Question about Shurflo 9300 Pump Replacement Motor Kit
Do you have replacement kit in stock and can I collect asap
    Problem Solver:
  • 21 Answers
More info needed
Posted on Jul 28, 2013
How to remove a Sharp MX-FR11U Data Security Kit from a Sharp MX5001N?
The data security kit is designed to be permanent. The only way to remove it would be to replace the data security kit ROMs with the stock ROMs and then flash the firmware back to stock.
It would be a process that your servicing dealer could probably handle.
Why do you need to remove it?
Jun 29, 2014 | Sharp MX5001N copier w/ 36 Month Warranty
Don't want to buy anymore stocks..
then sell them. or give all stocks to me , free. I collect them.
oils stocks are top buy and others, ask.
May 30, 2014 | Cars & Trucks
Need a replacement band for Invicta Mens 4578
with the model number you should be able to find one easily on ebay or amazon. ask the seller any questions before purchase if unsure.
Mar 24, 2014 | Invicta Mens 4578 Russian Diver Collection...
The unit won't run, shows overheating flashing light, we let kit cool, start again and it runs for only a few seconds until it quits again.
possible your motor stock up try to check capacitor or the bearing apply lubricants or replace bearing if needed
Feb 19, 2011 | Hoover Platinum Collection Upright Vacuum
Hi,just got a dynojet stage 1/3 kit for my 1980 honda cb650, it's on standard air box, but 4 into 1 exhaust, I take it I should use the stage one kit. Also I have no instructions can you help...
Intended for motorcycles with a stock engine using the stock airbox, air filter and stock pipe. Stage 1 kits are fully adjustable to allow the use of a well designed aftermarket pipes and stock replacement air filters like K&N. Stage 1 kits are designed to improve throttle response and driveability and in most cases power increases of approximately 5% throughout the entire power range can be achieved.
STAGE ONE INSTRUCTIONS
1. Remove the vacuum slide from the carbs. Remove the stock needles & spacers, noting the order of
assembly. Locate the slide lift holes (Fig. A), with the slide drill DD# 14 supplied, enlarge your slide lift
holes. The picture may not show your slide exactly, enlarge your slide lift hole or holes depending on your
model. Do not drill any new lift holes. Do not drill the needle hole.
2. Install Dynojet needles on groove #4, using all stock spacers. Install the Dynojet washers (2 per
needle) above the E-clip.
3. Remove the stock main jets and replace with the Dynojet main jets provided. If you are running with
stock exhaust, use the DJ110 main jets. With an aftermarket header or slip-on with high flowing baffles,
use the DJ116 main jets. Be sure that the jets you are changing are the main jets.
4. Locate the fuel mixture plug (Fig. B), if you see a screw head, proceed to adjusting procedure. With the
DD #5/32 drill bit provided, carefully drill thru the plugs. Note: the mixture screw is directly underneath this
plug, be ready to pull back on the drill the instant you break thru. Use screw provided to secure and
remove the plug. Carefully turn mixture screws clockwise until they seat, turn out 3 turns.
For further info on this, visit: http://www.dynojet.com/jetkits/motorcycle/honda.aspx
You can find the manual for the model you are searching for. Follow the 1st column "CC" to find 650cc models and you can find your specific model after that.
Thanks for asking.
Regards,
Arvind S Iyer
Oct 15, 2010 | Dynojet Cycling
My printer is canon my absorber is full...i dont
If you absorber is full, you will have to replace it. You can either buy an absorber kit or have it replaced at a service center. A kit should be around $40 and to have it replaced including the kit should be around $100. It's up to you on how your want to handle it.
i'm noit sure what your comment about the "stocked in the middle..." comment means.
Jun 15, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Morigeau Lepine 9000 Collection conversion kits
Call Lazar's in Chicago. 847-679-6146. They may not be able to provide the conversion kit to people outside the chicago area, but they may be able to fax you instructions on how to do it yourself.
Apr 14, 2010 | Baby Gear
I have sound but not picture on a Haier plasma tv
Hi my name is Roety,
I can help you with your issue ,
These Haier TVs go bad and I always install the repair kit part #?TV-3940-01
It includes the scan boards and an upgraded IC .
I can not find any kits in stock, but I know there some available online if you search or call a few places.
Mat electronics or sears parts direct may have some.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Apr 14, 2010 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Problem with hid on 2008 dodge ram 2500
Not too much amperage. HID lights use less amps. Duh. The circuit is showing a failure in the HID kit from not enough amps so it turns off. You need to add a resistor.
Apr 27, 2009 | Dodge Ram Pickup 2500 Cars & Trucks
Shurflo 9300 Pump Replacement Motor Kit Logo
27 people viewed this question
Top Shurflo Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Shurflo Pool and Spa Expert? Answer questions, earn points and help others
