Question about InFocus LP120 / 1000 Lumens / XGA / DLP Projector Refurbished Multimedia Projector
Infocus LP 120
My procetor just show a red - pink background. Nothing else. I have tried to reset the procejtor to factory settings but that doesn`t work either. BIG HELP. Hilmar
  • WendellT Feb 01, 2008
    I can see images faintly from my computed but everything looks faintly red.
  • itspec Feb 02, 2009
    I have a pink background. Anything that should be white is pink. I tried changing contrast, color, tint, etc. nothing helps. I have the problem on two LP120s.
How can i replace the fan
Posted on Nov 13, 2008
  • frankyj11 Nov 13, 2008
    how can i replace the fan
The projector does not show the color red. It shows it as black or on a black background shows nothing at all. Can you help?
It could be 3 things--
1. You need a new cable
2. This is unlikely, but the red segment could be off the colorwheel, but if this was the case the wheel would be way out of balance and the projector would be vibrating like crazy.
3. The "color ramps" or colorwheel index in the hidden factory menu may need to be adjusted.
Sep 15, 2010 | InFocus LP70+ Multimedia Projector
Projects a pink background image. Have tried resetting to factory defaults and replacing bulb.
try a brand new cable. if that doesn't fix it then your red lcd panel is probably burnt or the lcd cable isn't plugged in all the way.
Jun 21, 2010 | InFocus LP640 Projector Multimedia...
Picture colour is wrong. Too much green and pink.
first reset the settings to factory default. then swap out the cable. if you still have trouble, replace the colorwheel.
Mar 27, 2010 | InFocus ScreenPlay 4805 Multimedia...
InFocus LP540 Red Tint
first swap out the source cable. if the problem persists, reset the settings to factory default. if the problem still persists, your colorwheel may be bad.
Oct 29, 2009 | InFocus LP 540 Multimedia Projector
I have an LP 735. Problem is it looks to have a yellow ghost off to the left side. Focus is ok. All the lettering and all images seem to have this.
first try to reset the settings to factory default. then check to see if the resolution matches the source. otherwise, the lcd is shot, and there are no parts available.
Oct 23, 2009 | InFocus LP 735 Multimedia Projector
Infocus 540 has a blue tint to it.
if it only has a blue tint when the computer or video is hooked up, reset the settings to factory default and replace the cables. if the splash screen (when it says "infocus") has the blue tint, one of the light filters are fried due to excessive heat and dust. unfortunately, you'll have to replace the entire optical engine.
Oct 08, 2009 | InFocus LP 540 Multimedia Projector
Proxima dp100x projector shows red background. Is
the colorwheel or the dmd chip may be bad. but first, go into the menu under service and reset the settings to factory default.
Aug 21, 2009 | InFocus Proxima DP1000X Multimedia...
Infocus LP 70 projects a blurred display
Go to control panel and reset hardware configs that way.
Jun 29, 2009 | InFocus LP 70 Multimedia Projector
Infocus x2
first try another computer cable. if same results, press the "auto image" button on the projector. if that doesn't work, press menu, select settings, then factory reset, and "yes". if you still have the same problem, the eca (main board) is bad.
Sep 01, 2008 | InFocus X1 Multimedia Projector
Infocus LP120 Retrying-Power Light Turns Red...
Usually when the lamp is good and you get this message, the ballast is bad. That is the part thatdrives the lamp. Check with Infocus for a repalacement balast.
Dan
Apr 09, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
InFocus LP120 / 1000 Lumens / XGA / DLP Projector Refurbished Multimedia Projector Logo
451 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Jaime Hernandez
neOen
Level 1 Expert
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
