is nearly always in the menu accessed through a button on the machine. The MFC 7420 does it this way:
Switch printer on
Open front cover
press "Options"
Then enter "*00"
Should then see message saying toner counter reset
Posted on Nov 10, 2013
  • 12 Answers
SOURCE: Brother Hl 5240 printer- toner light on
1) Turn off printer
2)Turn back on
3) Remove Drum and Toner.
4)Press Go for 1 second(it appears to do nothing)
5)Put Drum and Toner back in.
6)Press Go for 1 second(it appears to do nothing)
7)Close door.
Try that
Posted on Jul 05, 2008
SOURCE: Brother laser cartridge refills
OK.. I agree that your problem is with the flag gear. However, there is a specific location in which it needs to be situated. The purpose of the flag gear is to trip a reset actuator on the left side of the printer. The correct position of the flag gear needs to be set so the reset actuator is depressed 3/4 of the way AND where the flag gear moves out of the way once this is done. If the flag gear is moved all the way forward, you run a risk of the gear mechanism inside not rotating it out of the way...which could leave you with a 'no cartridge installed' message. When the manufacturer of the toner cartridge made this unit, they decided to put a mark on the side to, evidently, let the assembly team know where to set the flag gear. Great for us :) On the outside plastic piece that you have to remove to get to the flag gear, you will see a diagonal line and a view window. When you rotate the flag gear, you will eventually see a portion of the white gear in that view window. Line up the white gear portion with the bottom of the diagonal line (typically two gear teeth), and you're done. Assemble and run!
Posted on Aug 01, 2008
  • 320 Answers
SOURCE: How do I reset the drum life of a DCP7010
never ver use refil toner on brother products. to answere your first question 1 open the front cover 2 push menue button scroll down to machine info press set buton 3 scroll down to drun lif - push set
Posted on Jan 16, 2009
rylee_smith
  • 8619 Answers
SOURCE: Brother 4070 Printer will not recognize new toner cartridge
Hi
Just cover the eyes (on both sides) that you can see in the bottom of the machine after removing the imaging cartrige with a small piece of electrical tape.
With printer switched on push the switch which is located inside the upper left side of printer (it is a small white switch) and then release it.
Also try resetting the gear, take the cartridge out. On the gear side take off 2 screws, the black gear on top right side, with a small spring underneath. Just take it off and reset it (rotate clockwise) so it is not at the stopping point.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Apr 20, 2009
  • 22 Answers
SOURCE: Toner light still on with new toner
Is the printer still asking for a new toner..?
If it is the there is a gear that can be reset on the toner cartridge2_bing.gif to tell the machine its a new toner cartridge. This is normally done by an engineer, but is quite easy to do if you know how. And I do :0
Posted on Mar 07, 2010
Brother MFC 7470D
you can use reset gear with follow structure:
http://reset.vn/reset-hop-muc-may-in-brother-mfc-7470d.html
May 20, 2012 | Brother MFC-7440N Laser Printer
Dell 3100n keeps saying "Change Black Toner" even
Before installing a new toner, put a disposable towel over the ink toner exit, and shake your toner lightly back and forth and up and down. Make sure your toner cartridge is in the open position before replacing it in your printer.
If you are using a refillable ink cartridge, make sure you are resetting the cartridge using the method described by the refillable manufacturer.
If this does not answer your question please request more information before voting on my answer. I will try to find more information about your toner cartridge that will help you futher.
Nov 16, 2010 | Dell 3100cn Laser Printer
MFC 9450 - CDN shows toner end of life message. The cartridges had been refilled from bottles. This was solved by resetting the flag gear so the printer thought it had a new cartridge. See this link. As...
You can reset the toner bias by opening the front cover of the printer so that you can see the toner cartridges and then press "clear/back".
This will access the toner reset menu and you can select which cartridge you are reseting.
Thanks,
Pat
Mar 25, 2010 | Brother MFC-8460N Laser Printer
I refilled my toner cartridge and now I can't get it to print. how can i reset it? thanks
You need to reset the flag gear for the cartridge to function. I own a Cartridge World printer cartridge refilling store and I would not recommend drill and fill of this cartridge unless you absolutely don't care about the quality of your prints. This cartridge recycles toner, so you build up paper fibers in the toner which wears on the drums and blades of the cartridge to give you very decorative streaky printing. I'm sure you can find flag gear reset instructions on the internet.
Jan 23, 2010 | Brother HL-2170W Laser Printer
I am using samsung ml-2245 when refill the toner it is acccept the toner
Perhaps you'll need to replace its lockout chip. Toner cartridges have a page counter and that needs to be reset after the cartridge has been refilled. Printing won't commence when the lockout chip has not be replaced with a compatible reset chip.
Nov 14, 2009 | Samsung ML-2240 Laser Printer
Brother Toner Refills
Yeah you can refill your cartridge. It is really easy and consists of removing the plug on the side of the cartridge, dumping out any old toner and dumping in the new toner. Its very easy. I have purchased refill kits from both of these sites in the past and its worked great:
www.tonerrefillstore.com
www.lasertekservices.com
They also have great customer service. I hope this helps!
Nov 08, 2009 | Brother DCP-7040 Laser Printer
Toner light is on and I have a new cartridge in it
The toner sensor where the cartridge is loaded is fouled or you refilled this cartridge and the printer does not reconise the toner inside and thinks its empty ether or sensor or refilled cartridge the printer thiks there is no toner.
1. Did you refill the toner?
2. Brand new cartridge > take it back to the retailer if that does not work the printer will need repair.
Please do leave positive feedback and ratings for your free answer today!!
Oct 20, 2009 | Brother HL-2040 Laser Printer
Need solutons for xerox phaser 3100 after refill message toner empty. how to reset and usr this cartridge
need solutons for xerox phaser 3100 after refill message toner empty. how to reset and usr this cartridge
Aug 08, 2009 | Xerox Phaser 3100MFP/S Laser Printer
Brother HL-4040CN won't read or show new refilled cartridge in the LCD
I think I know what the problem is...
When you refill these toner cartridges you need to reset the "toner empty" cog wheel.
For instructions on how to do this follw this link:
http://www.proprint.co.uk/brother_hl4040.htm
It has pictures and explains how to reset the cartridge
Good luck,
Billy.
May 11, 2008 | Brother HL 1440 Laser Printer
Resetting Toner count onprint settings PRINT SETTINGS report
I don't suggest refilling cartridges as I work on printers every day but seems to me that you have done everything correctly the only thing I think you have done is either filled with incorrect toner thus giving a incorrect reading or when moving gear you have dislodged the pin that activates the reset procedure.
Thanks J
Jan 14, 2008 | Brother HL-2040 Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
121 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
