Cell Phones Logo
Anonymous Posted on Jul 19, 2013
G' FIVE mobile is not dialing
When I press the number keys to dial and then push the phone symbol to send the ring to receiving end the mo bile displays "cannot connect to skype. you cannot make a call at this time. pl.check your mobile network setting and try again".Pl.advise.
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jul 19, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
197
Points
7
Ring gar
not working
1helpful
3answers
How do i reprogram my speeddial numbers on jazz 4400?
Although I've been unable to locate a User Manual specific to your phone, the following information pertains to programming most all NorStar phones:
To Program Buttons On Your Phone:
For External Numbers:
1. Press the Feature button, then * 1
2. Push the button you want to program
3. Display will read "Program and OK"
4. Enter the telephone number, then press the OK softkeyFor Internal Numbers (Extensions.:
1. Press the Feature button, then * 2
3. Display will read "Intercom #:__"
4. Enter the extension number
For Feature Codes:
1. Press the Feature button, then * 3
3. Press the Feature button then enter the Feature Code
To Change the Contrast of the Display:
1. Dial the Feature button, then * 7
2. Press the number keys 1 - 9 to your desired brightness level
3. Press the OK softkey
To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 - 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.)
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94. that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
Additional information about NorStar phones can be found by clicking here:
http://www.telephonemagic.com/phone-support/norstar-feature-programming-code.htm
How to recieve a fax on the Canon PIXMA MX340 Wireless Office All-in-One Printer
Take your incoming phone line and plug it into the place that says "line" on your fax machine. Plug another phone cord into where it says "phone" and connect this to your telephone. Test to make sure you have chosen the right places by dialing a phone number to fax to and listen for the dial tone. If you get a dial tone, then you have set it up correctly.
On the fax machine look for the button that says "menu". Push it and use the up and down arrows to navigate the options on the display. Look for fax set up and press "ok" or "enter" on the fax machines keyboard to access this area. Look for "number of rings" and change the fax machine to a number of rings that is less then your voice mail box if you have one. Then close and save your choices.
Have someone send a test fax by dialing your phone number for the line connected to the machine. The fax machine will pick up on the number of rings set and automatically begin receiving and printing a copy of your incoming fax.
You cannot use magic jack.
You can also choose to manually answer an incoming fax if you see that your display on the fax machine says "ringing" or incoming" you can push the "start" button and this will start receiving your incoming fax.
2answers
I push the feature button it turns red as soon as i enter the phone number the light goes out press feature and does not program
Why are you pressing the feature button?
Press feature then answer. You envoked ringing line pick up.
Press feature then speed dial button, dial a number like your dialing out, then feature again. You've just set a speed dial button.
Press feature, then 3 and you've changed your ringtone on a series i phone.
My phone only rings for 15sec and stops where do i have to change the ringing time
You have to dial a code into the phone and press send, it changes the ring time with t-mobile. Here are the instructions, key part is what number you choose to put in the ( ), (10) (15) (30), etc. You seem to be at (15) right now.
try this from your phone to extend the ring time
dial **61*18056377243**(5-10-15-30)# send
again, the numbers in() represent the amount of time you want the phone to ring before going to voice mail. this can only be done with t-mobile2_bing.gif
Brother Intellifax 4100 unable to send fax but can receive
Is the fax sensing the paper you put in to send out? Check the little black levers that poke into the document area. They should move freely when you touch them gently with a finger, and return quickly when you take your finger off. If it can't sense the paper it won't try to send a fax. If, when the paper is inserted, the display changes from whatever it said to anything else, the paper is being sensed.
Let's try dialing manually. Just left of the 1 key is a button labeled "Hook." Pressing that will take the telephone line "off-hook," like picking up the receiver of a phone. You should hear a dial tone -- if not, try adjusting the speaker volume with the buttons just right of the numbers. Once you get a dial tone, dial a number, whether it's another fax, or your own cell phone. As far as the phone company is concerned, your fax is just a phone, calling another phone. If you can make a call, and the phone at the other end rings, we're closing in on the problem. If you can dial another fax machine manually, you can still turn this into a fax call, assuming there's paper ready to fax. After the distant fax answers, touch the Start button, and your fax should take over. If you can't dial manually, try unplugging your fax from the phone line, and replacing it with a regular phone. Can you make calls with it? If not, the fax is no longer a suspect - you have a phone line problem.
Are you at a business where you need to dial 9 to get an outside line? It's easy to forget that detail when you're using a fax, but it has to dial out just like any other phone on the system.
If you can't get a dial tone at all with the fax, but it works with the phone alone, the main board in the fax is probably bad. If you can dial manually, using the Hook switch, but the same number doesn't work when you dial xxx-xxxx-Start, that sounds like a main board problem, too.
Cannot send fax with a proper working phone line hooked up
I have exactly the same problem! did you find a solution or reason???
2answers
Transfer
Do you mean send the call to another phone?
Make sure the line is not on hold (push the caller's line) then push Cnf/Trn, dial the extension you want the call to go to, then hang up.
The person you're sending to will receive that call on their speakerphone button and it will ring in a different tone.
Panasonic KX-FL511 cannot receive faxes but can send
check to see if your phone line is plugged in the " L" or line slot on your fax machine if it is then press the speaker or monitor key and listen for dial tone. then you put a document into the feeder and dial your cell phone number and press send, when your cell phone rings answer and listen if you are getting a high pitched squeel. if you are then it should be working. try it the other way too by dialing from your cell and listen again for the squeel. if you still don't get the squeel you have a defective modem.
Thank You,
Mikey
Thank You,
Mikey
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
