Question about Kodak EasyShare CX7525 Digital Camera
Internal memory to sd card
I have inserted an sd memory card but it still appears to be taking only 13 photos and keeping them stored on the internal memory instead of sd memory card. Is there something you have to alter to enable the camera to save to sd memory? Thanks
    Problem Solver:
  • 16 Answers
I don't know your camera; but... Before we assume anything about your camera we should check that SD card in another SD device that we know is working. your camera should default to the SD Card like most devices, which are able to use both simultaneously. It seems likely that something might have happened to the SD card if that is the only one you have tried in your camera. food for thought
Posted on Aug 28, 2007
Can i use my atrix 4g whit out a sd card
The memory in the atrix may be full. Delete some pictures from the unit and see if the message goes away.
Aug 04, 2014 | Motorola Cell Phones
How to check memory
It appears the photos are stored on the internal memory in the camers and this us usually a small memory.
You most likely need to insert a large SD memory card in your camera say 8 to 16Gb or more depending upon your requirements..
Mar 23, 2012 | Samsung PL 70 SL720 Digital Camera
When I turn on my Vivitar DVR 410,it says:Memory Full! Please insert an SD Memory Card.Then when I insert my card, it still says Memory Full! Please insert an SD Memory Card.It wont let me take a...
Remove the SD memory card from the camera, go into menu and locate "format" follow the prompt to remove all photo's from the internal memory, when completed install the SD card back in the camera to resume normal operation.
May 28, 2011 | Cameras
I need to transfer internal memory photos onto memory card
First need to take off the SD card; default settign make the SD card as main stored when this is inside the camera.
Take off the SD card and send the internal memory pics at pc folder (use USB connection); insure that the pics are in this pc folder, them delete the files in "internal memory".
Take on the SD card inside tha camera and send pics from pc folder at camera, confirm that the pics are there.
Hope helps.
Apr 28, 2011 | Fuji FinePix A850 Digital Camera
How do i switch photos from internal memory to a memory card
Hello and Welcome to Fixya!
To switch the photos
from internal memory to a memory card follow the given steps:-
  • Insert an SD card into your Kodak V570 camera.
  • Press the "Review" button on the back of the camera and navigate to the photo you would like to copy, then press the camera's "Menu" button.
  • Select "Copy" from the available options and then press the 'OK" button on the back of the camera. Navigate through the available options by using the arrow keys on the back of your camera.Select "Picture" from the list of options that appears to transfer just one picture. Select "All" from the list of options to transfer all of the photos from your camera's internal memory to an SD card.
I hope this solution helps you
For Further assistance, I am here to help
Thank you and Keep Visiting FixYa
Apr 19, 2011 | Kodak EasyShare V570 Digital Camera
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
http://static.infoteldistributors.com/pdf/VC8025%20User%20Manual.pdf
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
7
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
Note:
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
8
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
I have a vivicam 7025, when i insert the SD card says card inserted but then says its going back to internal memory so i cant take no pictures
I also have a vivicam 7025, with the same problem, when I insert the SD card, first it recognises that a card has been inserted but then it says its going back to internal memory. I can't take any photo's and am VERY frustrated!!! Did you find out how to sort yours out?
Dec 21, 2010 | Vivitar Cameras
Internal memory full- How do I fix it
Hello. You can either transfer your pictures to a computer with a usb cable or insert a sd memory card to to store more pictures. If you have a memory card look in your menu settings for the option to copy internal memory to memory card. Another option,if you have a usb cable is to go to a photo center at a department store or drug store and plug the camera into one of thier photo machines.You can then print or copy pictures to CD. Store workers can usually help you with this.
builderdale
Mar 01, 2010 | Kodak EasyShare Z740 Digital Camera
I lost the usb cable for my camera and am trying to remove images from the internal sd card. how can i do this?
For your USB
> Contact kodak store at 1 888 369 6600 ask for KODAK USB Cable, Model U-8 or simply log on to www.kodak.com/go/shop.
To remove images from the internal memory of the camera
1. Turn the Mode dial to Favorites
2. Press the Menu button
3. Highlight delete or the minus icon, then press the OK button.
All pictures stored in the Favorites section of internal memory are removed.
4. Press the Menu button to exit the menu
** Kodak CD33 has 16 MB internal memory and it has a slot for MEMORY CARD 3428db8.jpginternal memory is different to memory card. You can use the camera without memory card but it's only up to 16MB while if your using s memory card you can load up to SD Memory Card 2 GB.
16MB if camera is set to 2MP it will only take about 2-5 photos while if your using a Memory card with a size of 1GB and camera is set to 2MP about 1137 photos.
* Contact Kodak support line @ 1 800 235 6325 (23KODAK)
Nov 16, 2009 | Kodak EasyShare CD33 Digital Camera
Unreconized file format and also says interal memory full
Internal memory is full as you have been saving pictures there rather than your card. Have you checked those are not your missing photos?
Get a new sd card for your camera-I keep 3 cards for mine so that I don't need to delete anything for ages. I back up all photos to pc. The photos on your internal memory can be copied onto your new sd card when you insert it. When you are certain they are on the card AND backed up on the pc then you can delete them from the internal memory.Try mrnu>image storage. On your internal memory there will be an option to copy the photos to a card when you have one in your camera. Do check the internal memory-it is full of pictures-they may be the ones you want!
Jun 16, 2009 | Kodak Easyshare C813 Digital Camera
Kodak EasyShare CX7525 Digital Camera Logo
141 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
