Question about Westinghouse LTV-32w3 HD Television
TV: Great sound, no picture
Woke up one morning and turned the t.v. on. The blue light on the side panel appeared; however, there was only a blank screen - no picture. The audio worked perfectly. I unplugged the t.v. and let it sit for half an hour. I turned it back on, and again, the same problem: perfect sound, no picture. Utilizing the remote, I pressed attempted to turn the channel and select various menu options. Nothing ever appeared on screen. Can someone please help me?
  • 2035 Answers
SOURCE: Westinghouse LTV-32w1 32 in. HDTV-Ready
The fly back unit as failed resolder the flyback side,most of problem is cause by loose contact only, or if your not tech person need to get it serviced it would cost 50 $ to 100 S.............
Posted on Jun 08, 2008
SOURCE: Westinghouse 32in HDTV-Ready
I called westinghouse with a similar problem(my picture shows up but all the white turns blue or somtimes pink).
they say the problem is similar to that of the xbox 360's red ring of death problem. Now what needs to be done is the unit needs to be unplugged completely for about 30 minutes. this allows the unit to completely cool down. and when the unit restarts and heats up the troubled connections will reflow and all will be fixed.
I tried this and it worked well for my TV. but it is only a temp fix and will need to be done again if the problem occurs.
Posted on Apr 16, 2009
  • 1077 Answers
SOURCE: westinghouse 42' tv working fine this morning, got
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jul 01, 2009
  • 120 Answers
SOURCE: My westinghouse flat panel has lost its picture
Hello, It seems you might have to replace the main board on your unit since the board is not booting up all the way and it is also jamming the signal. If you are interested in obtaning the part please email Westinghouse parts at for price and availability of the main board.
Posted on Jan 29, 2010
  • 11361 Answers
SOURCE: Blank screen
You need to do some inspection inside.
Please see my basic troubleshooting guide here:
Posted on Jun 18, 2010
Westinghouse flat panel television problems
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jun 15, 2017 | Westinghouse LTV-32w3 HD Television
My sony trinitron is blinking red and won't turn on
Jun 25, 2013 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Emerson TV no picture, but still have sound
If this is an LCD TV, show a flash light (torch light) on the screen from a safe distance.
If you can see the picture, the backlight has gone off and might need
of a qualified service technician.
Aug 05, 2012 | Emerson Televison & Video
I turn on the T.V. and the blue light is blinking and the T.V. doesn't turn on
1. simultaneoulsy press and hold [menu] and [vol-] on TV side panel
2. press and release [power] on TV side panel
3. count to 5 and release[menu] and [vol-]
4. TV should have turned on
5. if not, unplug TV and press[power]
6. repeat from step 1 if the TV does not power on the 2nd time
Jul 10, 2009 | JVC LT42P789 42 in. LCD TV
Have sound but no picture on RCA
Resolder all the Pinns on FBT flyback transfomer, CK capacitors cp114,120,150 if ANY OF THEM IS PUFFED UP ON TOP REPLACE ALL 3 OF THEM 2200UF 16V (2) 220UF 35V.
Feb 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Powers on by itself
TV worked FINE for the past 2 yrs---this morning we woke up and the screen is totally BLACK! No sound..nothing. REmote doesn't do anything to the TV. Red light says ON unless we unplug it. Remote won't turn off the TV.
Any advise? Picture tube??
Worked great w/out any problems until we woke up today!
Jun 01, 2008 | RCA 32V420T 32" TV
No picture but has sound
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Crashing sound on Protron 32 TV
no sound, everything was working fine the night before. woke up the next morning, and turned the tv on, and there was no sound at all. nothing from the TV, DVD, and nothing from the Computer. Please help.
Dec 26, 2007 | Protron PLTV-32 Television
Televison & Video Logo
32 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
