Question about GE Simon XT Wireless Home Security System
Door open tampered alarm
I keep getting this door open tampered error.
My car alarm keeps going off on my 1997 jaguar xj6, how can I disable it ?
not easy to just disable because it is part of the engine control system and will not start if the security system module is disconnected or tampered with but the most likeley cause is one of the door latches faulty or wiring around the trunk hinge broken/opencircuit the security system thinks a door or the trunk is open. the clue to help is check the dash warning saying door or trunk open when sat inside with ignition on and all doors etc. closed or even the hood switch
May 31, 2017 | Jaguar Cars & Trucks
15 year old micromark intruder alarm need to switch off
Not really enough info to give you an answer, but I can generalise...
You say Knocked alarm box with ladder alarm started"
If the fault is there permanently from when this happened there's a good chance that you have disturbed the tamper spring/switch on the cover of the alarm unit. when the front of the panel is removed you should be able to see the Sping/switch which is automatically depressed by this front panel, you may find the spring has fallen off the switch or gone out of alignment, refitting / realigning it should remove the tamper fault once the lid has been refitted properly. As for "bleeps when doors, windows opened"
This sounds like the "Chime" feature has been switched on and without the manual I cannot tell you for sure how to switch it off.
Chime is a feature which "Chimes" when a door is opened (Not often used on windows), if this started when the ladder fell on the panel it is most likely just a single key press to switch it off, Once the tamper fault is sorted you should be easily able to find the correct key press to turn the chime feature off.
Sorry for being a bit general but I don't have that particular manual. Hope the info helps you :o)
Mar 20, 2017 | Home Security
Hi, my house alarm ready light is not on since I opened the anti tamper box, when the box opened the alarm went off, I put in the entrance code number, the alarm went quiet, since then the ready light
Hi Terry,
Most alarm systems require you to reset the tamper alarm.
Most systems will reset the tamper simply by arming the system and then immediately disarming the system. However, you MUST make sure that the Tamper circuit you tripped is closed. If you removed the cover on the panel, make sure the tamper switch for the cover is in the correct position and that the cover is pressing the switch and closing its contacts. If you are trying to arm the panel with a cover off, the tamper circuit will not reset unless you defeat the tamper switch. Just make sure you remove the defeat when you replace the cover. You may also wish to try a google search on the type and model of panel you have so you can download a copy of the manual to check on the reset procedure. We also need to know what brand and model the panel is so we can help you further..
Nov 26, 2014 | Cars & Trucks
Turn off tamper on gardtec 350 so I can fix socket
If you are disarmed, you should only get a trouble signal when you remove AC power, This should clear when power is re-established. The tamper is a switch inside the panel that trips when the door is opened. This too should be only a trouble if the panel is not armed. (Unless the tamper is programmed for instant alarm like a panic or fire alarm input.) Check your manual for the programming instructions for bypassing or disabling the tamper. Another thing you can do is disconnect the backup battery before removing the AC power, this will stop any alarms, but you should notify your monitoring company first.
http://www.innovatealarms.co.uk/pdfs/GARDTEC350+ENGINEER.pdf
Nov 08, 2014 | Home Security
Gardtec 370 repetitive bb tamper alarm
Yes any bell box will do. Just note your terminals.
you can link out the bellbox tamper from the control panel as a temporary measure until you replace the bellbox, assuming its faulty
Apr 12, 2014 | Home Security
The alarm system on my 2001 Volkswagen Jetta GL keeps turning on by itself
You must have the dealer keep the car until this fault occurs and then scan the security system to see what is causing the triggering of the security system. It is very possible that the drivers door ajar switch or latch switch is defective and it triggers a false tampering signal.
Sep 28, 2012 | Cars & Trucks
Verifone vx670 security alarm
Verifone units has multiple sensors built inside for security reason. If you acceidentally dropped or jarred the unit, the sensors will kicked-in and give that error that you have now. And i'm also thinking about your internal system battery is getting low too and needs to be replaced. Then we need to reload the Verifone Tamper Removal Software to clear the Tamper error. Tamper error can be cleared, if you still need help you can call us @ (775) 358-2922 ask for Randy. Hope to hear from you. thank you.
Jun 23, 2012 | VeriFone Vx 670 Payment Terminal
1996 Cadillac DeVille. Door open alarm comes on and stays on when no door is open. How do I fix this?
there are tamper switches in this vehicle. trunk lock asm and at all door latches. be sure all power door locks are operating correctly,if not,that not likely is the door to start with. there are also cancel switches in both front doors. if alarm will cancel when using door key in either lock,then they are ok. but sure to inspect trunk tamper switch mounted by /at trunk lock cylinder for "open". is a normally "closed" switch.
Sep 19, 2011 | Cadillac DeVille Cars & Trucks
The engine wont start and the tamper alert system keeps interferring when it's on. What can I do to fix this problem? We believe it may be the fuel line stopped up, but I want to keep more options open to...
Could you explain more? I know mine did that. If you set the alarm off or unhook and reconnect the battery it will disable the computer and the car will not start. Try reconnecting the battery. That will set the alarm off then insert the key into the drivers door and turn it to disable. It could also be problem with the alarm system. Sorry if
Im misunderstanding.
Mar 31, 2011 | 1992 Chrysler New Yorker
Alarm go off by itself after door lock.
check your battery connections and all alarm sensor/tamper switches at doors,hood & tailgate openings.
Mar 09, 2009 | 1994 Jeep Grand Cherokee
GE Simon XT Wireless Home Security System Logo
22 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
