Question about Transcend TS320GSJ25M2 - Storejet 25M2 320 Gb 2.5" External Hard Drive - Usb 2.0 - Sata - 5400 Rpm - 8 Mb Buffer
Connecting ts wx10lpa - Transcend TS320GSJ25M2 - Storejet 25M2 320 Gb 2.5" External Hard Drive - Usb 2.0 - Sata - 5400 Rpm - 8 Mb Buffer
How do I get my turn signals to work rite
check the ts switch the ts flasher or the ts module and before all that make sure all bulbs are working on the ts filament some bulbs have 2 filaments one for ts and one for running lites if all thats good check wiring in ts circuit for opens-shorts- or grounds make sure all connections are tight good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 16, 2015 | Motorcycles
Tip
How to convert TS to MP4 on windows?
What’s the problem?
Q1: I record a couple of videos with my JVC camcorder, and I found these videos are in the MPEG-2 TS formats. Is there any idea about how to put these .ts videos on my iPod?
Q2: I downloaded a couple of HDTV olympic videos and I can't seem to play them.
It a .ts video file (transport stream) file, and I looked for a codec, but came out with nothing.
As we know that .ts files are not widely accepted by a lot of multimedia players or portable media players, so you will find a lot of troubles when you want to play your downloaded HD .ts video clip on your PC, or put a camcorder .ts video to iPod, iPhone, or other portable media players.
Solution to play .ts files on PC or iPod, iPhone and other portable players
How to solve these problems? The easiest solution is to convert ts to mp4 with TS to MP4 Converter. One of these options is Wondershare TS to MP4 Converter which can play .ts video, convert .ts video to MP4 which is widely supported by most players, and edit .ts video.
A simple guide to convert ts to mp4 with TS to MP4 Converter
Please free download Wondershare TS to MP4 Converter, install and run it. And then follow the steps below:
Step 1: Add .TS files
You can click "Add Video" or just drag & drop your .ts videos to the file list directly.
Step 2: Select MP4 as output format
Select MP4 as output format from the categorized output formats list in "Profile" drop-down list and specify the output directory to save your converted files in "Output" drop-down list.
Step 3: Start to convert TS to MP4
After everything is done, hit “Start” button to convert TS to MP4. And all the tasks will be done at fast speed and high quality. The conversion speed often depends on the original video size and your PC configuration.
Step 4: Transfer converted MP4 files to iPod/iPhone or other portable players
Now you can connect your iPod/iPhone, or other portable media player you own with PC, and transfer these MP4 files to it. You know most portable media player accepts MP4 format, such as iPod, iPhone, Walkman, PSP, Zune, Creative Zen, etc. Now, it’s time to enjoy your both downloaded or camcorder record .ts video on your portable media player.
Tags:
ts to mp4
convert ts to mp4
ts to mp4 converter
on Mar 22, 2010 | Cameras
Have a 99 heritage softail. Why does my right signal light start blinking ,on its own.
Hi Bill_mtz, probally because it wants too. No seriously you have either a faulty TS button/switch or a worn wire between the switch and the TS module or a corrupted connection at the wiring harness connector to the TS module or the module itself could be going south. For a free wiring diagram please visit the website below and good luck. Harley Davidson Wiring Diagrams and Schematics
Apr 03, 2012 | 2000 Harley Davidson FLSTC Heritage...
Hi, when i try to connect thin client(L130/L230) , i get following error "ts error stations limit exceeded " , configuration is Dell power edge T110 , OS is Windows server 2003 , i have tried...
I need more details to help
How many TS licenses do you have?, are they PER SEAT or PER USER?
I suspect that you'r TS licensses are PER SEAT
seeya!
Dec 18, 2010 | NComputing L230 Network Terminal
Hello, How can we revoke Temporary TS per Device CALS in Windows server 2008? Thanks.
hi there,
When a terminal server is configured to use Per Device licensing mode, and a client computer or device connects to a terminal server for the first time, the client computer or device is issued a temporary license by default. When a client computer or device connects to a terminal server for the second time, if the Terminal Services license server is activated and enough TS Per Device CALs are available, the license server issues the client computer or device a permanent TS Per Device CAL. If the license server is not activated or does not have any TS Per Device CALs available, the device will continue to use the temporary license. The temporary license is valid for 90 days. A permanent TS Per Device CAL issued by a license server is configured to automatically expire after a random period between 52 and 89 days, at which time the TS Per Device CAL will return to the pool of available TS Per Device CALs on the license server.
In some circumstances, you might want or need to return a TS Per Device CAL that has been issued back to the available pool on the license server before the automatic expiration period has been reached. For example, you might want to do this if the client computer or device is no longer a part of your environment.
In Windows Server 2008 you can revoke a TS Per Device CAL by using the TS Licensing Manager tool.
In Windows Server 2008 you can only revoke a TS Per Device CAL. You cannot revoke a TS Per User CAL.
After you have revoked the TS Per Device CAL, that TS Per Device CAL will be immediately available to be issued to another client computer or device. Revocation is not a substitute for ensuring that you have enough TS Per Device CALs to support your environment.
You can only revoke up to twenty percent of the number of TS Per Device CALs of a particular version installed on your license server. For example, if there are 100 Windows Server 2003 TS Per Device CALs installed on the license server, you can only have 20 of those Windows Server 2003 TS Per Device CALs revoked at any given time. If you also have 200 Windows Server 2008 TS Per Device CALs installed on the license server, you can revoke up to 40 of those Windows Server 2008 TS Per Device CALs in addition to the Windows Server 2003 TS Per Device CALs that you have revoked.
Use the following procedure to revoke a TS Per Device CAL by using TS Licensing Manager.
Membership in the Administrators group, or equivalent, is the minimum required to complete this procedure. Review details about using the appropriate accounts and group memberships at http://go.microsoft.com/fwlink/?LinkId=83477.
To revoke a TS Per Device CAL by using TS Licensing Manager
1. Click Start, point to Administrative Tools, point to Terminal Services, and then click TS Licensing Manager.
2. Expand the node that represents the license server that issued the TS Per Device CAL, and then select the node that represents the version of TS Per Device CAL that was issued. For example, click Windows Server 2008 - Installed TS Per Device CALs.
3. From the list of issued TS Per Device CALs, select the TS Per Device CAL that you want to revoke.
4. On the Action menu, click Revoke TS CAL.
5. To confirm that you want to revoke this TS Per Device CAL, click Yes.
6. If the revocation was successful, a message will appear confirming that the TS Per Device CAL was revoked and telling you how many more TS Per Device CALs of that version you can still revoke.
7. Click OK to close this message. The Status column for the TS Per Device CAL will show a status of Revoked when the TS Licensing Manager display is refreshed.
Hope this helps, good luck, God bless
http://www.onlinepcrepair.vox.com
http://www.onlinepcrepair.url-go.com
Dec 04, 2009 | Office Equipment & Supplies
Connection Pioneer TS-W65A
you are probably looking at a dual voice coil subwoofer. This means you have many options of wiring in series/parralel/or bridged parralel. Go to either www.the12volt.com or crutchfield's learning center in order to figure out what your options are. Then you need to find out what ohm your subwoofers and what ohm your amp is stable at.
May 05, 2009 | Pioneer TS-WX65A Car Speaker
Ts-wx105a pioneer subwoofer connection to car stereo
1 I 2 I 3 I 4 I
---------------------- the wiev from woofer
5 I 6 I 7 I 8 I
1- Right Chanel (-)
2- Right Chanel (+)
3- Left Chanel (-)
4- Left Chanel (+)
5- NC (not connected)
6- GROUND ( - )
7- POSITIVE ( + )
8- Remote (from HU)
Apr 26, 2009 | Car Audio & Video
Cannot find License Server
1. TS and TS licensing server are installed in the same 2003 server. The lsview doesn’t list any TS licensing server.
2. If you open the Terminal Server Licensing, it shows “Finding servers… Connecting to \\apps\chicagotech.net. It never finds the apps server. There is not apps server in the network (They might remove this server from the network). After finishing the finding, there are two activated licensing servers listed, one is Windows 2000 server as 2000 TS licensing server and another one is Windows 2003 (also TS) as 2003 TS Licensing server.
3. The 2003 TS Licensing shows they are using Temporary License.
4. We modified the 2003 TS registry to point Licenseserver to itself (TS and TS license are the same server). That fixes the logon screen slow showing issue but not TS licensing issue.
for further querry
post comment
Oct 16, 2008 | Sibelius Computers & Internet
Change Faulty/Cracked touchscreen on P900
The screen consist of two parts: touchscreen(TS) itself and LCD screen. They're attached mechanically, not with glue or solder.
TS glued to metal frame and by mean of this frame(mechanically) attached to LCD(like shoebox cover) - you can see pits on side.
1. With sharp blade of razor or scalpel gently remove this frame with TS glued on top.
2. Then remove TS from the frame (I simply broke it and removed glass pieces from the frame)
3. Clean the frame with alcohol to remove glue and grains of glass.
4. Glue new TS to the frame at ONE SITTING!
5. Wipe out dust from LCD and inner surface of TS and attach the frame.
6. Buy conducting glue and connect 4-contacts of TS cable with LCD cable. Put adhesive tape over them to maintain electric connection.
That's all.
Jan 28, 2008 | Sony Ericsson P900
Pioneer TS-E6996 polarity?
large spade lug (connection) +
Small spade lug -
Jan 02, 2008 | Car Audio & Video
Transcend TS320GSJ25M2 - Storejet 25M2 320 Gb 2.5" External Hard Drive - Usb 2.0 - Sata - 5400 Rpm - 8 Mb Buffer Logo
19 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
pankaj rautela
pankaj rautela
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
