Wf-s4846pc Washing cycles are not functioning properly; water is not coming in
SOURCE: LG WF-764STP
Your problem might be the motor capacitor
Posted on Aug 31, 2007
SOURCE: I have an LG WF-T552A
your washing machine has a sediment trap in the bottom of it. if you take off the bottom plate you will see a cap/plug with hoses going into the back of it open the cap and clean it out. be ware lots of water will come out, i had the same problem and found 2 of my 1 year olds socks in it
Posted on Sep 26, 2008
SOURCE: error code F-05 water not leaving washing machine
F05 flashes due to electric oven control failure. The solution is to replace the electronic oven control (also called EOC or clock).
Posted on Dec 12, 2008
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
heatman101
  • 43501 Answers
SOURCE: my lg WF-T552TH washing machine will not drain the
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Oct 25, 2010
How do I fix my LG WF-T1391TP top loader washing machine, as water does not flush out after a wash cycle, sometimes after a rinse cycle?
sounds like the drain pump could be clogged up might wanna lay it on its backside and take the motor out and inspect it for any buildup inside of its self as this can/will damage the drain pump however if there is nothing there inside the drain pump then the pump needs replacing
Aug 24, 2016 | LG Washing Machines
LG WF-T7016PP. It makes an operational sound, but why doesn't the drum move?
U been had - go back to the vendor regarding that POS.
Mar 22, 2016 | Washing Machines
My lg intellowasher wf t8501tp won't go into a
Check the pressure switch and hose. Pressure switch is what turns the pump on and off. Trouble is usually in the hose so check it first. Look for the hose to be unattached or clogged.
Jan 13, 2013 | Washing Machines
LG washing machine WF-950 consumes a lot electricity when i did spining , how can i disable spinning option , please advice me
Spin cycles are intergrated into the function on all washing machine (cycles). It cannot be disabled in any way.
May 30, 2012 | Washing Machines
My washing machine model is LG WF-660.. it cannot function due to failure indicator at water level.... it keep on "beeeping" cannot do other operation.... plz help....tq...
pl check the bp sensor or the conector of the wire harness.according to my knowledge there is no door sensor in wf-660.if bp sensor is ok change the P.C.B
Feb 03, 2011 | LG Washing Machines
LG WF T6517TC Washing Machine does not fill water
sir
my washing machine WF-T6517TC
when it start to wash get Alarm "dE" beep and stop machine.
what need to do.
call me 91080843
Apr 10, 2010 | LG Washing Machines
I have an LG WF-T552A Washing machine it wont drain water from the spin cycle and the letters OE comes up on the screen
Sep 26, 2008 | LG Washing Machines
LG WF-764STP
Remove the belt and check whether the motor spins and let us know with your result. Good luck !
Aug 16, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
