Oki c330dn service call 134 - Office Equipment & Supplies
OKI C330dn Call Service fatal Error:980
That particular error indicates a fuser failure. Try turning off the printer and re-seating the fuser. If this does not clear the message then the fuser needs to be replaced. With such a low number of prints warranty should cover it.
Aug 29, 2014 | Oki Electric Industry C330dn Led Card...
Okidata printer c330dn copies have black smudged edge on the right
your drum cylinder (opc) or dev roller needs to be replaced
Aug 05, 2014 | OKI C Office Equipment & Supplies
134 error
134 error is led head missing , the fault is either ( if your lucky) the k led ribbon cable has become unseated or the k ribbon pins are damaged (you can trim them with scissors.
Alternatively more often than not someone has nicked the led bar off and tried to put the cable back in without turning the printer off blowing the fuse on the maintenance board. The holders for that model are prone to cracking also.
Apr 10, 2014 | OKI Office Equipment & Supplies
Oki b431 service 134
It may be necessary to replace the LED head. Part number 44317201
Apr 03, 2014 | Oki Electric Industry B431dn Printer
My Okidata C330dn has a "Service Call 991:Error" code. How do I resolve this without a service call?
probably one of colour cartridges (usually not original from OKI) is updetting the printers logic Swap they around (even if you have to use old cartridges), find offending one and replace.
Simple.
Sep 29, 2013 | OKI C Office Equipment & Supplies
Service Call 069: Error
My printer (Oki C330dn) experienced a hardware issue that placed it in a mode where it displays a 'Service Call 069: Error' on startup after the hardware problem was corrected. I used the following button combination at startup, which corrected my issue. Press and hold the BACK, DOWN ARROW, and OK buttons and power-on the unit. Continue to hold the buttons until you see RAM CHECK and some asterisks then release. This forces the unit to ignore all warnings and errors while placing it in an online mode. My printer came up to a ready state and worked normally. The next time I turned it on, it started up without any errors.
Aug 17, 2012 | Cisco Oki C330Dn Led Printer - Color -...
En la pantallade la impresora oki B4350 me marca error 134
Tengo una Oki mc361/mc561 me da error 134 como puedo solucionarlo
Aug 26, 2011 | OKI B4350 Laser Printer
474 people viewed this question
k24674
jasbo
jasbo
