Question about Cell Phones
Pcb nokia m2 jumper was cut - Cell Phones
    New Friend:
All iphone unlock service
Posted on Jul 19, 2013
Please explain the " network settings" for a nokia m2 mobile phone
Go online search Nokia M2 and find a user info site or Nokia website.
Sep 25, 2013 | FR/R Masher 2000 M2 2.2 Truck 2
Where is the ir on the jvc LT-47x899
Usually the IR receiver is located on the same board as the controls on the front of the TV or the same as the LED lights. If you suspect the IR sensor as being bad here are the part number for the control and LED pcbs. Please take a moment to rate my answer. Thanks..
CONTROL PCB: SFL-7224A-M2
LED PCB: SFL-8733A-M2
Nov 24, 2009 | JVC LT-47X899 47 in. LCD TV
Nokia 5200 in mic problam
first check the mic ,mic contact if it is ok then check the track form mic coil,which is embeded back side of the PCB IF IT IS dameg chang it,or put th jumper.
Apr 24, 2009 | Nokia 5200 Cellular Phone
I can detect no SATA' HDD
The ECS PM800-M2 only supports SATA 1.0 hard drives. If you are using a newer SATA 3.0 hard drive, there is a jumper on the hard drive which has to be set to SATA 1.0 in order for the VIA 8237R chipset southbridge (which Is on your ECS PM800-M2) to recognize the newer SATA 3.0 hard drives. This Is applicable to all motherboards with the Viatech PM800 / 8237R chipsets. Note: the location for the SATA 1.0 / 3.0 jumper varies on each brand of hard drives. Also check If SATA Is enabled In the BIOS and select IDE mode.
Apr 23, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
How 2 repaire insert sim card nokia 3100?
sir
pls try this solution, however pls test the contuinity of the jumper lines indicated on the pic before putting the jumper. only those cut lines should need jumper... not that we should use fine magnetic wire to avoid short circuit..
tnx
Jan 31, 2009 | Nokia 3100
Amp is cutting out
Check for bad solder joints on the underside of the PCB. These have a small jumper that connects the two layers of the double layer PCB together near the 12V input terminal. Mine had bad solder joints - resoldering it fixed the amp. You'll need a powerful iron... the PCB traces in this area are massive.
May 15, 2008 | Visonik V217SX Amplifier Car Audio...
Display light n keypad light problem
hi can i know any site from where i can get nokia 6070 pcb diagram or jumper settings any solution because i want to see the pcb diagram
Jan 11, 2008 | Nokia 6070 Cellular Phone
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
