Question about Nabi 2
Can i charge my tablet without a charger? - Nabi 2
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 22 Answers
No. Unfortunately you can only use the supplied charger or one similar.
Posted on Jul 19, 2013
My Charger Port is no longer there is there any other way to charge it
Jillian, Check warranty, I beleive should be one year, call manufacturer right away if under warranty. Option 2 Have charger port replaced at a computer/cell phone repair shop. Check links below and see how they fixed this issue.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android tablet charging port fix
How to Fix the Charging Port on Tablet
Is there any way to charge my tablet without the micro USB port
http://forums.androidcentral.com/amazon-kindle-fire/283806-anything-i-can-do-if-my-charging-port-broke.html
Apr 26, 2016 | Tablets & eReaders
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
How do I get my tablet to come on?
Try a faster charger.
If you're only using a USB charger, it might not deliver enough current. Use a genuine 'travel charger' from the original manufacturer to charge at a higher current than the trickle charge coming from your PC or generic charger.
Your other option is to leave it plugged in for a good 24 hours or more... without using it. Worked for me.
Mar 03, 2015 | Velocity Micro Cruz T410 10in Android...
Trouble charging a Digland 10.1" tablet
Did the charger that you are using come with the Tablets? Many 5 volt chargers can only output a 0.5 to 1amp current, while a Tablet typically needs 2 to 2.5 amps charging current. So, if you're using a charger from some other device, then it's almost certain that it cannot provide a sufficient current for the Tablet, and the charger overloads, shuts down cools off, turns on again, overloads again, shuts down etc repeatedly - giving the exact symptom you are reporting.
Even if the charger did come with the Tablet, some of the Chinese ones are of very poor quality and cannot provide reliable service. A replacement charger rated to suit your Tablet (there should be something in the specifications that came with the Tablet listing the requirements for the charger) should solve your problem {:o)
Jan 01, 2015 | Tablets & eReaders
Digiland tablet won't charge. Is there a way to
Depends upon exactly what's happening.
  • When you plug in your charger, does it try to charge the Tablet? ie Does the Charging icon come on the screen briefly when the charger is plugged in with the Tablet turned off, or does the little charging 'lightning' symbol come onto the battery icon on the home screen when the Tablet is running?
  • I assume the battery has gone flat, but will the Tablet turn on when the charger is connected?
If the charging icon comes on, and/or the tablet will run on the charger, then both the charger and the charge port connection on the Tablet are OK, and the most probable cause of failure is the internal battery which will need to be replaced.
However, If neither the icon comes on nor the Tablet runs on the charger, then either the charger has died, or the plug/socket on the Tablet where it connects is faulty. The most likely cause is that the charger has died and will neeed to be replaced
There is a slight chance that the internal charging circuits in the Tablet may have developed a fault, but that is highly unlikely {:o)
Dec 30, 2014 | Tablets & eReaders
My tonbux 10.1 will not switch on
Most likely the charger is not functioning. Test it with a meter where it goes into USB port and plugged into wall outlet.
Dec 01, 2014 | Tablets & eReaders
How to reset SVP TCP-1020 tablet
In most cases, the battery comes loose from the main connection. Those tablets do come apart, the back just presses on.
Jul 30, 2014 | SVP 10-inch Tablet
Unable to switch on my samsung T210 tablet
The charger has a function that restores the battery operation parameters by discharging then charging the battery a number of times. Refer to charging instructions in the pack but I think the cycle is a 3 hourly one, time to charge from a full discharge. If the charger thinks the battery is dead then it will try to recover the battery using this process. You may have left the charger on long enough to charge then also discharge the battery.
Start again and charge for the time in the instructions ONLY, if you are not sure of the time try it for an hour, then without disconnecting the charger turn the unit on and take particular note of any screen messages, if any.
You should be able to continue as normal now, but still be aware of the time you are leaving the charger connected for, as it may take some time before it returns to normal operation and stops trying to recover what it thinks is a dead battery.
Feb 17, 2014 | Samsung Galaxy Tab 3 SM-T210 8GB 7"...
Tablet will not charge or power on
Battery is probably dead. If it's to far gone, the tablet will not charge or work.
Also, try taking the OEM charger/chord (not some ebay or cheapo gas station charger) and plug it in overnight. It may suprise you and start to charge.
Nov 20, 2013 | Gateway M275 Tablet PC
Will not turn on
If tablet keeps burning out charges it is due to the fact that an internal short in the tablet is making the charging unit exceed its parameters and allowing it to burn itself out. The issue is with the tablet, not the chargers.
Mar 13, 2017 | Ainol 10" Novo 10 Hero 16GB Dual Core IPS...
Nabi 2 Logo
118 people viewed this question
Top Nabi Tablets & eReaders Experts
Steve
David Payne
David Payne
jeff5may32
Are you a Nabi Tablet and eReader Expert? Answer questions, earn points and help others
